Sign in to follow this
jeorainc
wake up from hibernation, system crash?
Hi all,
Let me first introduce my xpenology build:
Intel E2140
Intel D945GCNL
1G DDR2 ram *2
4*1T hitatchi HDD
4493 u2 with nanaoboot (upgrade from trantor 4.3)
After a bunch of test, I found that if I try to wake up the nas from hibernation through apps (video station etc), or samba file system (access a network drive from a windows client), the disk wake up from hibernation, and the access takes time to load.
Sometimes it will just fail, and then I no longer access unless reboot. Even the web GUI login still failed. It will just stuck at the screen "Processing, please wait..."
If I perform a reboot at commandline using root with command "reboot", the console will show the error "segmentation fault" and failed reboot. A hard reset is required.
To work around this issue, I disabled the hibernation, and so far the system is great.
Can someone please share with me your system with hibernation on and any unusual behavior occur?
Thanks a lot for your help!
Share this post
