Help needed getting Adaptec 72405 (24 port card) working on DS3622xs+ (what SataPortMap & DiskIdxMap values)
DarkBlade
I can get a basic build working following the tutorial here wundertech.net  how-to-install-xpenology-on-proxmox-dsm-7
This gets DSM running on the Proxmox storage drive.
I'm now trying to rebuild (from scratch), passing an Adaptec 72405 (24 port card set to HBA mode) through - hoping that DSM will still install on the VM drive and the disks on the Adaptec card are then seen as additional storage (to create storage pools etc). I only need/want to use (the first) 20 ports on the card (the remaining 4 ports are not connected to any drives or backplane).
When booting into Redpill and DSM:
  • DSM fails to spot the 20G VM disk
  • The drives on the Adaptec card start from slot 3
  • Only 14 of the 15 drives I currently have installed are picked up.
My initial attempts at changing the SataPortMap, DiskIdxMap and MaxDisks values has resulted in no disks showing, or crashing the Adaptec card. (requiring a complete power down to recover on one occasion).  I've had a few other issues which I think I have now resolved.
My ask is:
How can I get the build working using the VM sata1 drive?
What values should I try for SataPortMap, DiskIdxMap and MaxDisks?
This is the hardware setup in Proxmox
This is the satamap output (I manually set maxdisks to 24 in user_config before running satamap)
Spoiler
tc@box:~$ ./rploader.sh satamap now
Machine is VIRTUAL Hypervisor=KVM
Found SCSI HBAs, We need to install the SCSI modules
scsi-5.10.3-tinycore64 is already installed!
Succesfully installed SCSI modules
Found "00:1f.2 Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)"
Detected 6 ports/0 drives. Mapping KVM q35 bogus controller after maxdisks
Found "06:07.0 Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)"
Detected 6 ports/2 drives. Mapping SATABOOT drive after maxdisks
WARNING: Other drives are connected that will not be accessible!
Found SCSI/HBA "01:00.0 Adaptec Series 7 6G SAS/PCIe 3 (rev 01)" (15 drives)
lspci: -s: Invalid slot number
Found SCSI/HBA "" (0 drives)
lspci: -s: Invalid bus number
Found SCSI/HBA "06:07.0 Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)" (8 drives)
Found SCSI/HBA "05:03.0 Red Hat, Inc. QEMU PCI-PCI bridge 06:03.0 Red Hat, Inc Virtio memory balloon" (81 drives)
Computed settings:
SataPortMap=11
DiskIdxMap=1818
Edited by DarkBlade
