Alydis Posted January 21, 2016 #1 Posted January 21, 2016 So, I was forced to do a reboot during expansion. My drives are 2/2/2/3/3/4/4. Rebooted in the middle of expanding the last 4 TB drive. More detailed information can be found here: http://forum.synology.com/enu/viewtopic ... 9&t=109329 Essentially, what I should have is: md2 in raid5 with 7x2TB partitions md3 in raid5 with 4x1TB partitions md4 in raid1 with 2x1TB partitions The system was rebooted during reshape of md2. Upon power up, I find that md4 was created and md2 automatically assembled and finished reshape and resync. md3 failed to assemble. Recreating the situation in VirtualBox, I was able to recover by recreating md3. 1. I got the order of the drives via the mdadm -A --scan --verbose command. It reports which partitions were in which slot of md3. 2. I got the size by doing mdadm --examine /dev/sdb6, where sdb6 is a partition that was in the array. I then took that number and divided by 2 to convert from 512b blocks to 1024b blocks. 3. I recreated the array via: mdadm --create --assume-clean --level=5 --raid-devices=3 /dev/md3 /dev/sd[abc]6, where I passed the 3 members in the same order as the first three members of the array (slots 0-2). 4. vgchange -a y 5. mount /dev/vg1000/lv /mnt It also appeared to work if I specified the drives in any order. AND, it also appeared to work if I recreated the array with all 4 drives (with --raid-review=4) I am too afraid to run this on th actual NAS. Looking for some confirmation to say that this is the correct way for me to recover the data. Note, I did try to force assembly, but got an error about being in a critical section and needing a backup file, which I do t hav. I've posted on Synology forums, Linux-raid mailing list, but have not gotten any responses. Please help! Thank you in advance Tommy
