romeoz Posted August 6, 2013 Share #1 Posted August 6, 2013 I had no problems while running 4.1 but when I upgraded to 4.2 I'm having problems with either sleep or hibernate. I assume its sleep because the computer stays powered on but a red light shows up on the front of my PC. I try to access it but synology assistant says no servers found. I disabled the wol and under hardware options I turned off hd hibernation. I can reset my computer and everythig works as normal. Any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
