synologix Posted October 24, 2017 #1 Posted October 24, 2017 Hi, - I have a DVB-Sat-Card in my System - Until yet i have used ESXI on my System and 2 VMs 1. XPEnology 2. VDR Server - With latest DSM we have a QEMU based VM inside the Synology My Idea is Stopping my ESXI Project and Using XPEnology as Baremetal with the Buildin Synology VM The project stops on the point that Synology has not enabled Passthrough. But based on the knowledge they use QEMU / libvirt it should be possible to mod the VM config files Has Anybody tried to modify the Settings of GUI generated virtual machines with modding the config files on file Base? i have checked for IOMMU working or not (yes it works): dmesg | grep -e DMAR -e IOMMU Running Service: /var/packages/Virtualization/target/usr/local/bin/libvirtd -d --listen --config /etc/libvirt/libvirtd.conf /usr/local/bin/qemu-system-x86_64 -name fabf0876-7580-............................ so checked on console : qemu-system-x86_64 --h anybody knows where the config parameters are stored and how to modify / expand it? Best Regards Synologix Quote
haldi Posted October 24, 2017 #2 Posted October 24, 2017 9 hours ago, synologix said: The project stops on the point that Synology has not enabled Passthrough. But based on the knowledge they use QEMU / libvirt it should be possible to mod the VM config files They do at least support USB Passtrough now. But hey, if you manage to get a PCI-E Passtrough working.. i've got a old Quadro lying around here, and my HP Gen8 got a free slot, so that would be nice. Quote
sramshaw Posted September 18, 2024 #3 Posted September 18, 2024 Hi, I have tried to do similar things on a Synology DSM v7.2. , and landed here so I thought I might leave some help for others interested in such topics. Pci passthrough is best evaluated by: - creating and running a VM so that libvirt loads all drivers (as observed in service pkg-libvirtd 's definition ) - connecting via ssh and checking capabilities reported by libvirt with the command virt-host-validate In my case on DS1621+ I see that the system is capable of PCI passthrough, it is only the hypervisor (DSM's VMM) that does not expose the feature. Instead of using VMM to create the boot time PCI passthrough, I resorted instead to have a hotplug of PCI device approach, which means modifying the VM once it is running. This is not a perfect solution, but seems to work one time after each NAS (re)boot. More on this at https://github.com/sramshaw/pci_coral_on_synology Quote
