rebuild firmware with a patched kernel
I'm looking for a way to rebuild the official Synology firmware by including the bcache patch to the kernel and the tools to the firmware.
As I'm new to all this, all help would be appreciated!
I have a NAS which I can use to test the packages but is it ok to flash? Is the recovery easy?
For the kernel, I'm going to use the sources provided by Synology and apply the patch. Is there something else I should check?
Thanks!
