DVB-C Stick | TBS DVBC USB2.0
Schrammi
i try to use this DVB-C Stick with xpenology 4.3 on HP N54L. I tried the v1.0 and the v1.1 beta5. I think both with the same error.
I installed libdvb via ipkg and dvb link via synology.
When i plug in the stick, i got the following error via /var/log/message.
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740847] As the driver is backported to an older kernel, it doesn't offer
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740849] enough quality for its usage in production.
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740850] Use it with care.
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740851] Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740852] d92462401dde1effa04a51d0a15000e6246d2a43 [media] v4l2-ioctl: fix W=1 warnings
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740853] 1b8b10cc7e6bd9bf017c58e32b1e7f632e23850d [media] v4l2-ioctl: add blocks check for VIDIOC_SUBDEV_G/S_EDID
Jan 28 18:11:16 DiskStationtest kernel: [ 27.740855] 8a18382c3196978164f0f6290aac98f2f6f43c00 [media] omap3isp: Fix compilation error in ispreg.h
Jan 28 18:11:16 DiskStationtest avahi-daemon[8021]: Failed to add service 'DiskStationtest' of type '_http._tcp', ignoring service group (/usr/syno/avahi/services/http.service): Invalid record
Jan 28 18:12:11 DiskStationtest kernel: [ 82.006965] Got empty serial number. Generate serial number from product.
Jan 28 18:12:11 DiskStationtest kernel: [ 82.204698] tbsdvbc: read eeprom failed.
Jan 28 18:12:11 DiskStationtest kernel: [ 82.204741] dvb-usb: MAC address reading failed.
Jan 28 18:12:11 DiskStationtest kernel: [ 82.223203] tbsdvbcfe: attach failed : 21
Jan 28 18:12:11 DiskStationtest kernel: [ 82.223256] dvb-usb: no frontend was attached by 'TBS DVBC USB2.0'
Jan 28 18:12:12 DiskStationtest hotplugd: ##### ACTION:add
Jan 28 18:12:12 DiskStationtest hotplugd: DEVICE:/proc/bus/usb/001/003
Jan 28 18:12:12 DiskStationtest hotplugd: DEVPATH:1-5
Jan 28 18:12:12 DiskStationtest hotplugd: SUBSYSTEM:usb
Jan 28 18:12:16 DiskStationtest kernel: [ 87.233052] ------------[ cut here ]------------
Jan 28 18:12:16 DiskStationtest kernel: [ 87.233089] kernel BUG at kernel/workqueue.c:570!
Jan 28 18:12:16 DiskStationtest kernel: [ 87.234017] invalid opcode: 0000 [#1] SMP
Jan 28 18:12:16 DiskStationtest kernel: [ 87.234017] CPU 0
Jan 28 18:12:16 DiskStationtest kernel: [ 87.234017] Modules linked in: dvb_usb_tbsqbox22(O) tbs5922fe(P) dvb_usb_tbs5680(O) dvb_usb_tbsdvbc(O) tbsdvbcfe(P) tbs5680fe(P) dvb_usb_tbsqbox2ci(O) stv090x(O) dvb_usb_pctv452e(O) stb6100(O) stb0899(O) lnbp22(O) ttpci_eeprom(O) dvb_usb_dw2102(O) ds3000(O) au0828(O) au8522_dig(O) au8522_decoder(O) au8522_common(O) xc5000(O) s5h1411(O) dvb_usb_dib0700(O) dib9000(O) dib0070(O) dib7000p(O) dib0090(O) dib7000m(O) dib8000(O) dib3000mc(O) dibx000_common(O) dvb_usb_ttusb2(O) dvb_usb(O) tda827x(O) tda10048(O) tda10023(O) em28xx_dvb(O) em28xx(O) a8293(O) tda10071(O) m88ds3103(O) m88ts2022(O) tda18271(O) cxd2820r(O) tuner(O) rc_core(O) dvb_core(O) v4l2_common(O) videobuf_vmalloc(O) videobuf_core(O) videodev(O) media(O) tveeprom(O) cifs udf isofs loop usbhid hid usblp usb_storage uhci_hcd etxhci_hcd xhci_hcd ohci_hcd ehci_hcd bromolow_synobios(P) synoacl_ext4(P) synoacl_vfs(P) btrfs zlib_deflate libcrc32c hfsplus md4 hmac ixgbe be2net igb(O) i2c_algo_bit dca fuse vfat fat cryptd ecryptfs sha512_generic sha256_generic sha1_generic ecb aes_x86_64 authenc chainiv des_generic crc32c eseqiv krng ansi_cprng cts rng aes_generic md5 cbc cryptomgr pcompress aead crypto_hash crypto_blkcipher crypto_wq crypto_algapi cpufreq_conservative cpufreq_powersave cpufreq_performance cpufreq_ondemand mperf processor thermal_sys cpufreq_stats freq_table dm_snapshot crc_itu_t crc_ccitt quota_v2 quota_tree usbcore psnap p8022 llc usb_common ipv6 sg sk98lin(O) r8169 r8168(O) bnx2(O) tg3(O) e1000e(O) alx(O) mdio compat(O) [last unloaded: bromolow_synobios]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] Pid: 2534, comm: khubd Tainted: P O 3.2.40 #57 HP ProLiant MicroServer
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] RIP: 0010:[] [] get_work_gcwq+0x28/0x32
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] RSP: 0018:ffff880074a0f978 EFLAGS: 00010293
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] RAX: 0000000000000000 RBX: ffff880077a1a5a0 RCX: 0000000000000096
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] RDX: 0000000000000000 RSI: ffff880076c08140 RDI: 0000000000000005
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] RBP: ffff880076c08140 R08: 000000000000d182 R09: 00000100ffffff86
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] R10: ffff880076c18000 R11: ffffffff811a97c5 R12: ffff880077a1a5c0
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] R13: 00000000ffffffff R14: 0000000000000096 R15: 0000000000000001
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] FS: 00007f081858f5e0(0000) GS:ffff880077400000(0000) knlGS:00000000f73e21c0
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] CR2: 00000000f6c3fa38 CR3: 0000000072768000 CR4: 00000000000006f0
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] Process khubd (pid: 2534, threadinfo ffff880074a0e000, task ffff880076cc4c30)
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] Stack:
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] ffffffff810421c0 0000000000000096 ffff880077a18000 0000000000000000
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] 000000000000002a ffff880077a18000 ffffffffa05cc093 0000000000000000
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] ffff880077a19130 ffff880077a19298 0000000000000001 ffff880077a18a10
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] Call Trace:
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? queue_delayed_work_on+0x8f/0xfe
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? dvb_usb_remote_init+0x273/0x440 [dvb_usb]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? dvb_usb_device_init+0x62f/0x700 [dvb_usb]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? tbsdvbc_probe+0x20/0x30 [dvb_usb_tbsdvbc]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? usb_probe_interface+0xbf/0xfa [usbcore]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? driver_probe_device+0x99/0x11c
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? __driver_attach+0x61/0x61
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? bus_for_each_drv+0x46/0x77
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? device_attach+0x5c/0x73
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? bus_probe_device+0x22/0x3b
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? device_add+0x3d2/0x52d
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? usb_set_configuration+0x52a/0x57e [usbcore]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? generic_probe+0x48/0x73 [usbcore]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? usb_new_device+0x304/0x34d [usbcore]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? hub_thread+0x91f/0xd7f [usbcore]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? wake_up_bit+0x22/0x22
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? usb_kick_khubd+0x3c/0x3c [usbcore]
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? kthread+0x6a/0x72
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? kernel_thread_helper+0x4/0x10
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? kthread_bind+0x5c/0x5c
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] [] ? gs_change+0xb/0xb
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] Code: 08 eb be 48 8b 07 a8 04 74 06 30 c0 48 8b 00 c3 48 89 c7 31 c0 48 c1 ef 08 83 ff 09 74 16 3b 3d 12 72 61 00 72 09 83 ff 08 74 04 <0f> 0b eb fe e9 59 fd ff ff c3 e8 c9 ff ff ff 48 85 c0 ba 09 00
Jan 28 18:12:16 DiskStationtest kernel: [ 87.235893] RIP [] get_work_gcwq+0x28/0x32
Jan 28 18:12:16 DiskStationtest kernel: [ 87.244189] ---[ end trace 4bcb5cb5c9352674 ]---
Edited by Guest
