RAID and Volume lost after reboot - ESX, 6.5, DSM 6.1.4
Dear all,
I was installing mine Xpenology with manuals and files from pigr8 https://xpenology.com/forum/topic/7667-how-to-clean-install-in-vm-using-102b/?do=findComment&comment=74129
All went fine, until 1st reboot. Afer reboot i lost RAID group and Volume. When Xpenology boot without RAID group and Volume, i can easybuild RAID group again and create Volume and it will work again untill 1st reboot (normaly if there were any data, all is lost).
The RAID group and Volume  creatad on VMware virtual disk won't diapear after restart:
Hard disk 1:
8GB
Thin provisioned
SCSI controller 0, SCSI (0:0)
Dependent
Hard disk 3:
3TB
Thick provisioned, lazly zeroed
SCSI controller 0, SCSI (0:1)
Independent - persistant
Hard disk 4:
3TB
SCSI controller 0, SCSI (0:2)
System:
 HP N54L, 16GB RAM, 250GB HDD + 2x 3TB HDD in RAW mode mounted in RDM
loader: 1.02b
DS3615xs, DSM 6.1.4-15217 Update1
Hope nayone will have idea how to solve that, as i was searching forum and wasn't able to find solution how to solve.
Thank you!
Alex_G
  • Polanskiman changed the title to RAID and Volume lost after reboot - ESX, 6.5, DSM 6.1.4
UPDATE!
If i create Datastore on VMWARE and add this datastore to Xpenology, my Volumes are not lost after restart.
If i make RAW mount and creat VMFS images and than i add those existing disks to Xpenology VM than i always lose volume/raid group at each restart.
Any idea what i'm doing wrong?
Maybe now someone will have idea where i'm wrong.
Thank you,
Alex_G
