I have Xpenlogy 7.2 on a ESXI server, using ARC loader. I noticed that after a power outage, the volume in DSM7 is crashed, although both disks are fine. I inserted two more disk and created a second volume... it does the same thing. After each reboot, both volumes are crashed, although the disks are perfectly fine. After reboot, the system is stuck in "system is getting ready". I log in in to ssh and run these commands:
sudo synobootseq --set-boot-done
sudo synobootseq --is-ready
I can then login, check the storage manager and see both volumes crashed. Then I give this command:
sudo mount -v /dev/mapper/cachedev_0 /volume1
And the data is back online. After power outage and reboot, same thing 😐
hans112
0 answers to this question
