Help! Automatically restart after a power failure
vista1967
Hello, no no solution for this problem?
Now with the latest update, I can no longer check "Automatically restart after a power failure" Every time I "apply" it delivers alone. So when it's a crash, I have to be in front of the tower to start because it will not start by itself.
thank you
Yes this is enabled in bios option.
For several days my NAS randomly cutting brutal way.
In the logs, I have a warning "System booted up from an improper shutdown", and I receive a notification by mail "DiskStation encountered a power cut and turned off incorrectly.".
I met no power loss problem, the NAS is connected to a UPS.
Has that ever happened to anyone here?
Thank you in advance! sorry I do not speak English translation :sad:
