spec:
1st notebook:
name: asus eee pc 1001ha
BIOS: latest (1601)
LAN driver: Atheros AR8132
Chipset: Intel 945GSE Express
CPU: Intel atom N270
2nd notebook:
BIOS: some old - didnt upgrade
LAN: intel
So...
the only working configuration is nanoboot with dsm 5.0. But i need 5.1+ to use "DS File photo sync" app.
5.2 needs x64 cpu.
6.x versions stoping boot at "Screen will stop updating shortly..."
I tried to:
 - update bios to latest
 - turn off additional devices
 - turn on/off NIC
 - put drivers into kernel
 - use 2nd notebook
The diffrence between 1st and 2nd notebook at screen "Screen will stop updating shortly..." is:
 - 1st is not "talking" with router
 - 2nd is "talking"
anyway both are not getting IP adress(dhcp enabled). Tried to run ubuntu live 12.04, 14.04 and 16.04 - network worked w/o problems.
As i said - it works on dsm 5.0 perfectly but i want to have photos sync from my phone via LTE/wifi, so i need 5.1 + dsm.
5.2 worked find but only on VM's (virtual box, hyperv)
Any ideas?
Edited by Estovitch
forget smtg
