yaaa4 Posted June 16, 2014 #1 Posted June 16, 2014 Hi guys I've updated my Xpenology from 4.2 to 4.3. I had some randoms crashes with the 4.2 so I wanted to try the 4.3. I've updated to 4.3 successfully. For now, the randoms crashes stop (yes!) But my IDE/PATA drives are not mounted or recognize by the 4.3. If I remember correctly, I did have to mount manually the PATA/IDE drives. Is anybody has a suggestion? Maybe I have to mount the drives... but how? Thanks! Yaaa4
