Wizengamot Posted September 8, 2019 #1 Posted September 8, 2019 Here is the guide I have been using. I am using the files referred to in the Tutorial. 1. It refers to the VMDK file from the DS3615xs 6.02 Jun's Mod V1.01 2. It refers to two options for the IMG file, I am using the DS3615_6.2 image file. 3. I have modified the IMG file using Notepad++ and OSFMount as per the instructions. In my case I have 4 NICs, so I put those into the GRUB.CFG file. Using a serial for a DS3615. 4. Configured the VM exactly as the instructions said to do so. 5. The adding of the second disk was a bit unclear so I created a second disk of 500GB, Thick Provisioned, lazy zeroed. I believe the writer of the Tutorial meant for many disks to be added, but I only added 1. The idea being that more can be added later on as needed. I got right up the point where I see the Command Line screen as per the instructions. The black screen that says to visit find.synology.com. This website cannot find anything at all. So I promptly downloaded Synology Assistant. This is where things get weird. The assistant DOES find a synology on the network. Everything matches, the MAC I assigned, The Model I am installing, Serial Number given, but the IP address of the unit is 192.168.1.156. This is very very odd, because while the IBM x3650 M4 has 4 nics in it, only one is connected to a wire right now and it is only (theoretically) able to use 192.168.88.1 - 192.168.88.254 (this is according to the VLAN 0 configuration in ESXi. So.... I try to install DSM onto the found Disk Station. It asks for the PAT file and I give it the PAT that I grabbed which in this case is DSM_DS3615xs_23739 which I got from synology under the 6.2 folder. I got 6.2 because I was using the 6.2 bootloader. The "odd" file out is the VMDK from the zip file and it could well be a VMDK from 6.02. (see point #1). During the installation it recommends that I use Manual Network settings and suggests an address in the 192.168.88 subnet. When I attempt to use ANY address in this subnet it tells me that the address is in use. (It is not). I moved on to letting it use DHCP for networking and tried to run the install again. It failed right after applying the network with the message: The big question is this. How on earth can this VM get an address of 192.168.1.156 when the VLAN 0 says the only discoverable addresses are the range of 192.168.88.1 - 254? I think this is the root of the problem and I so far have not found a way around it. Thanks for your help in advance. B Quote
luchuma Posted September 8, 2019 #2 Posted September 8, 2019 are you using nics mac from your hardware? 1 Quote
Wizengamot Posted September 8, 2019 Author #3 Posted September 8, 2019 Yes. I checked using Linux to determine what the MAC was on each NIC. Not sure how to do this using ESXi but I was playing around with ProxMox earlier and I had the MAC addresses from when I tried this same procedure using PROXMOX. I did not even get this far on ProxMox and I found that ESXi had more information so I switched. Quote
Wizengamot Posted September 9, 2019 Author #4 Posted September 9, 2019 (edited) This is now working. There was a problem with the network that was fixed. Many thanks to Luchuma for their comment because it prompted me to look further into the networking and I found the issue as a result. Did not find a way to mark their post as answer. Edited September 9, 2019 by Wizengamot Quote
