kennyb Posted August 10, 2013 Share #1 Posted August 10, 2013 Hi, I had a synology DS212+ but after using it a while i wanted something more powerfull and be able to run other VM's on the same machine. As synology does not support runnung VM's on a DS, I assembled a power effecient machine myself: - Gigabyte GA Z87-D3HP - Intel i5 4570S - Crucial Ballistix Sport 2x8GB DDR3 1600 C9 LowP - Seasonic 400W PSU P-400 Fanless PLATINUM - Fractal Design Node 605 I installed Windows Server 2008 R2 on this machine. Now the next step is to run a VM with DSM on it. I would like to use VMware Workstation because I have a full icense for this but I've read this will not be possible or easy. I'm willing to run this in VirtualBox or something else if necessary. The 2 2TB disks I have come straight out of my old DS so everything is stil on the disks. The disks were in synology SHR (mirror). I would like to know the following things: - Is it possible to start a VM, passthrough the disks and run the VM so I don't have to install DSM and keeping all my files? - I don't think the above will be easy.. So the main goal is to run a VM with DSM but run everything on the 2 physical 2TB disks in mirror. - Do I have to set up the mirror on machine itself or is a passthrough of the 2 disks to the VM sufficient so DSM will set up the mirror. - What virtualization soft would you recommend? VirtualBox, VMware, ... - Is there a good manual for the things I want to do? Thanks in advance, Kenny Link to comment Share on other sites More sharing options...
