Hi All
I recently decided to take the plunge and set myself up a NAS and decided to give XPEnology a whirl. Settled on XPEnoboot_DS3615_5.1-5022.3 and corresponding DSM (which later updated to DSM 5.1-5022 Update 4 after I left auto update on). I'm running a Gen 8 HP and to be honest haven't had any issues but the one feature i really was after 'cloud station' doesn't work. I get an unknown error when i try and log in
I'm just wondering whether this option should work or i've messed the versions up i should have installed, also ill timed with my install as .nl has shutdown which i was using for references!
Anyway i was just wondering whether cloud station does work for others?
Many thanks
James
