turuncuoglu Posted June 22, 2016 Share #1 Posted June 22, 2016 My system updated to DSM 6 by itself and I had to downgrade it to DSM 5.2 after the downgrade it is working but when I go to the web interface I can not see the check boxes. I can not see the close and minimize bottoms as well. I tried to attach a file but the board attachment quota has been reached. Any help would be appreciated. Thanks T Link to comment Share on other sites More sharing options...
AllGamer Posted June 22, 2016 Share #2 Posted June 22, 2016 if you are using IE, try with Firefox, Opera, or Chrome. it's more than likely the IE cache playing tricks on you, by default IE never updates the cache properly. if all the other browsers have the same problem, then you'll probably need to re-install DSM 5.2 once again. Link to comment Share on other sites More sharing options...
