Proxmox with Mellanox ConnectX-3 Pro PCI passthrough not working with Redpill (but visible in TinyCore)
DarkBlade
I've installed a Mellanox ConnectX-3 Pro MCX312B-XCCS Dual Port card in my Proxmox machine, but I'm having no luck with the card when running redpill with DS3622xs+ (which I need to use as I will be passing through a RAID card once I've got the Mellanox card working).
I can see the 10Gbe card passed through into TinyCore, where I get two IP addresses for each NIC port. (No virtual NICs are
setup in the Virtual Machine)
I then execute the following commands:
./rploader.sh update now
./rploader.sh fullupgrade now
./rploader.sh serialgen DS3622xs+
./rploader.sh satamap now
./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-virtio/rpext-index.json
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/dodo-dk/rp-ext/main/acpid/rpext-index.json
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/v9fs/rpext-index.json
./rploader.sh build broadwellnk-7.1.0-42661
But when running Redpill, it fails to allocate either eth0 or eth1 addresses. Is there a way to pause the serial output (there is no obvious error in the tail end of the output), or read the complete logs somewhere?
Do I need to add an additional driver? (I assumed these cards were supported without needing drivers)
(I've managed to get a build working using a Proxmox virtualised e1000 NIC)
I've tried a build adding a virtual NIC (Intel E1000) alongside the Mellanox card.
This allowed installing of DSM, but on reboot, the DSM shuts down the VM. (I believe this might be caused by the DS3622xs+ build only allowing two NICs)
Spoiler
Tail of serial output...
[  OK  ] Reached target Synology local user and group ready.
[  OK  ] Reached target Synology synoscheduler functions.
[  OK  ] Reached target User and Group Name Lookups.
         Starting move domain or ldap user p...der to domain or ldap folder....
[  OK  ] Started Apply kernel variable kernel-shmmni at least 16384.
[  OK  ] Started Apply kernel variable vm.kswapd_threads.
[  OK  ] Started move domain or ldap user pr...older to domain or ldap folder..
[  OK  ] Started Apply kernel variable kernel.sem at least 1024.
[  OK  ] Started Apply kernel variable vm.min-free-kbytes.
[  OK  ] Started System Logger Daemon.
         Starting synodrnode...
[DEPEND] Dependency failed for rebuild local user and group db.
[  OK  ] Reached target Synology root filesystem (rw) ready.
         Starting Clean UPS config...
         Starting Load AppArmor profiles...
         Starting Synology Default TLS Profile...
         Starting Umount initrd...
         Starting SAS early initial...
         Starting DSM Boot Health Check...
         Starting Synology check locale...
         Starting syno-cgi-keygen.service...
         Starting Set Eunit Sequence...
         Starting DSM Installation ID...
[  OK  ] Reached target Network (Pre).
         Starting Set arp ignore...
         Starting Synology Network Daemon...
         Starting Synology Log bootup start...
[  OK  ] Started Clean UPS config.
[  OK  ] Started DSM Installation ID.
[  OK  ] Started Synology check locale.
[  OK  ] Started Set Eunit Sequence.
[  OK  ] Started Set arp ignore.
[  OK  ] Started SAS early initial.
         Starting Synology swap...
[  OK  ] Started Umount initrd.
[  OK  ] Started Synology Log bootup start.
[  OK  ] Started Synology Network Daemon.
         Starting Wait for Synology Network to be Configured...
         Starting rc.network...
[  OK  ] Started syno-cgi-keygen.service.
[   23.347083] zram: Added device: zram0
[   23.347697] zram: Added device: zram1
[   23.348277] zram: Added device: zram2
[   23.348828] zram: Added device: zram3
[   23.349449] zram: Added device: zram4
[   23.350055] zram: Added device: zram5
[  OK  ] Started DSM Boot Health Check.
[   23.456406] md: md1 stopped.
[   23.457461] md: bind<sdb2>
[   23.458361] md/raid1:md1: active with 1 out of 16 mirrors
[   23.460169] md1: detected capacity change from 0 to 2147418112
[  OK  ] Started Load AppArmor profiles.
[  OK  ] Started Synology Default TLS Profile.
[  OK  ] Started synodrnode.
[   23.528621] Adding 2097084k swap on /dev/md1.  Priority:-1 extents:1 across:2097084k
[   23.531195] zram0: detected capacity change from 0 to 1677721600
[   23.533650] Adding 1638396k swap on /dev/zram0.  Priority:1 extents:1 across:1638396k SS
[   23.535656] zram1: detected capacity change from 0 to 1677721600
[   23.537837] Adding 1638396k swap on /dev/zram1.  Priority:1 extents:1 across:1638396k SS
[   23.539652] zram2: detected capacity change from 0 to 1677721600
[   23.541927] Adding 1638396k swap on /dev/zram2.  Priority:1 extents:1 across:1638396k SS
[   23.543649] zram3: detected capacity change from 0 to 1677721600
[   23.545863] Adding 1638396k swap on /dev/zram3.  Priority:1 extents:1 across:1638396k SS
[   23.547527] zram4: detected capacity change from 0 to 1677721600
[   23.549698] Adding 1638396k swap on /dev/zram4.  Priority:1 extents:1 across:1638396k SS
[   23.551325] zram5: detected capacity change from 0 to 1677721600
[   23.553645] Adding 1638396k swap on /dev/zram5.  Priority:1 extents:1 across:1638396k SS
[  OK  ] Started Synology swap.
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Reached target System Initialization.
         Starting bootup upgrade sha package...
[  OK  ] Started Serial Getty on ttyS0.
         Starting Serial Getty on ttyS0...
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Synology token manager.
         Starting Synology token manager...
[  OK  ] Started Synology task manager.
         Starting Synology task manager...
[  OK  ] Started bootup upgrade sha package.
[  OK  ] Found device /dev/synoboot2.
[  OK  ] Reached target Synology synoboot2 done.
[  OK  ] Reached target Basic System.
[   23.725240] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
         Starting synoconfd daemon...
         Starting Synology Schedule Daemon...
         Starting Synology filesytem check on bootup...
         Starting Service for irq balance...
         Starting WD idle3 timer...
         Starting Login Service...
         Starting Synology firmware DLMC...
[  OK  ] Started Synology log accounting service.
         Starting Synology log accounting service...
         Starting always preprocess jobs before any package is started...
         Starting Samba Environment Setup Unit...
         Starting System Profile Tuning...
         Starting Hibernation debug check...
         Starting synoindex check if there a...ny synoindex-related packages...
[  OK  ] Started synobackup daemon.
         Starting synobackup daemon...
         Starting Log Rotate Daemon...
         Starting Write back disk latency to DB...
         Starting Synology log notification service...
         Starting Control RC power...
[  OK  ] Started Synology filesytem check on bootup.
[  OK  ] Started WD idle3 timer.
[  OK  ] Started Synology firmware DLMC.
[  OK  ] Started Write back disk latency to DB.
         Starting Synology space service...
[  OK  ] Started Login Service.
[  OK  ] Started Hibernation debug check.
[  OK  ] Started synoconfd daemon.
[  OK  ] Started Synology Schedule Daemon.
[  OK  ] Started Control RC power.
[  OK  ] Started Log Rotate Daemon.
[  OK  ] Stopped Synology Task Scheduler Vmtouch.
[  OK  ] Started Synology Task Scheduler Vmtouch.
         Starting Synology Task Scheduler Vmtouch...
[   23.833051] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   23.834252] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Service for irq balance.
[  OK  ] Started always preprocess jobs before any package is started.
[  OK  ] Reached target Hook on root ready.
         Starting ActiveInsight's service unit...
         Starting Python2's service unit...
         Starting BackupRestoreManager's service unit...
         Starting SecureSignIn's service unit...
         Starting SMBService's service unit...
[FAILED] Failed to start synoindex check if ... any synoindex-related packages.
See "systemctl status synoindex-checkpackage.service" for details.
[DEPEND] Dependency failed for synomkthumbd.
[DEPEND] Dependency failed for synoindex workerd.
[DEPEND] Dependency failed for synoindex scand.
[DEPEND] Dependency failed for synoindex notifyd.
[DEPEND] Dependency failed for synoindexd.
[DEPEND] Dependency failed for synoindex plugind.
[DEPEND] Dependency failed for synoindex mediad.
[DEPEND] Dependency failed for synomkflvd.
[   23.865132] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started System Profile Tuning.
         Starting DHCP client init...
[  OK  ] Created slice system-dhclient.slice.
[   23.888043] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started DHCP client init.
         Starting eth0 DHCP Client...
[   23.910157] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Samba Environment Setup Unit.
[  OK  ] Started eth0 DHCP Client.
[  OK  ] Started rc.network.
         Starting Set Multiple Geteway...
         Starting Check if network is ready...
         Starting PPPoE...
[  OK  ] Started PPPoE.
[   24.001129] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.014442] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.025225] <redpill/smart_shim.c:646> Got SMART *command* - looking for feature=0xd5
[   24.026382] <redpill/smart_shim.c:516> Generating fake WIN_SMART log=0 entries
[   24.027950] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.034444] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.037978] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.039998] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.041546] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.056049] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.073234] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Set Multiple Geteway.
[  OK  ] Reached target Network.
         Starting Out of Band Management Status Check...
         Starting Network Time Service...
         Starting Redis data structure server for webapi...
         Starting Synology SCGI SocketIO...
         Starting findhost daemon...
         Starting ACPI Daemon...
[  OK  ] Started Synology log notification service.
[  OK  ] Started ACPI Daemon.
[  OK  ] Started findhost daemon.
[  OK  ] Started Network Time Service.
[   24.160328] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Redis data structure server for webapi.
[  OK  ] Started Synology SCGI.
         Starting Synology SCGI...
[  OK  ] Started Python2's service unit.
[  OK  ] Started Wait for Synology Network to be Configured.
         Starting Synology Network Event Daemon...
[  OK  ] Started Synology Network Event Daemon.
[  OK  ] Started Synology space service.
         Starting Synology virtual space service...
[  OK  ] Started Synology virtual space service.
         Starting Synology virtual space service phase2...
[  OK  ] Started Synology virtual space service phase2.
[  OK  ] Reached target Synology storage pool.
         Starting Synology filesystem check service...
         Starting Check Synology HotSpare Config...
         Starting Synology Building Tasks Restore for Storage Manager...
[  OK  ] Started SMBService's service unit.
[  OK  ] Started Synology filesystem check service.
         Starting Synology volume service...
         Stopping eth0 DHCP Client...
[  OK  ] Stopped eth0 DHCP Client.
[  OK  ] Started Synology Building Tasks Restore for Storage Manager.
[  OK  ] Started Check Synology HotSpare Config.
[  OK  ] Started Synology volume service.
         Starting Synology volume mount post hook...
[  OK  ] Started Synology volume mount post hook.
[  OK  ] Reached target Synology data volumes.
         Starting Keep var services homes existing...
         Starting Synology task resume for Storage Manager...
         Starting Syno Data Protection - Btrfs Snapshot Meta Sync...
         Starting Build-in PHP timezone updater...
         Starting Syno Data Protection - Btrfs Snaptree reconstruct...
         Starting daemon for monitor HW/system status...
         Starting Syno Data Protection - Btrfs Snapshot Count Sync...
         Starting SSD Cache Pin File Daemon...
         Starting daemon for monitor logs and generate alert...
         Starting Synology Database Update...
         Starting Prepare var service tmp...
         Starting move user preference folder to volume....
[  OK  ] Started SNMP Daemon.
         Starting SNMP Daemon...
         Starting Daemon for Resource Monitor...
         Starting Synology Cache Advisor Service...
         Starting Synology Cron Daemon...
         Starting Load Bypass Traverse Checking...
         Starting Check Synology shared folders...
         Starting Syno Data Protection - Btrfs Deleted Subvolume Clean...
         Starting Syno Data Protection - Btrfs Snapshot Usage Task Clean...
[  OK  ] Started SecureSignIn's service unit.
[  OK  ] Started Keep var services homes existing.
[  OK  ] Started Syno Data Protection - Btrfs Snapshot Count Sync.
[  OK  ] Started Syno Data Protection - Btrfs Deleted Subvolume Clean.
[  OK  ] Started Syno Data Protection - Btrfs Snaptree reconstruct.
[  OK  ] Started Synology Database Update.
[  OK  ] Started Syno Data Protection - Btrfs Snapshot Meta Sync.
[  OK  ] Started SSD Cache Pin File Daemon.
[  OK  ] Started Synology task resume for Storage Manager.
         Starting Synology daemon for monitoring space/disk/cache status...
[  OK  ] Started Load Bypass Traverse Checking.
[  OK  ] Started Daemon for Resource Monitor.
         Starting Daemon of performance alarm...
[  OK  ] Started Syno Data Protection - Btrfs Snapshot Usage Task Clean.
[  OK  ] Started Synology daemon for monitoring space/disk/cache status.
         Starting Sync data scrubbing config...
[   24.792318] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started daemon for monitor logs and generate alert.
[  OK  ] Started Build-in PHP timezone updater.
[   24.812777] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started ActiveInsight's service unit.
[   24.826579] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
         Stopping Synology Task Scheduler Vmtouch...
[   24.838078] <redpill/smart_shim.c:646> Got SMART *command* - looking for feature=0xd5
[   24.839219] <redpill/smart_shim.c:516> Generating fake WIN_SMART log=0 entries
[   24.840054] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.840776] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.841243] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Prepare var service tmp.
         Starting Nginx...
[   24.854812] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.867931] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   24.869659] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Synology Cron Daemon.
[  OK  ] Started Daemon of performance alarm.
[  OK  ] Started Synology Cache Advisor Service.
[  OK  ] Started move user preference folder to volume..
[  OK  ] Started Sync data scrubbing config.
[  OK  ] Started Check Synology shared folders.
         Starting Check share snapshot...
         Starting Migrate all volume and share to quota DB...
[  OK  ] Started Migrate all volume and share to quota DB.
[  OK  ] Started Check share snapshot.
[  OK  ] Reached target Synology shared folders.
         Starting Remove session if the option enabled....
         Starting Build DB link for synolog...
         Starting Daemon for Recycle Bin...
         Starting synotifyd...
         Starting Shared Folder Sync Daemon...
         Starting Accountdb cache database...
         Starting daemon for handle hotplug event...
[  OK  ] Started Daemon for Recycle Bin.
[  OK  ] Started Remove session if the option enabled..
         Starting Synology CGI Auth Daemon...
[  OK  ] Started synotifyd.
[  OK  ] Started Build DB link for synolog.
[  OK  ] Started Synology CGI Auth Daemon.
[  OK  ] Started Accountdb cache database.
[  OK  ] Started daemon for handle hotplug event.
[  OK  ] Started Shared Folder Sync Daemon.
[   25.321910] capability: warning: `nginx' uses 32-bit capabilities (legacy support in use)
[  OK  ] Started Nginx.
         Starting SSDP service...
         Starting ActiveBackup Daemon for DSM...
[  OK  ] Started SSDP service.
[  OK  ] Started ActiveBackup Daemon for DSM.
[  OK  ] Started BackupRestoreManager's service unit.
[   26.192280] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   26.193671] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   26.195654] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   26.197081] ata7.00: configured for UDMA/100
[   26.197695] ata7: EH complete
[   26.199111] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   26.218747] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   26.220292] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Check if network is ready.
[  OK  ] Reached target Network is Online.
         Starting NetBIOS name server...
         Starting Avahi daemon...
         Starting deal with remote/ISO mount during when bootup and poweroff...
         Starting register ds region by ip...
         Starting broadcast synorelayd boot state...
         Starting Entry for WS-Transfer and WS-Discovery Server...
         Starting ScsiTarget's service unit...
         Starting Set IP Conflict Detect...
         Starting VPN Client...
[FAILED] Failed to start Out of Band Management Status Check.
See "systemctl status syno-oob-check-status.service" for details.
[  OK  ] Started Entry for WS-Transfer and WS-Discovery Server.
[  OK  ] Started deal with remote/ISO mount during when bootup and poweroff.
[  OK  ] Started Set IP Conflict Detect.
[  OK  ] Started VPN Client.
[  OK  ] Started Avahi daemon.
[  OK  ] Started NetBIOS name server.
[  OK  ] Started WS-Discovery Server.
         Starting WS-Discovery Server...
         Starting Samba SMB Daemon...
         Starting WS-Transfer Server...
[  OK  ] Started broadcast synorelayd boot state.
[  OK  ] Started WS-Transfer Server.
[  OK  ] Started Samba SMB Daemon.
[  OK  ] Reached target Packed In File Protocols.
         Starting iSCSI Service...
[   26.971671] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_init RODSP server started, login_key(d4902068d1d8).
[   26.984592] iSCSI:extent_pool.c:766:ep_init syno_extent_pool successfully initialized
[   26.991552] iSCSI:target_core_device.c:613:se_dev_align_max_sectors Rounding down aligned max_sectors from 4294967295 to 4294967288
[   26.993033] iSCSI:target_core_configfs.c:5777:target_init_dbroot db_root: cannot open: /etc/target
[   26.994177] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[   27.011699] iSCSI:target_core_file.c:152:fd_attach_hba RODSP plugin for fileio is enabled.
[   27.012764] iSCSI:target_core_file.c:159:fd_attach_hba ODX Token Manager is enabled.
[   27.013741] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[   27.014855] iSCSI:target_core_ep.c:795:ep_attach_hba RODSP plugin for epio is enabled.
[   27.015807] iSCSI:target_core_ep.c:802:ep_attach_hba ODX Token Manager is enabled.
[   27.072038] workqueue: max_active 1024 requested for vhost_scsi is out of range, clamping between 1 and 512
[   27.188399] iSCSI:qla_dbg.c:2605:ql_log qla2xxx [0000:00:00.0]-0005: : QLogic Fibre Channel HBA Driver: 8.07.00.38-k.
[   27.199247] [10977]: ocs_fc_lio: ocs_scsi_ini_driver_init:1104::disabling the app heartbeat timeout detection
[   27.200566] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1225::ocs_fc_lio: driver version 12.2.385.0
[   27.201843] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1227::  Module parameters:
[   27.202917] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1228::  Initiator = 0
[   27.203932] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1229::  Target = 1
[   27.204913] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1230::  ctrlmask = 0x000a
[   27.205980] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1231::  loglevel = 5
[   27.207089] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1232::  logmask = 0x0000
[   27.208191] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1233::  ramlog_size = 1048576
[   27.209325] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1234::  rq_threads = 0
[   27.210338] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1235::  wwn_bump = 0
[   27.211295] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1236::  topology = 0
[   27.212249] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1237::  speed = 0
[   27.213150] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1238::  holdoff_link_online = 2
[   27.214195] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1239::  enable_hlm = 0
[   27.215148] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1240::  hlm_group_size = 8
[   27.216140] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1241::  max_remote_nodes = 2048
[   27.217181] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1242::  ethernet_license = 0
[   27.218196] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1243::  num_scsi_ios = 8192
[   27.219196] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1244::  dif_separate = 0
[   27.220167] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1245::  tow_feature = 0
[   27.221125] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1246::  tow_io_size = 65536
[   27.222137] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1247::  tow_xri_cnt = 512
[   27.223121] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1248::  queue_topology = eq cq rq cq mq $nulp($nwq(cq wq:ulp=$rpt1)) cq wq:len=256:class=1
[   27.224762] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1249::  rq_selection_policy = 0
[   27.225807] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1250::  rr_quanta = 1
[   27.226749] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1251::  filter_ref = 0,0,0,0
[   27.227761] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1252::  cq_process_limit = 64
[   27.228783] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1253::  explicit_buffer_list = 0
[   27.229836] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1254::  external_loopback = 0
[   27.230856] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1255::  target_io_timer = 0
[   27.231855] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1256::  target_wqe_timer = 30
[   27.232876] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1257::  ddump_saved_size = 0
[   27.233888] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1258::  hal_war_version = (null)
[   27.234939] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1259::  hw_cmpl_context = 1
[   27.235942] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1260::  watchdog_timeout = 0
[   27.236950] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1261::  heartbeat_cpu_mask = 0x0
[   27.238008] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1262::  sliport_healthcheck = 0
[   27.239047] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1263::  disable_fec = 0
[   27.239996] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1264::  enable_dpp = 1
[   27.240941] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1265::  sliport_pause_errors = disabled
[   27.242064] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1266::  enable_bbcr = 1
[   27.243023] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1267::  fw_dump_type = 1
[   27.243983] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1268::  enable_auto_recovery = 0
[   27.245028] [10977]: ocs_fc_lio: ocs_driver_print_module_params:1269::  cfg_suppress_rsp = 1
[   27.246077] [10978]: ocs_fc_lio: ocs_thread_thunk:1046::ocs_proxy running
[  OK  ] Started iSCSI Service.
[  OK  ] Started SCSI Target Monitor.
         Starting SCSI Target Monitor...
[  OK  ] Started Synology Storage Console Server.
         Starting Synology Storage Console Server...
[  OK  ] Started Synology SCGI SocketIO.
[  OK  ] Started ScsiTarget's service unit.
[  OK  ] Reached target High priority packages start up done.
         Starting synodrnode_reset...
[  OK  ] Started synodrnode_reset.
[  OK  ] Reached target Multi-User System.
         Starting Synology Cache Advisor Boot Clean Up...
         Starting Customized post-install configuration...
[  OK  ] Started Preload synopki data to cache.
         Starting Preload synopki data to cache...
         Starting Execute packages' scripts during the boot-up...
         Starting Support channel checker...
[  OK  ] Started Synology Get EW Info Status.
         Starting Synology Get EW Info Status...
         Starting Synology Event-based Task Scheduler Bootup Trigger...
         Starting Before upgrade ready...
         Starting Periodic Command Scheduler...
         Starting Check if DS has a connected printer. If so, enable cups....
         Starting Get expansion host wide port count...
         Starting Check malware and execute rc.local...
         Starting Synology Web console login prepare...
         Starting Update all disks firmware status...
         Starting Check normal shutdown or improper shutdown...
         Starting Initial Disk Health Database...
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started Check malware and execute rc.local.
[  OK  ] Started Synology Web console login prepare.
[  OK  ] Started Get expansion host wide port count.
[  OK  ] Started Customized post-install configuration.
[  OK  ] Started Check normal shutdown or improper shutdown.
[  OK  ] Started Check if DS has a connected printer. If so, enable cups..
[   27.353924] ext2: synoboot2 mounted, process=synopkicompatsy
[  OK  ] Started Update all disks firmware status.
[  OK  ] Started Initial Disk Health Database.
[  OK  ] Started Synology Cache Advisor Boot Clean Up.
[  OK  ] Started Execute packages' scripts during the boot-up.
[   27.404249] vfat: synoboot2 mounted, process=synopkicompatsy
[   27.409844] synoboot2 unmounted, process=synopkicompatsy
[   27.432664] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Support channel checker.
[  OK  ] Started Synology Event-based Task Scheduler Bootup Trigger.
[  OK  ] Started Before upgrade ready.
[  OK  ] Reached target Synology Web console login available.
         Starting OAuthService's service unit...
         Starting Synology Set bootseq to boot done...
         Starting FileStation's service unit...
         Starting SynoFinder's service unit...
[  OK  ] Reached target Synology bootup done.
         Starting Schedule smart db update...
         Starting Syno ssd cache bootup missing check...
         Starting To send disable push mail and send notify...
         Starting Fan debug check...
         Starting syno-mkdhparam.service...
         Starting Auto scrubbing - Auto data...ata scrubbing after fsck done...
         Starting Reassemble Pstore log into /var/log/pstore/...
         Starting Information dump of SAS disk map and cache slot...
         Starting synobrm recovery restart after partition change...
         Starting Synology Dump Bootup Log...
         Starting PostgreSQL adapter...
         Starting Log important service timestamp during boot time...
         Starting Synology Database Update Daemon...
         Starting Check the disk is ssd/hdd...
         Starting Synology daemon for monitoring disk latency....
         Starting Memory Rule Check...
         Starting Syno Raid Feature Adjust Serialize Policy...
         Starting Update all disk information in disk log...
         Starting Dump synoplatform info...
         Starting Check synorbd on system volume...
         Starting Single Memory Channel Action...
         Starting Synology Bundle SSD estima...ifespan calculation on bootup...
         Starting Restart UPS Daemon after boot done...
         Starting set NOATIME flag on /var/run when bootup...
         Starting Check and add schedule scan for Security Advisor...
         Starting Fix bind mount explosion problem...
         Starting HybridShare's service unit...
[  OK  ] Started Synology Set bootseq to boot done.
[  OK  ] Started Synology Dump Bootup Log.
[  OK  ] Started Syno Raid Feature Adjust Serialize Policy.
         Starting Notify bundle drive update after bootup done...
         Starting Sync disk and related smart scheduler....
         Starting Notify system partition error happened...
         Starting Notify system is detected for unsupported drive...
         Starting Run data scrubbing schedule after bootup done...
         Starting Synology Available Pool Scan for Storage Manager...
         Starting Notify data volume has been repaired by drop log tree....
         Starting Adjust md resync speed after bootup done...
         Starting Check disk compatiblity....
         Starting Notification for firmware upgrade result...
         Starting Synology space table update for Storage Manager...
         Starting Check Synology HotSpare Config for Disk Compat...
[  OK  ] Started Schedule smart db update.
[  OK  ] Started To send disable push mail and send notify.
[  OK  ] Started Single Memory Channel Action.
[  OK  ] Started Notify system partition error happened.
[  OK  ] Started set NOATIME flag on /var/run when bootup.
[   27.544985] <redpill/intercept_execve.c:82> Blocked /usr/syno/bin/syno_pstore_collect from running
[  OK  ] Started Reassemble Pstore log into /var/log/pstore/.
[  OK  ] Started Memory Rule Check.
[  OK  ] Started Synology Database Update Daemon.
[  OK  ] Started Auto scrubbing - Auto data ... data scrubbing after fsck done.
[  OK  ] Started Adjust md resync speed after bootup done.
[  OK  ] Started Update all disk information in disk log.
[  OK  ] Started Run data scrubbing schedule after bootup done.
[  OK  ] Started Notify data volume has been repaired by drop log tree..
[  OK  ] Started Synology Bundle SSD estimate lifespan calculation on bootup.
[   27.563240] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Fan debug check.
[  OK  ] Started Notify bundle drive update after bootup done.
[  OK  ] Started Sync disk and related smart scheduler..
[   27.575197] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Check the disk is ssd/hdd.
[  OK  ] Started Synology daemon for monitoring disk latency..
[  OK  ] Started Syno ssd cache bootup missing check.
[  OK  ] Started Notification for firmware upgrade result.
[  OK  ] Started Check Synology HotSpare Config for Disk Compat.
[  OK  ] Started Notify system is detected for unsupported drive.
[  OK  ] Started Check disk compatiblity..
[  OK  ] Started Restart UPS Daemon after boot done.
[  OK  ] Started Dump synoplatform info.
[  OK  ] Started Check synorbd on system volume.
[   27.649595] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started Synology Available Pool Scan for Storage Manager.
[  OK  ] Started Information dump of SAS disk map and cache slot.
[  OK  ] Started Log important service timestamp during boot time.
[FAILED] Failed to start PostgreSQL adapter.
See "systemctl status pgsql-adapter.service" for details.
[DEPEND] Dependency failed for PostgreSQL adapter target.
[DEPEND] Dependency failed for check mediaserver database is needed to upgrade.
[DEPEND] Dependency failed for check synoindex database is needed to upgrade.
[  OK  ] Started synobrm recovery restart after partition change.
[   27.784741] 8021q: 802.1Q VLAN Support v1.8
[   27.785332] 8021q: adding VLAN 0 to HW filter on device eth0
[   27.835497] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[  OK  ] Started daemon for monitor HW/system status.
         Starting Synology Log bootup done...
         Starting Synology shutdown task...
[  OK  ] Started Synology shutdown task.
[  OK  ] Started Synology Log bootup done.
[  OK  ] Started Fix bind mount explosion problem.
[  OK  ] Started Check and add schedule scan for Security Advisor.
[  OK  ] Started Synology space table update for Storage Manager.
         Starting Notify all idle drives after bootup done...
[  OK  ] Started OAuthService's service unit.
[  OK  ] Started Notify all idle drives after bootup done.
Sat Dec 31 07:35:06 2022
SynologyNAS login: [   30.046559] fuse init (API version 7.23)
[  OK  ] Stopped Update all disks firmware status.
         Stopping Update all disks firmware status...
[  OK  ] Stopped Notification for firmware upgrade result.
         Stopping Notification for firmware upgrade result...
         Stopping Synology shutdown task...
[  OK  ] Stopped Synology Event-based Task Scheduler Bootup Trigger.
         Stopping Synology Event-based Task Scheduler Bootup Trigger...
[  OK  ] Stopped Synology Database Update.
         Stopping Synology Database Update...
         Stopping Service for irq balance...
[  OK  ] Stopped register ds region by ip.
         Stopping register ds region by ip...
         Stopping Synology daemon for monitoring disk latency....
[  OK  ] Stopped Syno Raid Feature Adjust Serialize Policy.
         Stopping Syno Raid Feature Adjust Serialize Policy...
[  OK  ] Removed slice Synology Cache Advisor.
         Stopping ActiveBackup Daemon for DSM...
[  OK  ] Stopped target Timers.
         Stopping Synology Network Event Daemon...
[  OK  ] Stopped Check disk compatiblity..
         Stopping Check disk compatiblity....
[  OK  ] Stopped Check the disk is ssd/hdd.
         Stopping Check the disk is ssd/hdd...
[  OK  ] Stopped Build DB link for synolog.
         Stopping Build DB link for synolog...
         Stopping Write back disk latency to DB...
[  OK  ] Stopped Syno Data Protection - Btrfs Snapshot Meta Sync.
         Stopping Syno Data Protection - Btrfs Snapshot Meta Sync...
[  OK  ] Stopped synorelay daemon reloads package configuration.
[  OK  ] Stopped Notify data volume has been repaired by drop log tree..
         Stopping Notify data volume has been repaired by drop log tree....
         Stopping VPN Client...
[  OK  ] Stopped Syno Data Protection - Btrfs Snaptree reconstruct.
         Stopping Syno Data Protection - Btrfs Snaptree reconstruct...
         Stopping Set IP Conflict Detect...
[  OK  ] Stopped Execute packages' scripts during the boot-up.
         Stopping Execute packages' scripts during the boot-up...
[  OK  ] Stopped Sync disk and related smart scheduler..
         Stopping Sync disk and related smart scheduler....
[  OK  ] Stopped Schedule smart db update.
         Stopping Schedule smart db update...
[  OK  ] Stopped Preload synopki data to cache.
         Stopping Preload synopki data to cache...
[  OK  ] Stopped target Login Prompts.
[  OK  ] Stopped broadcast synorelayd boot state.
         Stopping broadcast synorelayd boot state...
[  OK  ] Stopped Update all disk information in disk log.
         Stopping Update all disk information in disk log...
[  OK  ] Stopped Synology Dump Bootup Log.
         Stopping Synology Dump Bootup Log...
[  OK  ] Stopped Dump synoplatform info.
         Stopping Dump synoplatform info...
         Stopping WS-Discovery Server...
[  OK  ] Stopped Fan debug check.
         Stopping Fan debug check...
[  OK  ] Stopped Syno Data Protection - Btrfs Snapshot Count Sync.
         Stopping Syno Data Protection - Btrfs Snapshot Count Sync...
         Starting Remove SAS firmware update fail list...
[  OK  ] Stopped Support channel checker.
         Stopping Support channel checker...
[  OK  ] Stopped Check Synology HotSpare Config for Disk Compat.
         Stopping Check Synology HotSpare Config for Disk Compat...
[  OK  ] Stopped Set arp ignore.
         Stopping Set arp ignore...
[  OK  ] Stopped Notify all idle drives after bootup done.
         Stopping Notify all idle drives after bootup done...
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Stopped Check synorbd on system volume.
         Stopping Check synorbd on system volume...
[  OK  ] Stopped Synology Get EW Info Status.
         Stopping Synology Get EW Info Status...
[  OK  ] Stopped Memory Rule Check.
         Stopping Memory Rule Check...
[  OK  ] Stopped Synology Log bootup done.
         Stopping Synology Log bootup done...
[  OK  ] Removed slice Synology Index slice (WAT).
[  OK  ] Stopped Single Memory Channel Action.
         Stopping Single Memory Channel Action...
[  OK  ] Stopped Notify system is detected for unsupported drive.
         Stopping Notify system is detected for unsupported drive...
[  OK  ] Stopped synorelay daemon reloads configuration for fixed packages.
[  OK  ] Stopped Check malware and execute rc.local.
         Stopping Check malware and execute rc.local...
[  OK  ] Stopped Mount usb fs.
         Stopping Mount usb fs...
         Stopping Synology Database Update Daemon...
[  OK  ] Stopped Synology Bundle SSD estimate lifespan calculation on bootup.
         Stopping Synology Bundle SSD estima...ifespan calculation on bootup...
[  OK  ] Stopped Customized post-install configuration.
         Stopping Customized post-install configuration...
[  OK  ] Stopped Syno Data Protection - Btrfs Snapshot Usage Task Clean.
         Stopping Syno Data Protection - Btrfs Snapshot Usage Task Clean...
[  OK  ] Stopped Syno ssd cache bootup missing check.
         Stopping Syno ssd cache bootup missing check...
         Stopping Adjust md resync speed after bootup done...
[  OK  ] Stopped Reassemble Pstore log into /var/log/pstore/.
         Stopping Reassemble Pstore log into /var/log/pstore/...
         Stopping Periodic Command Scheduler...
[  OK  ] Stopped Initial Disk Health Database.
         Stopping Initial Disk Health Database...
[  OK  ] Stopped Synology Building Tasks Restore for Storage Manager.
         Stopping Synology Building Tasks Restore for Storage Manager...
[  OK  ] Stopped Check normal shutdown or improper shutdown.
         Stopping Check normal shutdown or improper shutdown...
         Stopping WD idle3 timer...
[  OK  ] Stopped Syno Data Protection - Btrfs Deleted Subvolume Clean.
         Stopping Syno Data Protection - Btrfs Deleted Subvolume Clean...
[  OK  ] Stopped Notify system partition error happened.
         Stopping Notify system partition error happened...
         Stopping WS-Transfer Server...
[  OK  ] Stopped Notify bundle drive update after bootup done.
         Stopping Notify bundle drive update after bootup done...
[  OK  ] Removed slice Shared Folder Sync.
[  OK  ] Stopped hook on all packages ready.
         Stopping Control RC power...
[  OK  ] Stopped auto repair packages.
[  OK  ] Stopped target Packages start up done.
         Starting Log syno package service timestamp during boot time...
[  OK  ] Stopped target Low priority packages start up done.
         Stopping SynoFinder's service unit...
         Stopping HybridShare's service unit...
         Stopping OAuthService's service unit...
[  OK  ] Stopped Service for irq balance.
[  OK  ] Stopped Synology Network Event Daemon.
[  OK  ] Stopped WS-Discovery Server.
[  OK  ] Stopped Periodic Command Scheduler.
[  OK  ] Stopped FileStation's service unit.
[  OK  ] Stopped syno-mkdhparam.service.
[  OK  ] Stopped Synology Database Update Daemon.
[  OK  ] Stopped Synology daemon for monitoring disk latency..
[  OK  ] Stopped ActiveBackup Daemon for DSM.
[  OK  ] Stopped VPN Client.
[  OK  ] Stopped Set IP Conflict Detect.
[  OK  ] Started Remove SAS firmware update fail list.
[  OK  ] Stopped Adjust md resync speed after bootup done.
[  OK  ] Stopped Control RC power.
[  OK  ] Removed slice system-dhclient.slice.
[  OK  ] Stopped DHCP client init.
         Stopping DHCP client init...
[  OK  ] Removed slice system-syno\x2dmd\x2dresync\x2dspeed\x2dadjust.slice.
[  OK  ] Stopped target Synology bootup done.
[  OK  ] Stopped Synology Cache Advisor Boot Clean Up.
         Stopping Synology Cache Advisor Boot Clean Up...
[  OK  ] Removed slice FileStation's slice.
[  OK  ] Started Log syno package service timestamp during boot time.
[  OK  ] Stopped WD idle3 timer.
[  OK  ] Stopped Synology shutdown task.
         Stopping daemon for monitor HW/system status...
[  OK  ] Stopped WS-Transfer Server.
[  OK  ] Stopped pkg-SynoFinder-fileindexd.
         Stopping pkg-SynoFinder-synoelasticd...
[  OK  ] Stopped Write back disk latency to DB.
[  OK  ] Stopped OAuthService's service unit.
[  OK  ] Removed slice OAuthService's slice.
[  OK  ] Stopped HybridShare's service unit.
[  OK  ] Removed slice HybridShare's slice.
[  OK  ] Stopped pkg-SynoFinder-synoelasticd.
[  OK  ] Stopped SynoFinder's service unit.
[  OK  ] Removed slice SynoFinder's slice.
[  OK  ] Stopped target Synology Web console login available.
[  OK  ] Stopped Synology Web console login prepare.
         Stopping Synology Web console login prepare...
[  OK  ] Stopped target High priority packages start up done.
         Stopping ScsiTarget's service unit...
         Stopping Python2's service unit...
         Stopping BackupRestoreManager's service unit...
         Stopping SMBService's service unit...
         Stopping ActiveInsight's service unit...
         Stopping SecureSignIn's service unit...
[  OK  ] Stopped Before upgrade ready.
         Stopping Before upgrade ready...
[  OK  ] Stopped target Multi-User System.
[  OK  ] Removed slice BTRFS Optimization.
         Stopping Network Time Service...
         Stopping Synology Schedule Daemon...
         Stopping Log Rotate Daemon...
         Stopping ACPI Daemon...
[  OK  ] Removed slice Synology Swap Works.
         Stopping Synology log notification service...
[  OK  ] Stopped System Profile Tuning.
         Stopping System Profile Tuning...
         Stopping daemon for monitor logs and generate alert...
         Stopping synobackup daemon...
         Stopping SSD Cache Pin File Daemon...
[  OK  ] Stopped Entry for WS-Transfer and WS-Discovery Server.
         Stopping Entry for WS-Transfer and WS-Discovery Server...
[  OK  ] Removed slice RAID Resync Process. ...ing Resync, Repair and Reshape..
         Stopping synoconfd daemon...
[  OK  ] Removed slice BTRFS Space Reclaim.
         Stopping Synology SCGI SocketIO...
         Stopping Synology log accounting service...
         Stopping Login Service...
         Stopping Synology CGI Auth Daemon...
         Stopping Synology SCGI...
         Stopping SSDP service...
         Stopping Avahi daemon...
         Stopping deal with remote/ISO mount during when bootup and poweroff...
         Stopping Daemon for Recycle Bin...
         Stopping Synology daemon for monitoring space/disk/cache status...
         Stopping Daemon of performance alarm...
         Stopping Synology Cron Daemon...
         Stopping findhost daemon...
[  OK  ] Stopped target Packed In File Protocols.
         Stopping Samba SMB Daemon...
[  OK  ] Removed slice Synology Flashcache.
         Stopping Accountdb cache database...
         Stopping daemon for handle hotplug event...
[  OK  ] Stopped Login Service.
[  OK  ] Stopped Synology log accounting service.
[  OK  ] Stopped synobackup daemon.
[  OK  ] Stopped synoconfd daemon.
[  OK  ] Stopped Log Rotate Daemon.
[  OK  ] Stopped ACPI Daemon.
[  OK  ] Stopped findhost daemon.
[  OK  ] Stopped Network Time Service.
[  OK  ] Stopped Synology daemon for monitoring space/disk/cache status.
[  OK  ] Stopped daemon for monitor logs and generate alert.
[  OK  ] Stopped Synology Cron Daemon.
[  OK  ] Stopped Daemon of performance alarm.
[  OK  ] Stopped Daemon for Recycle Bin.
[  OK  ] Stopped daemon for handle hotplug event.
         Stopping Daemon for Resource Monitor...
[  OK  ] Removed slice Performance alarm.
[  OK  ] Stopped Check Synology HotSpare Config.
         Stopping Check Synology HotSpare Config...
[  OK  ] Removed slice Synology DSM Storage Service.
[  OK  ] Removed slice synobackup daemon slice.
[  OK  ] Stopped Daemon for Resource Monitor.
         Stopping SNMP Daemon...
[  OK  ] Stopped Synology SCGI SocketIO.
[  OK  ] Stopped Synology CGI Auth Daemon.
[  OK  ] Stopped Accountdb cache database.
[  OK  ] Stopped SSD Cache Pin File Daemon.
[  OK  ] Stopped SSDP service.
[  OK  ] Removed slice SSDP service.
[  OK  ] Stopped Avahi daemon.
[  OK  ] Stopped Synology log notification service.
         Stopping D-Bus System Message Bus...
[  OK  ] Stopped D-Bus System Message Bus.
         Stopping Synology Storage Console Server...
         Stopping SCSI Target Monitor...
[  OK  ] Stopped Synology Storage Console Server.
[  OK  ] Stopped SCSI Target Monitor.
         Stopping iSCSI Service...
[   31.495123] Module [udf] is removed.
[  OK  ] Stopped active insight monitor.
[   31.518037] Module [isofs] is removed.
[  OK  ] Stopped Samba SMB Daemon.
         Stopping NetBIOS name server...
[  OK  ] Stopped target User and Group Name Lookups.
[  OK  ] Stopped NetBIOS name server.
[  OK  ] Stopped Samba Environment Setup Unit.
         Stopping Samba Environment Setup Unit...
[  OK  ] Stopped LIO Userspace-passthrough daemon(tcmu-runner).
[   31.540555] Module [ocs_fc_lio] is removed.
[   31.541486] ocs_lnx_xport_detach: releasing transport layer
[  OK  ] Stopped deal with remote/ISO mount during when bootup and poweroff.
[  OK  ] Stopped target Synology shared folders.
[  OK  ] Stopped Check share snapshot.
         Stopping Check share snapshot...
[  OK  ] Stopped Migrate all volume and share to quota DB.
         Stopping Migrate all volume and share to quota DB...
[  OK  ] Stopped Check Synology shared folders.
         Stopping Check Synology shared folders...
[  OK  ] Stopped Load Bypass Traverse Checking.
         Stopping Load Bypass Traverse Checking...
[  OK  ] Stopped Keep var services homes existing.
         Stopping Keep var services homes existing...
[  OK  ] Stopped Python2's service unit.
[  OK  ] Stopped SMBService's service unit.
[  OK  ] Removed slice SMBService's slice.
[  OK  ] Removed slice Python2's slice.
[   31.558025] [10978]: ocs_fc_lio: ocs_thread_thunk:1054::ocs_proxy    terminated
[   31.567130] Module [tcm_qla2xxx] is removed.
[   31.590041] Module [qla2xxx] is removed.
[  OK  ] Stopped SNMP Daemon.
[  OK  ] Removed slice SNMP.
[   31.596230] Module [libfc] is removed.
[   31.604026] Module [scsi_transport_fc] is removed.
[   31.612994] Module [iscsi_target_mod] is removed.
[   31.631129] Module [tcm_loop] is removed.
[  OK  ] Stopped SecureSignIn's service unit.
[  OK  ] Removed slice SecureSignIn's slice.
[   31.645085] Module [vhost_scsi] is removed.
[  OK  ] Stopped ActiveInsight's service unit.
[  OK  ] Removed slice ActiveInsight's slice.
[   31.657027] Module [vhost] is removed.
[   31.665053] Module [target_core_user] is removed.
[   31.680226] Module [target_core_ep] is removed.
[   31.696982] Module [target_core_multi_file] is removed.
[   31.712029] Module [target_core_file] is removed.
[   31.728871] Module [target_core_iblock] is removed.
[   31.745017] Module [target_core_mod] is removed.
[   31.761001] Module [syno_extent_pool] is removed.
[   31.761654] iSCSI:extent_pool.c:780:ep_exit syno_extent_pool successfully finalized
[   31.768147] Module [rodsp_ep] is removed.
[   31.768760] iSCSI:target_core_rodsp_server.c:844:rodsp_server_exit RODSP server stopped.
[  OK  ] Stopped iSCSI Service.
[  OK  ] Stopped ScsiTarget's service unit.
         Stopping Nginx...
[  OK  ] Stopped target Network is Online.
[  OK  ] Stopped Check if network is ready.
         Stopping Check if network is ready...
[  OK  ] Stopped Wait for Synology Network to be Configured.
         Stopping Wait for Synology Network to be Configured...
[  OK  ] Removed slice ScsiTarget's slice.
[  OK  ] Stopped daemon for monitor HW/system status.
[  OK  ] Removed slice scemd.
[  OK  ] Stopped Nginx.
[  OK  ] Stopped Prepare var service tmp.
         Stopping Prepare var service tmp...
[  OK  ] Stopped target Synology data volumes.
[  OK  ] Stopped Synology volume mount post hook.
         Stopping Synology volume mount post hook...
         Stopping Synology volume service...
[  OK  ] Stopped Synology volume service.
[  OK  ] Stopped Synology filesystem check service.
         Stopping Synology filesystem check service...
[  OK  ] Stopped target Synology storage pool.
         Stopping Synology virtual space service phase2...
[  OK  ] Stopped Synology virtual space service phase2.
         Stopping Synology virtual space service...
[  OK  ] Stopped Synology virtual space service.
         Stopping Synology space service...
[  OK  ] Stopped Synology space service.
         Stopping Synology filesytem check on bootup...
         Stopping Synology firmware DLMC...
[  OK  ] Stopped Synology firmware DLMC.
[  OK  ] Stopped Synology filesytem check on bootup.
[  OK  ] Stopped Synology SCGI.
         Stopping Synology task manager...
         Stopping Redis data structure server for webapi...
[  OK  ] Removed slice Synology DSM desktop service.
[  OK  ] Stopped Redis data structure server for webapi.
[  OK  ] Stopped target Network.
[  OK  ] Stopped Set Multiple Geteway.
         Stopping Set Multiple Geteway...
         Stopping PPPoE...
         Stopping Synology Network Daemon...
[  OK  ] Stopped Synology Network Daemon.
         Stopping D-Bus Session Message Bus...
[  OK  ] Stopped D-Bus Session Message Bus.
[  OK  ] Stopped PPPoE.
[  OK  ] Stopped target Network (Pre).
[  OK  ] Stopped BackupRestoreManager's service unit.
[  OK  ] Stopped target Hook on root ready.
[  OK  ] Stopped always preprocess jobs before any package is started.
         Stopping always preprocess jobs before any package is started...
[  OK  ] Removed slice Package Center Slice.
[  OK  ] Removed slice BackupRestoreManager's slice.
[  OK  ] Stopped Synology Schedule Daemon.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Synology synoboot2 done.
[  OK  ] Stopped bootup upgrade sha package.
         Stopping bootup upgrade sha package...
[  OK  ] Stopped target System Initialization.
         Stopping Synology swap...
[  OK  ] Stopped Check /etc/synoinfo.conf.
         Stopping Check /etc/synoinfo.conf...
[  OK  ] Stopped Set Eunit Sequence.
         Stopping Set Eunit Sequence...
         Stopping unbind USB device...
[  OK  ] Stopped Apply kernel variable kernel.sem at least 1024.
         Stopping Apply kernel variable kernel.sem at least 1024...
[  OK  ] Stopped Synology Log bootup start.
         Stopping Synology Log bootup start...
         Stopping System Logger Daemon...
[  OK  ] Stopped Apply kernel variable vm.min-free-kbytes.
         Stopping Apply kernel variable vm.min-free-kbytes...
[  OK  ] Stopped Apply kernel variable vm.kswapd_threads.
         Stopping Apply kernel variable vm.kswapd_threads...
[  OK  ] Stopped target Swap.
[  OK  ] Stopped Clean UPS config.
         Stopping Clean UPS config...
[  OK  ] Stopped target Synology root filesystem (rw) ready.
[  OK  ] Stopped Apply kernel variable kernel-shmmni at least 16384.
         Stopping Apply kernel variable kernel-shmmni at least 16384...
[  OK  ] Stopped Apply Kernel Variables.
         Stopping Apply Kernel Variables...
[  OK  ] Stopped Apply default and user cust...ed sysctl.conf kernel variable..
         Stopping Apply default and user cus... sysctl.conf kernel variable....
[  OK  ] Stopped target Sockets.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
         Stopping Disabling fan checking flag ......
[  OK  ] Stopped target Paths.
[  OK  ] Removed slice Task Scheduler Group.
[  OK  ] Stopped target Synology synoscheduler functions.
[  OK  ] Stopped target Synology local user and group ready.
[  OK  ] Stopped Check Synology group info consistency.
         Stopping Check Synology group info consistency...
[  OK  ] Stopped Check Synology user info consistency.
         Stopping Check Synology user info consistency...
[  OK  ] Stopped target Create SDK locks directory.
[  OK  ] Stopped unbind USB device.
[   32.937848] md1: detected capacity change from 2147418112 to 0
[   32.938622] md: md1: set sdb2 to auto_remap [0]
[   32.939203] md: md1 stopped.
[   32.939573] md: unbind<sdb2>
[   32.944026] md: export_rdev(sdb2)
[  OK  ] Stopped Disabling fan checking flag ....
[   32.952195] <redpill/smart_shim.c:354> ATA_CMD_ID_ATA confirmed SMART support - noop
[   32.965233] Module [zram] is removed.
[   32.966505] zram: Removed device: zram0
[   32.972900] zram: Removed device: zram1
[   32.983923] zram: Removed device: zram2
[   32.991051] zram: Removed device: zram3
[   33.000434] zram: Removed device: zram4
[   33.006765] zram: Removed device: zram5
[  OK  ] Stopped System Logger Daemon.
[  OK  ] Removed slice Synology DSM internal service.
[  OK  ] Stopped Synology swap.
[  OK  ] Stopped Synology task manager.
[  OK  ] Stopped synodsmnotify.
         Stopping synodsmnotify...
[  OK  ] Stopped Create Volatile Files and Directories.
         Stopping Create Volatile Files and Directories...
[  OK  ] Reached target Shutdown.
         Starting Touching NormalShutdown...
[  OK  ] Stopped target Local File Systems.
[  OK  ] Started Touching NormalShutdown.
[  OK  ] Reached target Final Step.
         Starting broadcast synorelayd poweroff state...
         Starting Synology log rm service...
[  OK  ] Started Synology log rm service.
[  OK  ] Started broadcast synorelayd poweroff state.
         Starting Power-Off...
[   34.125066] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[   34.128858] systemd-journald[6411]: Received SIGTERM from PID 1 (systemd-shutdow).
[   35.130563] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[   35.134834] systemd-shutdown[1]: Unmounting file systems.
[   35.135748] systemd-shutdown[1]: Unmounting /config.
[   35.144017] systemd-shutdown[1]: Unmounting /tmp.
[   35.176180] EXT4-fs (md0): re-mounted. Opts: (null)
[   35.178790] EXT4-fs (md0): re-mounted. Opts: (null)
[   35.179506] EXT4-fs (md0): re-mounted. Opts: (null)
[   35.180188] systemd-shutdown[1]: All filesystems unmounted.
[   35.180945] systemd-shutdown[1]: Deactivating swaps.
[   35.181695] systemd-shutdown[1]: All swaps deactivated.
[   35.182635] systemd-shutdown[1]: Detaching loop devices.
[   35.184161] systemd-shutdown[1]: All loop devices detached.
[   35.185144] systemd-shutdown[1]: Detaching DM devices.
[   35.186091] systemd-shutdown[1]: All DM devices detached.
systemd-shutdown: run synobios_uninit OK
[   35.213010] systemd-shutdown[1]: Powering off.
[   36.214556] sd 6:0:0:0: [sdb] Synchronizing SCSI cache
[   36.215293] sd 6:0:0:0: [sdb] Stopping disk
[   36.215866] sd 5:0:0:0: [synoboot] Synchronizing SCSI cache
[   36.216620] sd 5:0:0:0: [synoboot] Stopping disk
[   36.253839] mlx4_core 0000:01:00.0: mlx4_shutdown was called
[   37.273614] parameter error. gpiobase=00000000, pin=0, pValue=ffff88046b983da4
[   37.775159] Turned off USB vbus gpio 0 (ACTIVE_LOW)
[   37.776541] parameter error. gpiobase=00000000, pin=0, pValue=ffff88046b983da4
[   38.278157] Turned off USB vbus gpio 0 (ACTIVE_LOW)
[   38.279508] parameter error. gpiobase=00000000, pin=0, pValue=ffff88046b983da4
[   38.781154] Turned off USB vbus gpio 0 (ACTIVE_LOW)
[   38.782567] parameter error. gpiobase=00000000, pin=0, pValue=ffff88046b983da4
[   39.284131] Turned off USB vbus gpio 0 (ACTIVE_LOW)
[   39.284864] parameter error. gpiobase=00000000, pin=0, pValue=ffff88046b983da4
[   39.786147] Turned off USB vbus gpio 0 (ACTIVE_LOW)
[   39.795536] ACPI: Preparing to enter system sleep state S5
[   39.796454] reboot: Power down
[   39.798363] acpi_power_off called
[   39.798951] Confirm SLP_TYP poweroff status 0 pm1a 1 pm1b 1
[   39.799005] Confirm OS poweroff status 0 pm1a 2001 pm1b 2001
I did manage to grab this from the serial output before it vanished off the screen....
Spoiler
 ... [  OK  ]
:: Loading kernel modules from extensions ...
Loading kmod #0 "button.ko" for dodo-dk.acpid (args: )
[   11.123033] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[   11.123940] ACPI: Power Button [PWRF]
Loading kmod #0 "e1000.ko" for pocopico.e1000 (args: )
[   11.127873] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[   11.128762] e1000: Copyright (c) 1999-2006 Intel Corporation.
[   11.129645] ACPI: PCI Interrupt Link [GSIH] enabled at IRQ 23
[   11.424085] usb 2-1: new high-speed USB device number 2 using ehci-pci
[   11.426739] e1000 0000:06:12.0 eth0: (PCI:33MHz:32-bit) a2:cc:ea:6c:14:8c
[   11.427644] e1000 0000:06:12.0 eth0: Intel(R) PRO/1000 Network Connection
Loading kmod #0 "mlx4_core.ko" for pocopico.mlx4_core (args: )
[   11.432481] mlx4_core: Mellanox ConnectX core driver v2.2-1 (Feb, 2014)
[   11.433417] mlx4_core: Initializing 0000:01:00.0
So I tried removing the virtual NIC. This allowed the Redpill to boot to the SynologyNAS stage, but still no IP or eth0/eth1 assignment.
Spoiler
root@SynologyNAS:~# lspci -kkq
0000:00:00.0 Class 0600: Device 8086:29c0
        Subsystem: Device 1af4:1100
0000:00:01.0 Class 0300: Device 1234:1111 (rev 02)
0000:00:1a.0 Class 0c03: Device 8086:2937 (rev 03)
        Kernel driver in use: uhci_hcd
0000:00:1a.1 Class 0c03: Device 8086:2938 (rev 03)
0000:00:1a.2 Class 0c03: Device 8086:2939 (rev 03)
0000:00:1a.7 Class 0c03: Device 8086:293c (rev 03)
        Kernel driver in use: ehci-pci
0000:00:1b.0 Class 0403: Device 8086:293e (rev 03)
0000:00:1c.0 Class 0604: Device 1b36:000c
        Kernel driver in use: pcieport
0000:00:1c.1 Class 0604: Device 1b36:000c
0000:00:1c.2 Class 0604: Device 1b36:000c
0000:00:1c.3 Class 0604: Device 1b36:000c
0000:00:1d.0 Class 0c03: Device 8086:2934 (rev 03)
0000:00:1d.1 Class 0c03: Device 8086:2935 (rev 03)
0000:00:1d.2 Class 0c03: Device 8086:2936 (rev 03)
0000:00:1d.7 Class 0c03: Device 8086:293a (rev 03)
0000:00:1e.0 Class 0604: Device 8086:244e (rev 92)
0000:00:1f.0 Class 0601: Device 8086:2918 (rev 02)
        Kernel driver in use: lpc_ich
0000:00:1f.2 Class 0106: Device 8086:2922 (rev 02)
        Kernel driver in use: ahci
0000:00:1f.3 Class 0c05: Device 8086:2930 (rev 02)
        Kernel driver in use: i801_smbus
0000:01:00.0 Class 0200: Device 15b3:1007
        Subsystem: Device 15b3:000c
        Kernel driver in use: mlx4_core
0000:05:01.0 Class 0604: Device 1b36:0001
0000:05:02.0 Class 0604: Device 1b36:0001
0000:05:03.0 Class 0604: Device 1b36:0001
0000:05:04.0 Class 0604: Device 1b36:0001
0000:06:03.0 Class 00ff: Device 1af4:1002
        Subsystem: Device 1af4:0005
        Kernel driver in use: virtio-pci
0000:06:07.0 Class 0106: Device 8086:2922 (rev 02)
0001:09:00.0 Class 0106: Device 1b4b:9235 (rev 11)
0001:0c:00.0 Class 0106: Device 1b4b:9235 (rev 11)
root@SynologyNAS:~#
Edited by DarkBlade
Got this working by initially using a virtualised Intel e1000 NIC, running TinyCore and executing the following to get the base loader ready:
  • ./rploader.sh update now
  • ./rploader.sh fullupgrade now
  • ./rploader.sh serialgen DS3622xs+
  • ./rploader.sh build broadwellnk-7.1.0-42661
  • sudo poweroff
Then Ran the full DSM installation - then once completed...
Shutdown the virtual machine.
Removed the virtual Intel NIC (in Proxmox).
Added the Mellanox NIC via PCI passthrough.
Started the VM.
Both 10Gbe ports available in DSM.
