IG-88
problem getting 916+ to work in VirtualBox
hi,
does anyone sucseeded in using 916+ in VitualBox? (test system is skylake, so it does boot/work on a processor/basic level)
the vm configuration that works for 3615/3617 (IDE boot jun's loader and SCSI for DSM disks) does not work for 916+, it does not find disks, also buslogic or SAS do not work only SATA disk is found but after starting to copy DSM from the pat file it stops with error 21 (sysnology assistent)
other funny fthing is if no disk is found then the nic gets a dhcp adress (can bee seen in serial console and log) but the systerm in synology assistent  (and browser) is reachable under a APIPA address 169.254.x.y (x,y are the values from the dhcp address it used), if the webinterface ist opend it shows that no disk was found, but that just odd and of no real value as without disks found its no working configuration
here is the log of sata disk with unsuccsessfull copy of dsm (md5 of dsm is ok, tryed 15047 and 15152, also tryed 1.02a2 and 1.02b)
tryed migration of 3615 working vm/config and clean install with empty 100GB dynamic disk, same error (creation of partitions work, "using" them does not)
log
Jan  1 00:00:13 findhostd: ninstaller.c:1571(ErrFHOSTReceiveUpgradeFile) cRead=[4], ulFileSize=[218398720]
Jan  1 00:00:14 findhostd: Estimated time =[1]
Jan  1 00:00:14 findhostd: ErrFHOSTTcpResponseCmd: cmd=[5], ulErr=[0]
Jan  1 00:00:14 findhostd: Starting ErrFHOSTDoUpgrade()...
Jan  1 00:00:14 findhostd: Remove /tmpData/upd@te...cmd=[/bin/rm -rf /tmpData/upd@te > /dev/null 2>&1]
Jan  1 00:00:14 findhostd: ninstaller.c:2372(ErrFHOSTDoUpgrade) retv=[0]
Jan  1 00:00:14 findhostd: ErrFHOSTDoUpgrade() Done
Jan  1 00:00:14 findhostd: query prog, szBuf = ^R4VxSYNONI^A^D^A
Jan  1 00:00:14 findhostd: alz=[0], prg=[0], cfg=[0], retv=[0]
Jan  1 00:00:14 findhostd: Create /tmpData/upd@te...cmd=[/bin/mkdir -p /tmpData/upd@te > /dev/null 2>&1]
Jan  1 00:00:14 findhostd: Untar /tmpData/upd@te.pat...cmd=[/bin/tar xpf "/tmpData/upd@te.pat" -C /tmpData/upd@te > /dev/null 2>&1]
Jan  1 00:00:14 kernel: [   68.824062] hrtimer: interrupt took 4916523 ns
Jan  1 00:00:15 findhostd: ErrFHOSTCheckUpgradeFile: Remove /tmpData/upd@te.pat...
Jan  1 00:00:15 findhostd: Verify codesign of [/tmpData/upd@te]...
Jan  1 00:00:16 findhostd: query prog, szBuf = ^R4VxSYNONI^A^D^A
Jan  1 00:00:16 findhostd: alz=[0], prg=[0], cfg=[0], retv=[0]
Jan  1 00:00:16 findhostd: Verify checksum of [/tmpData/upd@te]...
Jan  1 00:00:17 findhostd: Pass checksum of /tmpData/upd@te...
Jan  1 00:00:17 findhostd: ErrFHOSTTcpResponseCmd: cmd=[5], ulErr=[0]
Jan  1 00:00:17 updater: updater.c:5773 Start of the updater...
Jan  1 00:00:17 updater: updater.c:2746 orgBuildNumber = 15047, newBuildNumber=15152
Jan  1 00:00:17 updater: updater_util.c:49 fail to read company in /tmpRoot//etc.defaults/synoinfo.conf
Jan  1 00:00:17 updater: file_check_key_value.c:25 SLIBCFileGetKeyValue(runccc) failed [0x0900 file_get_key_value.c:29]
Jan  1 00:00:17 updater: updater.c:6028 ==== Start flash update ====
Jan  1 00:00:17 updater: updater.c:6032 This is X86 platform
Jan  1 00:00:17 updater: boot/boot_lock.c(227): failed to mount boot device /dev/synoboot2 /tmp/bootmnt (errno:2)
Jan  1 00:00:17 updater: updater.c:5583 Failed to mount boot partition
Jan  1 00:00:17 updater: updater.c:2645 No need to reset reason for v.15047
Jan  1 00:00:17 updater: updater.c:6549 Failed to accomplish the update! (errno = 21)
Jan  1 00:00:17 findhostd: ninstaller.c:1779 Executing [/tmpData/upd@te/updater -v /tmpData > /dev/null 2>&1] error[21]
Jan  1 00:00:17 findhostd: ninstaller.c:196 Mount partion /dev/md0 /tmpRoot
Jan  1 00:00:17 findhostd: ninstaller.c:1748 Moving updater for configuration upgrade...cmd=[/bin/mv -f /tmpData/upd@te/updater /tmpRoot/.updater > /dev/null 2>&1]
Jan  1 00:00:17 findhostd: ninstaller.c:225 umount partition /tmpRoot
Jan  1 00:00:17 findhostd: ErrFHOSTCleanPatchDirFile: After updating /tmpData/upd@te...cmd=[/bin/rm -rf /tmpData/upd@te > /dev/null 2>&1]
Jan  1 00:00:17 findhostd: ErrFHOSTCleanPatchDirFile: Remove /tmpData/upd@te.pat...
Jan  1 00:00:17 findhostd: ErrFHOSTDoUpgrade(2355): child process failed, retv=-21
Jan  1 00:00:17 findhostd: ninstaller.c:2363(ErrFHOSTDoUpgrade) err=[-1]
Jan  1 00:00:17 findhostd: ninstaller.c:225 umount partition /tmpData
Jan  1 00:00:18 findhostd: query prog, szBuf = ^R4VxSYNONI^A^D^A
Jan  1 00:00:18 findhostd: alz=[0], prg=[0], cfg=[0], retv=[-21]
Jan  1 00:00:18 findhostd: ninstaller.c:1869(ErrFHOSTUpdaterProgress) retv=-21
Jan  1 00:00:19 getty[5504]: console: TCGETS: Input/output error^M
Jan  1 00:00:20 findhostd: query prog, szBuf = ^R4VxSYNONI^A^D^A
Jan  1 00:00:20 findhostd: alz=[0], prg=[0], cfg=[0], retv=[-21]
Jan  1 00:00:20 findhostd: ninstaller.c:1869(ErrFHOSTUpdaterProgress) retv=-21
Jan  1 00:00:20 findhostd: ninstaller.c:1364(ErrFHOSTNetInstaller) read socket fail, ret=[0], errno=[10]
Jan  1 00:00:20 findhostd: ninstaller.c:1455(ErrFHOSTNetInstaller) retSel=[1] err=(10)[No child processes]
Jan  1 00:00:20 findhostd: ninstaller.c:721 Dev: sda, DiskPath: /dev/sda, Partition version: 8
Jan  1 00:00:20 findhostd: ninstaller.c:196 Mount partion /dev/md0 /tmpRoot
Jan  1 00:00:20 kernel: [   74.779589] EXT4-fs (md0): barriers disabled
Jan  1 00:00:20 kernel: [   74.787905] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
Jan  1 00:00:20 findhostd: ninstaller.c:225 umount partition /tmpRoot
Jan  1 00:00:20 kernel: [   74.832806] EXT4-fs (md0): barriers disabled
Jan  1 00:00:20 kernel: [   74.840000] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
Jan  1 00:00:20 kernel: [   74.851958] EXT4-fs (md0): barriers disabled
Jan  1 00:00:20 kernel: [   74.860958] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
Jan  1 00:00:20 findhostd: ninstaller.c:538 failed to get upnpmodelname from [/tmpRoot/etc.defaults/synoinfo.conf].
Jan  1 00:00:20 findhostd: ninstaller.c:545 failed to get buildnumber from [/tmpRoot/etc.defaults/VERSION].
Jan  1 00:00:20 findhostd: ninstaller.c:552 failed to get productversion from [/tmpRoot/etc.defaults/VERSION].
Jan  1 00:00:20 findhostd: ninstaller.c:554 failed to get majorversion from [/tmpRoot/etc.defaults/VERSION].
Jan  1 00:00:20 findhostd: ninstaller.c:557 failed to get minorversion from [/tmpRoot/etc.defaults/VERSION].
Jan  1 00:00:20 findhostd: lib/system/system_platform_get.c:35 failed to get unique from /tmpRoot/etc.defaults/synoinfo.conf errno=[0x0900 file_get_key_value.c:29]
Jan  1 00:00:20 findhostd: ninstaller.c:569 failed to get platform from [/tmpRoot/etc.defaults/synoinfo.conf].
Jan  1 00:00:20 findhostd: lib/system/system_max_align_get.c:86 [/tmpRoot/.system_info/pgsql_alignment] doesn't exist, check model name for alignment
Jan  1 00:00:20 findhostd: lib/system/system_endian_get.c:61 [/tmpRoot/.system_info/endian] doesn't exist, check model name for endian
Jan  1 00:00:20 findhostd: lib/system/system_bit_get.c:57 [/tmpRoot/.system_info/bits] doesn't exist, check model name for bits
Jan  1 00:00:20 findhostd: ninstaller.c:602 fail to get admin port from /tmpRoot/etc/synoinfo.conf... try another way
Jan  1 00:00:20 findhostd: ninstaller.c:482 /tmpRoot/usr/syno/etc/www/DSM.json not exist
Jan  1 00:00:20 findhostd: ninstaller.c:605 fail to get admin port from /tmpRoot/usr/syno/etc/www/DSM.json
Jan  1 00:00:20 findhostd: ninstaller.c:633 failed to get nvr key from [/tmpRoot/etc.defaults/synoinfo.conf].
Jan  1 00:00:20 findhostd: ninstaller.c:783 fail to read [unique] from [/tmpRoot//etc.defaults/synoinfo.conf]
Jan  1 00:00:20 findhostd: ninstaller.c:851 unique not match
Jan  1 00:00:20 findhostd: ninstaller.c:1311 SYSTEM_NORMAL, [Recoverable=0]
Jan  1 00:00:20 findhostd: ninstaller.c:1244(FillUpgradeVolumeInfo): gszUpgradeVolDev = /dev/md0
Jan  1 00:00:20 findhostd: ninstaller.c:1245(FillUpgradeVolumeInfo): gszUpgradeVolMnt = /tmpData
Jan  1 00:00:20 findhostd: ninstaller.c:1327 gblSupportRaid: 1, gSysStatus: 1, gblCreateDataVol: 0, gblSystemRecoverable: 0
Jan  1 00:00:20 findhostd: ninstaller.c:1473(ErrFHOSTNetInstaller)
Jan  1 00:00:20 findhostd: Return from TcpServer()
Jan  1 00:00:29 getty[5557]: console: TCGETS: Input/output error^M
Hide
Edited by IG-88
Share this post
@IG-88
when I saw your post I didn't have time to write and than I've forgotten about it.
Back home I have an OMV server (latest OMV v4) with Fujitsu-MoBo (intel nic) and haswell cpu (i5-4590S with 4 cores). Under OMV I've installed virtualbox from the official OMV repo and set it up according to this how-to here. I guess I didn't install the extensions pack and for the mac address I have one from an original DS916+ (as well the serial number).
I hope that a link to an another forum is allowed.
Also you can see me Virtualbox settings and how DSM looks like under Virtualbox.
For me it was a long try and error to get the DS916 system definiton to work. So I don't know exactly anymore what I did and where I got the DS916 synoboot.vmdk. The second virtual HDD is the data drive "Syno-DS916plus2.vhd".
Unfortunately under DSM the synoboot.vmdk shows up and I didn't have time to check how I can hide it.
I hope I could help you further
Edited by Huberer
Share this post
hi,
thanks, that helped to find the problem
i had a IDE controller with the bootimage (jun's loader), that works with 3615/3617 (and you don't see the disk after installation) but does'nt with 916+
with sata as boot controller and first disk the bootloader image and 2nd the data disk it does work
now i can test new compiled 916+ drivers for a new extra.lzma
Share this post
Hello,
good to hear that it works. And also good to hear that you test new compiled 916+ drivers. Maybe with that I can get my Intel Nur with DS916 bootloader to work. Looking forward to test it.
Share this post
