Tomte Posted October 21, 2018 #1 Posted October 21, 2018 (edited) Hello, I would like to use my system to connect to the wan/lan via wifi and connect other devices at the ethernet ports without subnet. Therefore, I would like to define a bridge. I try to follow roughly this discussion: https://www.synology-forum.de/showthread.html?76597-DS-als-Switch-nutzen-bei-DSM-6-0-Bridge-zwischen-eth0-und-eth1 However, I have problems with the brctl command: root@Syno-N40L:~# /sbin/modprobe /usr/lib/modules/stp.ko root@Syno-N40L:~# /sbin/modprobe /usr/lib/modules/bridge.ko root@Syno-N40L:~# /bin/brctl addbr br0 add bridge failed: Package not installed root@Syno-N40L:~# insmod /lib/modules/bridge.ko insmod: ERROR: could not insert module /lib/modules/bridge.ko: Unknown symbol in module root@Syno-N40L:~# brctl addbr br0 add bridge failed: Package not installed The wifi USB stick is already inserted and working. I am running DSM 6.2 update 2 on a N40L. So I am not so sure, if this is a problem of the Diskstation software or rather XPEnology specific? Can anybody please give me a hint? Kind regards, Tomte Edited October 21, 2018 by Tomte Quote
Tomte Posted October 21, 2018 Author #2 Posted October 21, 2018 Does not seem to be a xpenology issue. I fixed it with insmod /lib/modules/stp.ko However, the setup with wifi does not work. Has anyone a working example? Regards, Tomte Quote
