Trying to get my new server access outside the home network. Have activated host name and all working using port 5500, as 5000 already being used.  But i am getting a connection not secure error, which is stopping me access with my mobile DS photo app. I have tried using port 5001 which the port was made open, without success.
What am I doing wrong, any ideas?
To be accessible from outside your local network, PhotoStation needs port 80 (http) or port 443 (https) to be forwarded in your router. Personally I only open the secured port. PhotoStation does not use the same secured port as the GUI's access. Pay close attention to what is mentioned in DSM network settings:
If you are ever in doubt what port is needed you can look at DSM's list of service ports: https://www.synology.com/en-global/knowledgebase/DSM/tutorial/General/What_network_ports_are_used_by_Synology_services
You can also look in DSM's firewall to check what ports are being used for each service.
Also don't forget to configure PhotoStation accordingly:
There is another option where you could bypass all the above and that would consist of configuring your DSM as a VPN server and then accessing PhotoStation by VPN from DSPhoto. This is even more secure but it implies opening up a VPN connection each time you wish to access your photos through DSPhoto.
