Hydrael Posted September 1, 2019 #1 Posted September 1, 2019 Hi, Sorry for my noob question I really try to find out answer via serach bar but I still cant figure out how to get HDD Health info in XPEnology. I am runnung 2 virtual systems running in VMware 6.7 build on Juns loader 1.04b DS918+ properly but I cant figure out how to get health disk info from drives. I build both VM by Tutorial: Install DSM 6.2 on ESXi 6.7 and have latest version of DSM there... only diferences are drives controlers : 1.system passthrough LSI SAS3008 9300-8I flashed to IT mode. 2.system passthrough motherboard SATA controller from ASRock Z370M-ITX/AC (SMART enabled in bios) For both systems I m not able to get this info. Could you please help me what I should check or explain me why its not possible? I would be very happy for any answer or advice. PS: sorry for my bad english. Quote
bibicu Posted September 1, 2019 #2 Posted September 1, 2019 I have the same problem and I spent the past week trying all sorts of things. I just can't see the Health info with Jun 1.04 loader and DS918+. I am passing the Intel SATA controller to Synology VM. I went so far to create another VM, using Jun 1.03b loader and DS3615xs, passing through the same SATA controller and having the same HDD. So, two VMs, one can see Health info, one cannot. Both running DSM 622-24922. Any suggestions would be much appreciated ! Quote
bibicu Posted September 2, 2019 #3 Posted September 2, 2019 9 hours ago, bibicu said: I have the same problem and I spent the past week trying all sorts of things. I just can't see the Health info with Jun 1.04 loader and DS918+. I am passing the Intel SATA controller to Synology VM. I went so far to create another VM, using Jun 1.03b loader and DS3615xs, passing through the same SATA controller and having the same HDD. So, two VMs, one can see Health info, one cannot. Both running DSM 622-24922. Any suggestions would be much appreciated ! I forgot to tell: in the DS3615xs / 1.03b machine I can see the Helath info. In the DS(18+ / 1.04 I cannot Quote
