XPEnology 24TB/36TB Recipe (Check for Compatibility Issues)
I've been playing with some numbers and checking compatibility lists and I was hoping I could get a second (or third) opinion. I need something fast and reliable as an iSCSI target, and I've put together a recipe that should be compatible with XPEnology. My biggest concern is the RAID card and the integrated networking on the motherboard, but if anyone sees something I might be overlooking, please let me know.
Thanks.
8 x Seagate Constellation CS ST3000NC002 3TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive -- $1,919.92 ($239.99 each)
1 x SeaSonic X Series X650 Gold ((SS-650KM Active PFC F3)) 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD -- $129.99
1 x Intel S1200BTSR Micro ATX Server Motherboard LGA 1155 DDR3 1333 -- $189.99
1 x 3ware 9650SE-12ML SGL PCI Express x8 SATA II (3.0Gb/s) Controller Card -- $659.99
1 x Rosewill RSV-L4411 Black Metal/ Steel, 1.0 mm thickness, 4U Rackmount Server Chassis, 12 SATA Hot-swap Drives -- $159.99
3 x 3ware CBL-SFF8087OCF-05M 1 Unit of .5M Multi-lane Internal (SFF-8087) Serial ATA Breakout Cable -- $59.97 ($19.99 each)
1 x Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 ECC Unbuffered Server Memory Intel Model KVR13E9K2/8I -- $69.99
1 x Intel Xeon E3-1220 V2 Ivy Bridge 3.1GHz (3.5GHz Turbo) LGA 1155 69W Quad-Core Server Processor BX80637E31220V2 -- $214.99
Total: $3,404.83
Honestly I can't help you, but if you allow me to give my opinion, I would consider to get original hardware and buy DS1812+... it's just about 800-900€ , and you will have official support / warranty and system upgrades.
Despite XPEnology is great, it doesn't have support and still has some hardware compatibility issues. This is more oriented to home nas... and 36TB doesn't look like "home" :grin:
