ozool Posted April 15, 2019 #1 Posted April 15, 2019 Hi, I'm trying to switch from a Highpoint SGL2720SGL to an LSI 9207-8i. The system is running correctly on ESXi 6.7 with the Highpoint card but seems to crash when I switch to the 9207-8i. The 9207-8i works perfectly when passed through to a Windows VM, but nothing shows up in Synology Assistant when passed to the Xpenology VM. I'm using loader 1.03a2 with DS918+ and I have synoboot on SATA0:0 with a second virtual disk on SATA1:0. Can anyone help? Pasting my serial port output below. Thanks. patching file etc/rc patching file etc/synoinfo.conf Hunk #2 FAILED at 266. Hunk #3 FAILED at 311. 2 out of 3 hunks FAILED -- saving rejects to file etc/synoinfo.conf.rej patching file linuxrc.syno patching file usr/sbin/init.post START /linuxrc.syno Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module ohci-hcd ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module xhci-pci ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading module BusLogic ... [ OK ] :: Loading module vmw_pvscsi ... [ OK ] :: Loading module megaraid_mm ... [ OK ] :: Loading module megaraid_mbox ... [ OK ] :: Loading module scsi_transport_spi ... [ OK ] :: Loading module scsi_transport_sas ... [ OK ] :: Loading module libsas ... [ OK ] :: Loading module raid_class ... [ OK ] :: Loading module mptbase ... [ OK ] :: Loading module mptscsih ... [ OK ] :: Loading module mptspi ... [ OK ] :: Loading module mptctl ... [ OK ] :: Loading module megaraid ... [ OK ] :: Loading module megaraid_sas ... [ OK ] :: Loading module mptsas ... [ OK ] :: Loading module mpt2sas ... [ OK ] :: Loading module mdio ... [ OK ] :: Loading module 3w-9xxx ... [ OK ] :: Loading module 3w-sas ... [ OK ] :: Loading module aacraid ... [FAILED] :: Loading module arcmsr ... [ OK ] :: Loading module gdth ... [ OK ] :: Loading module hpsa ... [ OK ] :: Loading module hptiop ... [ OK ] :: Loading module isci ... [ OK ] :: Loading module mvsas ... [ OK ] :: Loading module mvumi ... [ OK ] :: Loading module aic94xx ... [ OK ] :: Loading module cciss ... [ OK ] :: Loading module ips ... [FAILED] :: Loading module sx8 ... [ OK ] Insert net driver(Mindspeed only)... [ 3.212932] BUG: unable to handle kernel paging request at 0000000000306d73 [ 3.213522] IP: [<ffffffff813f0c19>] syno_ahci_disk_led_enable+0x39/0x170 [ 3.213936] PGD 72e85067 PUD 76f5c067 PMD 0 [ 3.213980] Oops: 0000 [#1] PREEMPT SMP [ 3.214025] Modules linked in: apollolake_synobios(PO+) etxhci_hcd sx8(E) cciss(E) aic94xx(E) mvumi(E) mvsas(E) isci(E) hptiop(E) hpsa(E) gdth(E) arcmsr(E) 3w_sas(E) 3w_9xxx(E) mdio(E) mpt2sas(OE) mptsas(E) megaraid_sas(E) megaraid(E) mptctl(E) mptspi(E) mptscsih(E) mptbase(E) raid_class(E) libsas(E) scsi_transport_sas(E) scsi_transport_spi(E) megaraid_mbox(E) megaraid_mm(E) vmw_pvscsi(E) BusLogic(E) usb_storage xhci_pci xhci_hcd ohci_hcd(E) usbcore usb_common bfex(OE) [ 3.218936] CPU: 1 PID: 4901 Comm: insmod Tainted: P OE 4.4.59+ #23739 [ 3.218981] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/28/2017 [ 3.219936] task: ffff880070a3c480 ti: ffff880036b54000 task.ti: ffff880036b54000 [ 3.219981] RIP: 0010:[<ffffffff813f0c19>] [<ffffffff813f0c19>] syno_ahci_disk_led_enable+0x39/0x170 [ 3.220937] RSP: 0018:ffff880036b57b90 EFLAGS: 00010206 [ 3.220981] RAX: ffff880070162000 RBX: 0000000000306d63 RCX: 0000000000000000 [ 3.221025] RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff880070162500 [ 3.221070] RBP: ffff880036b57bc0 R08: 0000000300000001 R09: 0000000700000005 [ 3.221114] R10: 0000000300000001 R11: 0000000700000005 R12: ffff88007375b740 [ 3.221117] R13: ffff880070162000 R14: 0000000000000001 R15: ffff88007a776ac0 [ 3.221898] FS: 00007fa87ede2700(0000) GS:ffff88007fd00000(0000) knlGS:0000000000000000 [ 3.221942] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 3.221986] CR2: 0000000000306d73 CR3: 0000000072c4c000 CR4: 00000000001606f0 [ 3.222031] Stack: [ 3.222075] 0000000000000286 ffffffff8180e040 ffff88007375b740 0000000000000000 [ 3.222937] ffffffffa02e15f0 ffff88007a776ac0 ffff880036b57cb8 ffffffffa02e516a [ 3.222981] ffff88007d0da248 0000000000000000 0000000000000286 ffff880036b57c20 [ 3.223025] Call Trace: [ 3.223070] [<ffffffffa02e15f0>] ? remove_card_detect_proc+0x20/0x20 [apollolake_synobios] [ 3.223937] [<ffffffffa02e516a>] synobios_model_init+0x10a/0x650 [apollolake_synobios] [ 3.223981] [<ffffffff812b63ff>] ? ida_pre_get+0x4f/0xe0 [ 3.224026] [<ffffffff8119da2d>] ? proc_alloc_inum+0x3d/0xc0 [ 3.224070] [<ffffffff8119dba9>] ? proc_register+0xb9/0x110 [ 3.224114] [<ffffffffa02e15f0>] ? remove_card_detect_proc+0x20/0x20 [apollolake_synobios] [ 3.224937] [<ffffffff8119dd12>] ? proc_mkdir_data+0x62/0x90 [ 3.224981] [<ffffffff8119dd60>] ? proc_mkdir+0x10/0x20 [ 3.225026] [<ffffffffa02e1663>] synobios_init+0x73/0x470 [apollolake_synobios] [ 3.225070] [<ffffffff810003b6>] do_one_initcall+0x86/0x1b0 [ 3.225114] [<ffffffff810df1d8>] do_init_module+0x56/0x1be [ 3.225159] [<ffffffff810b554d>] load_module+0x1ded/0x2070 [ 3.225203] [<ffffffff810b28b0>] ? __symbol_put+0x50/0x50 [ 3.225247] [<ffffffff81112da5>] ? map_vm_area+0x35/0x50 [ 3.225292] [<ffffffff811140ec>] ? __vmalloc_node_range+0x13c/0x240 [ 3.225937] [<ffffffff810b5858>] ? SYSC_init_module+0x88/0x110 [ 3.225981] [<ffffffff810b58cf>] SYSC_init_module+0xff/0x110 [ 3.226026] [<ffffffff810b5969>] SyS_init_module+0x9/0x10 [ 3.226070] [<ffffffff81566b17>] entry_SYSCALL_64_fastpath+0x12/0x6a [ 3.226114] Code: 41 55 41 54 53 48 8d 64 24 f8 e8 93 0d fb ff 48 85 c0 4c 8d 28 0f 84 39 01 00 00 48 8b 98 b0 07 00 00 48 85 db 0f 84 22 01 00 00 <48> 8b 7b 10 4c 8b a3 20 38 00 00 e8 07 5b 17 00 31 d2 31 ff 48 [ 3.228937] RIP [<ffffffff813f0c19>] syno_ahci_disk_led_enable+0x39/0x170 [ 3.228982] RSP <ffff880036b57b90> [ 3.229026] CR2: 0000000000306d73 [ 3.229153] ---[ end trace 13b0883ac134e798 ]--- Killed Starting /usr/syno/bin/synocfgen... /usr/syno/bin/synocfgen returns 255 rmmod: can't unload 'apollolake_synobios': Device or resource busy [ 3.234956] md: Autodetecting RAID arrays. [ 3.240187] md: invalid raid superblock magic on sda3 [ 3.240227] md: sda3 does not have a valid v0.90 superblock, not importing! [ 3.242073] md: invalid raid superblock magic on sdc3 [ 3.242113] md: sdc3 does not have a valid v0.90 superblock, not importing! [ 3.242946] md: Scanned 6 and added 4 devices. [ 3.242985] md: autorun ... [ 3.243024] md: considering sda1 ... [ 3.243063] md: adding sda1 ... [ 3.243102] md: sda2 has different UUID to sda1 [ 3.243142] md: adding sdc1 ... [ 3.243181] md: sdc2 has different UUID to sda1 [ 3.243220] md: created md0 [ 3.243259] md: bind<sdc1> [ 3.243298] md: bind<sda1> [ 3.243337] md: running: <sda1><sdc1> [ 3.243377] md: kicking non-fresh sdc1 from array! [ 3.243944] md: unbind<sdc1> [ 3.247927] md: export_rdev(sdc1) [ 3.249110] md/raid1:md0: active with 1 out of 12 mirrors [ 3.249944] md0: detected capacity change from 0 to 2549940224 [ 3.249988] md: considering sda2 ... [ 3.250027] md: adding sda2 ... [ 3.250066] md: sdc2 has different UUID to sda2 [ 3.251287] md: created md1 [ 3.251546] md: bind<sda2> [ 3.251802] md: running: <sda2> [ 3.254118] md/raid1:md1: active with 1 out of 24 mirrors [ 3.254684] md1: detected capacity change from 0 to 2147418112 [ 3.254954] md: considering sdc2 ... [ 3.255062] md: adding sdc2 ... [ 3.255101] md: md1 already running, cannot run sdc2 [ 3.255143] md: export_rdev(sdc2) [ 3.255182] md: ... autorun DONE. Partition Version=8 /sbin/e2fsck exists, checking /dev/md0... /sbin/e2fsck -pvf returns 0 Mounting /dev/md0 /tmpRoot [ 3.381474] EXT4-fs (md0): barriers disabled [ 3.390031] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: ------------upgrade Begin upgrade procedure No upgrade file exists End upgrade procedure ============upgrade Wait 2 seconds for synology manufactory device [ 3.725047] clocksource: Switched to clocksource tsc Mon Apr 15 15:04:58 UTC 2019 /dev/md0 /tmpRoot ext4 rw,relatime,data=ordered 0 0 [ 7.503481] random: nonblocking pool is initialized none /sys/kernel/debug debugfs rw,relatime 0 0 sys /sys sysfs rw,relatime 0 0 none /dev devtmpfs rw,relatime,size=1008764k,nr_inodes=252191,mode=755 0 0 [ 7.524078] VFS: opened file in mnt_point: (/dev), file: (/ttyS1) umount: can't umount /dev: Device or resource busy proc /proc proc rw,relatime 0 0 [ 7.529589] VFS: opened file in mnt_point: (/dev), file: (/ttyS1) linuxrc.syno executed successfully. Post init mount: mounting none on /dev failed: Device or resource busy [ 7.555508] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [ 7.784802] VFS: opened file in mnt_point: (/dev), file: (/ttyS1) umount: can't umount /dev: Device or resource busy [ 7.861617] EXT4-fs (md0): re-mounted. Opts: (null) [ 8.398568] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 8.398609] sd 1:0:0:0: Attached scsi generic sg1 type 0 [ 8.398646] sd 2:0:0:0: Attached scsi generic sg2 type 0 [ 8.495758] md1: detected capacity change from 2147418112 to 0 [ 8.496515] md: md1: set sda2 to auto_remap [0] [ 8.496536] md: md1 stopped. [ 8.496557] md: unbind<sda2> [ 8.502495] md: export_rdev(sda2) [ 8.666881] md: bind<sda2> [ 8.666940] md: bind<sdc2> [ 8.668243] md/raid1:md1: not clean -- starting background reconstruction [ 8.668532] md/raid1:md1: active with 2 out of 24 mirrors [ 8.676550] md1: detected capacity change from 0 to 2147418112 [ 8.676730] md: md1: current auto_remap = 0 [ 8.676898] md: resync of RAID array md1 [ 8.677152] md1: Failed to send sync event: (sync type: resync, finish: 0, interrupt: 0) [ 8.677541] md: minimum _guaranteed_ speed: 1000 KB/sec/disk. [ 8.677751] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync. [ 8.678182] md: using 128k window, over a total of 2097088k. [ 8.845603] Adding 2097084k swap on /dev/md1. Priority:-1 extents:1 across:2097084k [ 9.147903] zram: Added device: zram0 [ 9.207625] zram0: detected capacity change from 0 to 1260388352 [ 9.209665] Adding 1230844k swap on /dev/zram0. Priority:1 extents:1 across:1230844k SS [ 9.488735] NET: Registered protocol family 10 [ 9.493694] sit: IPv6 over IPv4 tunneling driver [ 10.021693] init: syno-auth-check main process (6043) killed by TERM signal [ 10.435755] AVX2 version of gcm_enc/dec engaged. [ 10.435773] AES CTR mode by8 optimization enabled [ 10.441756] fuse init (API version 7.23) [ 10.446778] e1000e: Intel(R) PRO/1000 Network Driver - 3.4.0.2-NAPI [ 10.446803] e1000e: Copyright(c) 1999 - 2017 Intel Corporation. [ 10.449769] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.3 [ 10.449795] Copyright (c) 2007-2015 Intel Corporation. [ 10.451908] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.0.4 [ 10.452740] Copyright(c) 1999 - 2017 Intel Corporation. [ 10.453866] i40e: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.3.6 [ 10.454751] i40e: Copyright(c) 2013 - 2017 Intel Corporation. [ 10.455817] tn40xx low_mem_msg proc entry initialized [ 10.455842] tn40xx low_mem_counter proc entry initialized [ 10.455867] tn40xx debug_msg proc entry initialized [ 10.455893] tn40xx: Tehuti Network Driver, 0.3.6.12.3 [ 10.461198] Compat-mlnx-ofed backport release: c22af88 [ 10.461753] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git c22af88 [ 10.461778] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git [ 10.477762] bnx2x: QLogic 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.712.30-0 (2014/02/10) [ 10.488801] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0 [ 10.489740] ACPI: Power Button [PWRF] [ 10.494749] Linux agpgart interface v0.103 [ 10.497207] agpgart-intel 0000:00:00.0: Intel 440BX Chipset [ 10.497876] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x0 [ 10.505796] [drm] Initialized drm 1.1.0 20060810 [ 10.537958] Btrfs loaded, crc32c=crc32c-intel [ 10.539776] exFAT: Version 1.2.9 [ 10.551145] jme: JMicron JMC2XX ethernet driver version 1.0.8 [ 10.554430] sky2: driver version 1.30 [ 10.559786] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.3.63 [ 10.562522] QLogic/NetXen Network Driver v4.0.82 [ 10.564209] Solarflare NET driver v4.0 [ 10.566789] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 10.566826] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 10.568258] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de [ 10.570188] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k-NAPI [ 10.570792] vmxnet3 0000:03:00.0: # of Tx queues : 2, # of Rx queues : 2 [ 10.572074] vmxnet3 0000:03:00.0 eth0: NIC Link is Up 10000 Mbps [ 10.577335] cnic: QLogic cnicDriver v2.5.22 (July 20, 2015) [ 10.591508] usbcore: registered new interface driver ax88179_178a [ 10.596086] usbcore: registered new interface driver asix [ 10.598361] Atheros(R) L2 Ethernet Driver - version 2.2.3 [ 10.598842] Copyright (c) 2007 Atheros Corporation. [ 10.602784] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1 [ 10.604273] usbcore: registered new interface driver cx82310_eth [ 10.612370] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 10.612771] e100: Copyright(c) 1999-2006 Intel Corporation [ 10.614175] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20 [ 10.618850] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 10.626113] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 10.626784] usbcore: registered new interface driver pegasus [ 10.628121] usbcore: registered new interface driver plusb [ 10.630172] usbcore: registered new interface driver rtl8150 [ 10.634832] sis900.c: v1.08.10 Apr. 2 2006 [ 10.637167] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker [ 10.641351] usbcore: registered new interface driver r8152 [ 10.645195] vxge: Copyright(c) 2002-2010 Exar Corp. [ 10.645773] vxge: Driver version: 2.5.3.22640-k [ 12.108738] systemd-udevd[7169]: starting version 204 [ 26.245853] md: md1: resync done. [ 26.246916] md1: Failed to send sync event: (sync type: resync, finish: 1, interrupt: 0) [ 26.248022] md: md1: current auto_remap = 0 [ 26.258551] RAID1 conf printout: [ 26.259003] --- wd:2 rd:24 [ 26.259390] disk 0, wo:0, o:1, dev:sda2 [ 26.259951] disk 1, wo:0, o:1, dev:sdc2 Quote
