DeanoBeano 1 Posted May 26, 2020 Share Posted May 26, 2020 (edited) Wow what a great place you have here i am so pleased i managed to find this fourm. So my aim is to upgrade from my 4 bay synology by building my own home sever with up to 10 bays available . This will be my very first home build so would like to make sure it will be fine before buying the parts and building it . This will mainly be a storage device for all my media DNLA server and for torrenting use, i dont really use plex so not that botherd if i have it or not . Motherboard : ASRock B450M PRO4 Micro ATX AM4 CPU :AMD Ryzen 3 3200G 3.6 GHz Quad-Core RAM : Kingston HyperX Fury 8 GB (1 x 8 GB) DDR4-3200 I have done a lot of reading though the forum and as far as i can tell they should be fine . The only other thing im not sure about is it worth having an internal ssd on my motherboard and if yes will that automatically show up when i do the install or do i have to change or add code on set up . Edited May 26, 2020 by DeanoBeano Quote Link to post Share on other sites
