Synology DS3612xs - DSM 4.2 build 3202
I just installed XPEnology on an Intel S1200BTLR with a Xeon E3 and 32Gb of Ram. (system was to be a Windows server 2012 Essentials with storage spaces, but as I'm not happy with the performance of storage spaces, I'm trying different things.)
The two NIC's Intel 82574L adn Intel 82579 are seen and configured correctly.
There is a slight problem though, I have 3 IBM Serveraid M1015 controller that are flashed to LSI 9220-8i wich turned them into LSI SAS2008 HBA's basically.
This should render them transparent to the system, but DSM doesn't see any of the disks attached to them.
Could anyone help me figure out how I can make the system see this HBA's and the disks attached to them ?
Thank you.
Sorry for cross posting you can remove the post in the "Installing XPEnology in PC" section.
Hello !
Congrats for this job on DSM ;o) !!
but I am unable to find my machine with synology assitant.
it appears that my network card does not work with tis rom
this is as XFX 8200 MB, I am trying to find out which network chip it holds ...
foud ! the network controller is a Marvell® 88E8056 .... could it work with this DSM image ? thanks !
Thansk for yout help !
;oD !
Hello !
;oD !
Hi there!
Try the ++ version that is here
viewtopic.php?f=2&t=41
Give me a feedabck.
Hi there!
Give me a feedabck.
Hello ! thanks for your reply !
I have tested this version too .; no more success.. the network light on the MB don't blink,
and on the screen it prompts me to log with a user .... !?
Regards.
Your bios settings are by default?
What is the screen on the syno saying? (if you pluged a screen!)
Hi there!
Give me a feedabck.
Regards.
bios setting are by default : Yes
the screen says : "Diskstation login :"
the light on the lan port does not show any lights
and my usb keyboard does not work.... but it works in the bios..
OK so it loads OK. What you expected at the begining is right i think... it is probably a driver issue has there are no blinking! Sorry!
No way to solve this ??...
It depends on your level of linux knowledge... compiling kernel...
I am digging into that as we speak but it does not seem simple for a newbie like me!
Do you have a spare PCI card to test?
I have never compiled a kernel fron now ... perhaps i'll be the first ^^
and I have no spare card, no :-\ ...
Marvel YUKON lan controllers seems to be supported by the 4.1-2668++ version ...
my chip is a yukon one ...
what could be the problem ?
some ideas ?
Thanks
If it loads OK with the ++ version but the LAN card is not blinking on both parts (PC + HUB/Routeur) then it will never work...
Are you sure the bios is on default settings?
Did you update the bios to latest version?
Did you check the cable? Change with another one?
Did you check that the LAN card is working (try a live UBUNTU CD??)
Did you do an offering or a sacrifice to computer god? :lol:
some ideas ?
Thanks
3202 seens to be not support your lan chips
i have tested realtek pci 8168,the lan chips also not work probarly in 3202.
Most Realtek PCI 8168 NIC need to use r8169.ko
thx for your help
some ideas ?
Thanks
the lan card works fine with another OS (freenas, other linuxes, win$ ...), with the same cable ^^
the bios is in the latest version....
I will burn some old processors in my garden and will make a dance for the hardware ancesters ... good idea ^^
RTL8169 - not working
D-Link DGE-530T rev B1 (Marvell 88E8001-LKJ1) - no link, no leds
D-Link DGE-528T rev A1 (D-link DLG10028A) - linked, but no ping, leds always on
noname gigabit cards from ebay on the Realtek RTL8111E, DL - no link, no leds
M/b Intel D525MW, DSM 4.2 build 3202
:lol::lol::lol::lol:
Nice joke... but sorry to hear that it is not working my friend...
Someone needs to recompile a news kernel with drivers + New DSM!!!
Your MB have one PCI slot and LOM need r8169.ko, all your list card are not supported in my build.
The fastest way to you is: insert Intel PRO-1000 PCI series NIC (e1000)
Thanks for this information !
I will try to find it out from my local grocery :wink:
hi.
my old system use below
IDE controller ALi M5229 PCI Bus Master IDE Controller
SCSI/RAID controller D347PRT SCSI Controller
SCSI/RAID controller ULi SATA/RAID Controller (M1573)
is it possible?
dsm 4.1 is not know my hdd system.
check and reflect next comfile..
