ptodic Posted July 4, 2022 Share #26 Posted July 4, 2022 On 2/9/2022 at 7:19 PM, DSfuchs said: Happy Modding, my DS412+ is now prepared as RS814+ for DSM 8 Thanks for your pinout! So you are running DSM 7 on your DS412+ flashed as RS814+? Any issues with it? Would you mind sharing the flash file (remove your serial number or change to something else). Thank you. Quote Link to comment Share on other sites More sharing options...
FlorisVN Posted July 4, 2022 Share #27 Posted July 4, 2022 (edited) 7 hours ago, ptodic said: So you are running DSM 7 on your DS412+ flashed as RS814+? Any issues with it? Would you mind sharing the flash file (remove your serial number or change to something else). Thank you. I also wonder how this works ? And would be great to upgrade my ds1512+ to an ds1513+ since this one supports the DX510/DX513. The RS814+ won't support the DX510/513 at all.. Would be great if that would be possible ?? And what are the options I wonder for the DS1511+ , without going the xpenology route.. ? Edited July 4, 2022 by FlorisVN Quote Link to comment Share on other sites More sharing options...
FlorisVN Posted July 4, 2022 Share #28 Posted July 4, 2022 On 2/9/2022 at 7:19 PM, DSfuchs said: Happy Modding, my DS412+ is now prepared as RS814+ for DSM 8 Thanks for your pinout! Seems not I guess, release notes for DSM 7.1 : For the following models, DSM 7.1 will be the last upgradable version. XS Series: RS3413xs+, RS10613xs+, RS3614xs+, RS3614xs, RS3614RPxs, RC18015xs+, DS3615xs, DS2015xs Plus Series: DS2413+, DS1813+, DS1513+, DS713+, RS2414RP+, RS2414+, RS814RP+, RS814+, DS214+, RS815RP+, RS815+, DS2415+, DS1815+, DS1515+, DS415+, DS215+ Value Series: RS814, RS214, DS414, DS214, DS214play, DS114, RS815, DS1515,DS715, DS415play, DS115 J Series: DS213j, DS414slim, DS414j, DS214se, DS215j, DS115j, DS416se Quote Link to comment Share on other sites More sharing options...
apejovic Posted November 20, 2022 Share #29 Posted November 20, 2022 On 9/5/2020 at 3:27 AM, mc4ren said: So clearly there is a short circuit, but my skills are not good enough to find it. Could be that one or more Mosfets (U33 & U34) is burned too. Dont give up 👍 Check your PSU with another load instead of the PCB. Maybe the PSU is defect too. It will just damage more without that you notice it. Quote Link to comment Share on other sites More sharing options...
7up_ Posted March 5, 2023 Share #30 Posted March 5, 2023 (edited) Synology USB DOM image cloned to a generic USB DOM, with female socket swapped to match, fits and boots up normally. Special thanks to DSfuchs. Edited March 5, 2023 by 7up_ Quote Link to comment Share on other sites More sharing options...
chickey Posted March 23, 2023 Share #31 Posted March 23, 2023 On 2/9/2022 at 6:19 PM, DSfuchs said: Happy Modding, my DS412+ is now prepared as RS814+ for DSM 8 Thanks for your pinout! Sorry to drag up an old thread but do you have an image of the RS814+ with serial removed as just gotten a DS412+ Quote Link to comment Share on other sites More sharing options...
chickey Posted March 23, 2023 Share #32 Posted March 23, 2023 On 2/9/2022 at 6:19 PM, DSfuchs said: Happy Modding, my DS412+ is now prepared as RS814+ for DSM 8 Thanks for your pinout! Sorry to drag up an old thread but do you have an image of the RS814+ with serial removed as just gotten a DS412+ Quote Link to comment Share on other sites More sharing options...
chickey Posted March 23, 2023 Share #33 Posted March 23, 2023 On 2/9/2022 at 6:19 PM, DSfuchs said: Happy Modding, my DS412+ is now prepared as RS814+ for DSM 8 Thanks for your pinout! Sorry to drag up an old thread but do you have an image of the RS814+ with serial removed as just gotten a DS412+ Quote Link to comment Share on other sites More sharing options...
TN-Notebooks Posted March 23, 2023 Share #34 Posted March 23, 2023 You are are talking about DSM 7 Does anyone know how to extract the PAT Files ? With 7 Zip it is not possible any more - also not if its renamed. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #35 Posted March 23, 2023 Hello, only 4 files, source according to the screenshot, have to be replaced on the 2nd partition. However, you must already have the device-specific file "vender" for the RS814+ in vender_format_version=2. You can watch it on your own DSx16+, for example, and you're done. Good succeed! Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #36 Posted March 23, 2023 If the internal flash is still OK, you can simply perform the file operation in an SSH terminal session on the fly. After rebooting, it is already the new model with no hardware intervention. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #37 Posted March 23, 2023 If a replacement for the internal flash is required, I took an USB memory stick with the original "0xf400" IDs to boot via the front socket. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #38 Posted March 23, 2023 25 minutes ago, TN-Notebooks said: You are are talking about DSM 7 Does anyone know how to extract the PAT Files ? With 7 Zip it is not possible any more - also not if its renamed. Just do it exactly like the screenshot in No 35. If you try anything else, it will fail. This is the way. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #39 Posted March 23, 2023 1 hour ago, chickey said: Sorry to drag up an old thread but do you have an image of the RS814+ with serial removed as just gotten a DS412+ No problem, please see #35, the topic is never than ever. You MUST already have the device-specific file "vender" for the RS814+ in vender_format_version=2. You can watch it on your own DSx16+, for example! Quote Link to comment Share on other sites More sharing options...
chickey Posted March 23, 2023 Share #40 Posted March 23, 2023 2 minutes ago, DSfuchs said: No problem, please see #35, the topic is never than ever. You MUST already have the device-specific file "vender" for the RS814+ in vender_format_version=2. You can watch it on your own DSx16+, for example! Hi, it was more where to source the vender specific file for the RS814+. I've managed to get it working by manually amending the files and doing a manual installation of the .pat for the RS814+ it was a bit broken since filestation and some other packages were failed and wouldn't repair so i did a reset and then used a slightly newer DSM 7.1 pat file for the RS814+ and it's now working ok. Shame there isn't a repository of the USB boot images with the serial number removed. I also bought a DS716+ as faulty and i think it's the USB DOM image causing the problem with it. Quote Link to comment Share on other sites More sharing options...
TN-Notebooks Posted March 23, 2023 Share #41 Posted March 23, 2023 37 minutes ago, DSfuchs said: Just do it exactly like the screenshot in No 35. If you try anything else, it will fail. This is the way. Misunderstood How to extract the PART File to get all the Data - just download the PAT File and extract is what i need - for best on a Windows System -- in Post 35 it is extracted already. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #42 Posted March 23, 2023 DS716+ great! So we can do two mosquitoes with one stone. We can easily fix the 716+ and at the same time we get a vender in version 2. Just sell me, reversal possible, your defective module/NAS or a photo of the device sticker and proof of purchase as a private message. Your experiment will not work because you cannot install/unlock business packages. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #43 Posted March 23, 2023 2 minutes ago, TN-Notebooks said: Falsch verstanden So extrahieren Sie die PART-Datei, um alle Daten zu erhalten - laden Sie einfach die PAT-Datei herunter und extrahieren Sie, was ich brauche - am besten auf einem Windows-System -- in Post 35 ist es bereits extrahiert. No, in #35 it is only open with 7zip! Rename it to the suffix ".tar" and it can also be done directly in a "Midnight Commander" session via the SSH method. Quote Link to comment Share on other sites More sharing options...
TN-Notebooks Posted March 23, 2023 Share #44 Posted March 23, 2023 Rename it to .tar works only up to DSM 7.0.1 but not with DSM 7.1 and up see also a discussion on the Syno Forum https://www.synology-forum.de/threads/dsm-7-1-42661-extrahieren.121411/ Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #45 Posted March 23, 2023 Sorry, that's not the way! We only talk about model upgrade, and manufacturer's official way for OS update/upgrade. All approaches here with DSM7 are scrap! Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #46 Posted March 23, 2023 To fix a module of a DSM7 install, I always go through the 25556 stand with a dummy hard drive for lifting up to DSM7.x 1 Quote Link to comment Share on other sites More sharing options...
chickey Posted March 23, 2023 Share #47 Posted March 23, 2023 59 minutes ago, DSfuchs said: DS716+ great! So we can do two mosquitoes with one stone. We can easily fix the 716+ and at the same time we get a vender in version 2. Just sell me, reversal possible, your defective module/NAS or a photo of the device sticker and proof of purchase as a private message. Your experiment will not work because you cannot install/unlock business packages. You've totally lost me there, no idea what your going on about. For the last part i'm not trying to unlock business packages just to get it to see the hard disks. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #48 Posted March 23, 2023 Achso, you are apparently on a data rescue way. In order to read/write only the data of the Btrfs-partition, I simply connect the hard drives to my Windows laptop via USB. Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #49 Posted March 23, 2023 11 minutes ago, chickey said: You've totally lost me there, no idea what your going on about. For the last part i'm not trying to unlock business packages just to get it to see the hard disks. Sorry, I must have misunderstood. I thought the problem was a defective DS716+ Quote Link to comment Share on other sites More sharing options...
DSfuchs Posted March 23, 2023 Share #50 Posted March 23, 2023 If the air burns, I once managed to boot a battered internal flash module like this: 1. "Bake" at 100 degrees Celsius for an hour and let cool. 2. Then in the freezer for a few hours. Maybe you can do without point 1. Quote Link to comment Share on other sites More sharing options...
