My system updated to DSM 6 by itself and I had to downgrade it to DSM 5.2 after the downgrade it is working but when I go to the web interface I can not see the check boxes. I can not see the close and minimize bottoms as well.
I tried to attach a file but the board attachment quota has been reached.
Any help would be appreciated. Thanks
T
if you are using IE, try with Firefox, Opera, or Chrome.
it's more than likely the IE cache playing tricks on you, by default IE never updates the cache properly.
if all the other browsers have the same problem, then you'll probably need to re-install DSM 5.2 once again.
