k3rmitou Posted January 29, 2018 Author Share #26 Posted January 29, 2018 just install the 5.2.5967 version with 5.5.5967 pat file ---> all ok access to dsmeg ok or user\lib\modules with the tg3.ko in it Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted January 29, 2018 Share #27 Posted January 29, 2018 Seems to me like a problem with the tg3 module on DSM 6.1. The best way would be to have serial logs during DSM 6.1 installation and after a reboot. Without those it is difficult to troubleshoot. Quote Link to comment Share on other sites More sharing options...
k3rmitou Posted January 29, 2018 Author Share #28 Posted January 29, 2018 I m lost coz think the install process is not complete. I can see files and folders on the hdd but not all of them like the fresh install i made (see above post) Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted January 29, 2018 Share #29 Posted January 29, 2018 As I said without logs we are blind. It doesn't matter if the install process is finished or not. What matters is to see what is going on during the install and for that you could use a serial cable (serial to usb) to check what is going on. Quote Link to comment Share on other sites More sharing options...
k3rmitou Posted January 29, 2018 Author Share #30 Posted January 29, 2018 need to buy one then thanx @Polanskiman Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 29, 2018 Share #31 Posted January 29, 2018 9 hours ago, Polanskiman said: Seems to me like a problem with the tg3 module on DSM 6.1 why? if the *.pat file downloaded and the loader starts to extract it the network was working as expected, maybe problems with the storage driver, the tg3 is often used for hp and dell systems (broadcom nic), never heard of problems so far @k3rmitou check if there is any bios update for that old (g5) system and just in case try a smaller max 1tb disk (in the hp specs there is 1tb max.) Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted January 30, 2018 Share #32 Posted January 30, 2018 7 hours ago, IG-88 said: why? if the *.pat file downloaded and the loader starts to extract it the network was working as expected, maybe problems with the storage driver, the tg3 is often used for hp and dell systems (broadcom nic), never heard of problems so far You are correct. I overlooked the logic! Still the boot logs would give us a more clear insight of what is happening. BTW he is already using a 128 go ssd crucial or a 500Go hdd for testing so I don't think it is a problem with the drive exceeding the HP max size specs. BIOS update is always a good thing. Quote Link to comment Share on other sites More sharing options...
k3rmitou Posted January 30, 2018 Author Share #33 Posted January 30, 2018 hi guys @IG-88, @Polanskiman bios is update to the latest and nic too. As i said before, i don't understand why the dsm system is not install on hdd like the 5.2.5967. Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted January 30, 2018 Share #34 Posted January 30, 2018 1 minute ago, k3rmitou said: hi guys @IG-88, @Polanskiman bios is update to the latest and nic too. As i said before, i don't understand why the dsm system is not install on hdd like the 5.2.5967. And as I said before without logs it is going to be difficult for us to tell. The problem could come from some storage driver or anything else. Quote Link to comment Share on other sites More sharing options...
k3rmitou Posted January 30, 2018 Author Share #35 Posted January 30, 2018 By the way how can see the log ,with the usb to serial adapter, of the dsm ?? Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted January 30, 2018 Share #36 Posted January 30, 2018 You need a serial to usb adaptor. https://www.google.co.th/search?q=serial+to+usb The serial port plugs into your XPEnology box, the usb port to your computer/laptop. Then you need a terminal running on your computer/laptop to see the boot logs when your XPEnology boots up. Make sure the serial port is enabled in your bios first. Your terminal should also be configured to 115200 bits per second. Quote Link to comment Share on other sites More sharing options...
