[SOLVED] Remote shutdown for Win users (Telnet or SSH wRSA)
toshas
There are some people's which is not familiar with linux.
This remote shutdown solution can be useful for them.
Solution was found here:
http://www.synology-forum.de/showthread ... ing-Telnet
Telnet Scripting Tool a.k.a TST10.exe
http://jerrymannel.com/blog/2008/11/11/ ... -tst10exe/
1. On synology go to Control Panel/Network Services Folder/Terminal Services and enable the Telnet Service
http://forum.synology.com/wiki/index.ph ... _Interface
2. download TST10.zip - Telnet Scripting Tool
3. write you own script (shutdown.txt) like this
192.168.1.10 23
WAIT "login:"
SEND "root\m"
WAIT "assword:"
SEND "MyPassword\m"
WAIT ">"
SEND "poweroff\m"
WAIT ">"
4. create .bat file with right path to TST10.exe
C:/../TST10/tst10 /r:shutdown.txt
5. shutdown your synology by double-click on .bat file
p.s. there is report about weak telnet security
http://wrgms.com/post/37501692643/synol ... t-password
I can't confirm this on my setup (Trantor v1.2 repack).
TST10.zip
Edited by Guest
Solution that allows you login via SSH with a RSA keypair was found here:
http://www.mauchle.name/blog/?p=239
1. Download PuTTY and PuTTYgen (or just get the installer, everything is in there) from here http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html.
2. Generate a keypair with PuTTYgen (Parameters: SSH-2 RSA)
3. Save the private key as “myprivatekey.ppk”
4. Copy the public key to the clipboard. Looks somewhat like this:
ssh-rsa AAAAB3NzaC1yc2EAAAABJQAAAIEAzP4MR3lkCD2pa7nwT3NMjjDBMmEuJ4exW4GKBBP+okArZ/IrjbLIpdh8ahpfgjh8kM//OVUGeRa1GigzcCuGzIa2YfS7L4Q9cbUUWFwIu2hGV3ZpJ2xDZExaaLH90Vw+ZBaozD2OI4FZ1Dqh8Bj29SQqIIbmxf/ASyTmXHZCbQk= rsa-key-20130414
5. Connect to your diskstation with PuTTY
diskstation:22
6. Login as root
7. Edit the SSH config with
vi /etc/ssh/sshd_config
8. Look for the following lines
#RSAAuthentication yes
#PubkeyAuthentication yes
#AuthorizedKeysFile .ssh/authorized_keys
9. Change them to this (by hitting “x” when the cursor is over the # and hitting ESC, then typing :wq ENTER)
10. Go to /root and create the .ssh folder
cd /root
mkdir .ssh
11. Edit the keyfile
vi /root/.ssh/authorized_keys
12. Press “i”
13. Paste your public key and save the file (Hit Esc, type :wq, hit Enter)
14. Set the access-rights to the file
chmod 700 /root/.ssh
chmod 644 /root/.ssh/authorized_keys
15. Disconnect with
exit
16. Open Putty again and make the following settings
Hostname: or
Port: 22
Connection type: SSH
Connection->Data->Auto-login username: root
Connection->SSH->Auth->Private Key: Your Keyfile
And save the session as
17. Create a new shortcut on your desktop with the following target
"C:\Program Files (x86)\PuTTY\putty.exe" -load "sessionname"
18. Finished. From now on you can connect by double-clicking.
All steps can be done via ssh or telnet.
At step 16
Connection->SSH->Remote command:
allows you to send different commands after login
for shutdown it should be
nohup poweroff > /dev/null 2>&1 &
For more complex command set
"C:\Program Files (x86)\PuTTY\putty.exe" -load "sessionname" -m C:\commands.txt
If you don't want to close session immediately, change
Connection->Close windows on exit: Always/Never/On clean exit
SSH with a RSA keypair login is more secure than Telnet.
p.s. with this thread
Turn on your XPEnology with *double-click*
http://xpenology.com/forum/viewtopic.php?f=2&t=1330
Win users have complete 'double-click' solution for turn-on/turn-off their synology
