Cr4z33 Posted January 29, 2018 Share #1 Posted January 29, 2018 I was planning to add an additional volume to my custom built NAS to avoid to use too much my 4 SHR RAID hard drives. Unfortunately I've ended all the available SATA3 ports. I therefore thought about using a USB3 external 1TB (mechanical) hard drive, but I wonder if it would work without problem when using it for Synology Surveillance System and for its records? Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted January 30, 2018 Share #2 Posted January 30, 2018 It's not possible out of the box because external drives cannot be made volumes since DSM does not manage external drives. There is a work around that is explained in the following link but it seems old so not sure if that would work with the current DSM 6.1. and honestly I would not advise it. http://82.100.88.27/wordpress/?p=5 There is another option as explained here: https://forum.synology.com/enu/viewtopic.php?t=77947#p293164 and detailed here: https://forum.synology.com/enu/viewtopic.php?t=129503#p493831 The other option is to simply change your HDDs for bigger capacity. Quote Link to comment Share on other sites More sharing options...
Cr4z33 Posted January 30, 2018 Author Share #3 Posted January 30, 2018 It's not possible out of the box because external drives cannot be made volumes since DSM does not manage external drives. There is a work around that is explained in the following link but it seems old so not sure if that would work with the current DSM 6.1. and honestly I would not advise it.http://82.100.88.27/wordpress/?p=5 There is another option as explained here:https://forum.synology.com/enu/viewtopic.php?t=77947#p293164 and detailed here:https://forum.synology.com/enu/viewtopic.php?t=129503#p493831 The other option is to simply change your HDDs for bigger capacity.Thank you for helping.Damn so I have to swap again the motherboard.Time to find one finally working with Synology standby then... Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 31, 2018 Share #4 Posted January 31, 2018 hi, there might be an option but its kind of experiMENTAL if you use some unconventional settings you might be able to make a usb a internal drive accidentally happened here (see the picture where drive 21 is a usb flash drive) https://xpenology.com/forum/topic/9412-max-10-drives-in-dsm-61/?tab=comments#comment-80569 1 Quote Link to comment Share on other sites More sharing options...
Cr4z33 Posted February 1, 2018 Author Share #5 Posted February 1, 2018 12 hours ago, IG-88 said: hi, there might be an option but its kind of experiMENTAL if you use some unconventional settings you might be able to make a usb a internal drive accidentally happened here (see the picture where drive 21 is a usb flash drive) https://xpenology.com/forum/topic/9412-max-10-drives-in-dsm-61/?tab=comments#comment-80569 Thanks, might give it a look later today. Quote Link to comment Share on other sites More sharing options...
darrepac Posted April 18, 2021 Share #6 Posted April 18, 2021 Le 01/02/2018 à 10:06, Cr4z33 a dit : Thanks, might give it a look later today. Have you been successfully having an external drive? Quote Link to comment Share on other sites More sharing options...
ASLuis Posted March 21, 2022 Share #7 Posted March 21, 2022 Hello, finally is it possible? I need to atach some external disks by USB Thanks Quote Link to comment Share on other sites More sharing options...
