grodzuik
MAX 10 Drives in DSM 6.1
Hello
I've built an Xpenology system with a 2u server enclosure the has 12 hot swap drive bays connected to 2 HBA's with 8 drives on HBA1 and 4 drives on HBA2.
I start by connecting 1 drive and it shows up in the DSM. Connect a second drive and it shows up in the DSM. This continues to work great up to the 10th drive.
Once I connect the 11th drive, it doesn't show up in the DSM and the 12th drive also will not show up in the the DSM. Always only 10 drives.
I've tried with the default settings and then by modifying the synoinfo.conf files in /etc and /etc.defaults all to no avail. Always max 10 drives no matter what I do.
Any ideas or solutions you could suggest? I'm using jun's boot loader v.1.02b and img file ds3615.
Thank-you!
Share this post
hi,
the numbers to change in synoinfo.conf are binary and then converted to hex and there is more then one number to change
the numberds depend on the amount of sata ports you have (dsm default is 12)
you say 2 hba's (same type/brand?) so each 8 ports and there are onboard sata ports (2,4,6?) so the amount of satat ports will bei x+8+8 (dsm usualy starts counting with the onboard ports) if the number is to small then some ports of your 2nd hba will be missed out and you will exactly see ehat you describe
you should watch this video to get the numbers right and if unsure about the number of sata ports make it 24 and calculate the numbers for esata and usb for 24 sata ports
https://www.youtube.com/watch?v=2PSGAZy7LVQ
Share this post
how do the drives appear in storage manager (ie is hba drive 1 dsm drive 1) ? If you work our the connections it can help diagnosing this.
Also, following @IG-88 comment, disable on board sata ports so that the only controllers are the HBAs, that way your 12 available drive connections will match the 12 limit and you wont need to alter synoinfo.conf
Share this post
Without modifying the synoinfo.conf file I actually only get 6 disks visible in the storage manager with a default install. See attached photo.
I achieved 10 drives by modifying both synoinfo.conf files. I modified max drives, and the 3 hex fields for internal, usb and esata,
The 2 HBAs are identical allowing for 8 drives per HBA. I have a super micro motherboard and have disabled the onboard sata ports.
The HBAs are  IT Mode Genuine LSI 9211-8i SAS SATA 8-port PCI-E Card.
I also tried to append SataPortMap=22 and get 10 drives. Trying SataPortMap=12 got me to 11 drives, but I can't get to 12 drives.
5a050be747923_ScreenShot2017-11-09at7_10_58PM.png.ac08a9058e6f703dd01a1f591e0d60e0.png5a050bfe6f67c_ScreenShot2017-11-09at7_10_26PM.png.067f4a71923d3c218c3fc094c6606b1d.png
Share this post
Forgot also to say, from default install 6 drives appear in storage manager and the other 6 appear as esata.
See attached picture5a050de5b9ddc_ScreenShot2017-11-09at7_24_13PM.thumb.png.3ef8318b1398e0fb7812534558683925.png
Share this post
what values did you use in synoinfo.conf?
for 16 internal disks (no esata) and 4 usb it has to this
maxdisks=16
esataportcfg=0x0
usbportcfg=0xf0000
internalportcfg=0xffff
if using sataportmap then it will be the amount of ports for each controller in dezimal in a row like 688 (6 internal, 8 port hba, 8 port hba) or 88 (hba, hba) when internal is diabled, but usualy thats not needed
PS:what systemboard?
Edited by IG-88
Share this post
Now trying image file for DS3617xs and pat file for DSM 6.13. 8 drives immediately visible in storage manager and 4 drives are being interpreted as esata.
Growing extremely frustrated with xpenology.
5a075ef0519c2_ScreenShot2017-11-11at1_34_12PM.thumb.png.a3993d45d03ae152d9a482bf14ba8a9b.png
Share this post
why should it be different with 3617, its all the same dsm 6.1 and how it works
did you tryed the 16 disk settings?
the board has 6 onboard sata + 8+8 sata from the hba's and 9 usb
you can try this config, it should cover all disks even if the onboard sata are counted
maxdisks=22
esataportcfg=0x0
usbportcfg=0x‭7FC00000‬
internalportcfg=‭0x3FFFFF‬
Share this post
Well, I can't friggin believe it! THAT WORKED!
I used your exact config settings, edited both etc/synoinfo.conf and etc.defaults/synoinfo.conf
THANKYOU THANKYOU THANKYOU
 5a077ef10faa2_ScreenShot2017-11-11at3_50_34PM.thumb.png.4d76e40a6d6bf853ea8f15a011d356be.png5a077f2c64dee_ScreenShot2017-11-11at3_51_54PM.thumb.png.3e74ebc93e48c20bcb4e25d79cb37641.png
Share this post
kind of ok for the hdd's but there is a usb drive that should'nt be there as hdd, so there ist still something not right
try to enable all 6 onboard sata ports, the disk count of 22 is expecting them all to be present
atm it looks like as 4 of the sata ports are enabled, your bord has 2+4 onboard sata ports (2 x sata3, 4 x sata2, manual page 2-38)
as 2 are missing the count of 22 gets the first 2 usb ports as disks (the last 2 positions in the gui, including your boot media, a 8GB usb flash drive)
if you want to leave it this way the disk count has to be reduced to 20 and the values have to be changed that way
Edited by IG-88
Share this post
yes that is the boot loader usb. i saw that and was wondering why that was showing up.
ill try your suggestion.
Share this post
7 hours ago, grodzuik said:
So I enabled the 6 sata ports on the MB and rebooted. USB still is listed as a HD.
I had some strange results editing the hex settings but what I found seemed to work was to 'pad out' with 0's the values so the string length of the hex values were all the same and also ensure that no values > 0 appeared at the same character position in the strings. Taking @IG-88 example and altering to;
esataportcfg=0x000000000
usbportcfg=0x‭7FC000000‬
internalportcfg=‭0x0003FFFFF‬
I think somehow this tell the system that there are no 'overlaps' in the configuration when it reads the various drive types
Share this post
So I've gotten it to the point that the USB drive is no longer visible as a HD and have 12 HD showing up in storage manager.
I was also looking at my MB bios and found where to disable the onboard sata ports, but strange thing I realized was that the bios
setting is only disabling the 2 x SATA3 ports and leaving the 4 x SATA2 ports active.
Thanks for the suggestion sbv3000 about padding. It makes sense to me.
Share this post
if you can find where to disable the other 4 on board sata ports that would be 'neater' as it would mean no need to edit synoinfo.conf (which can be overwritten with some updates causing a volume/raid crash).
Share this post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
