chury721 Posted November 29, 2013 Share #1 Posted November 29, 2013 Hi to all, I have a problem with RAID5 (4x2TB HDD). RAID is volume ext4. When I give ext4 repair volume and repair will (one day) to 100%, restarts and it is again the same. System is mode Read-only. It's probably a mistake volume structure Does anyone have any advice? Thx TuxDiskStation> sfdisk -l /dev/sda1 256 4980735 4980480 fd /dev/sda2 4980736 9175039 4194304 fd /dev/sda3 9437184 3907015007 3897577824 f /dev/sda5 9453280 3907015007 3897561728 fd /dev/sdb1 256 4980735 4980480 fd /dev/sdb2 4980736 9175039 4194304 fd /dev/sdb3 9437184 3907015007 3897577824 f /dev/sdb5 9453280 3907015007 3897561728 fd /dev/sde1 256 4980735 4980480 fd /dev/sde2 4980736 9175039 4194304 fd /dev/sde3 9437184 3907015007 3897577824 f /dev/sde5 9453280 3907015007 3897561728 fd /dev/sdf1 256 4980735 4980480 fd /dev/sdf2 4980736 9175039 4194304 fd /dev/sdf3 9437184 3907015007 3897577824 f /dev/sdf5 9453280 3907015007 3897561728 fd /dev/md01 0 4980351 4980352 0 /dev/md11 0 4194175 4194176 0 Error: /dev/md2: unrecognised disk label get disk fail /dev/sdu1 63 32129 32067 83 TuxDiskStation> vgdisplay --- Volume group --- VG Name vg1000 System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 4 VG Access read/write VG Status resizable MAX LV 0 Cur LV 1 Open LV 0 Max PV 0 Cur PV 1 Act PV 1 VG Size 5.44 TB PE Size 4.00 MB Total PE 1427328 Alloc PE / Size 1427328 / 5.44 TB Free PE / Size 0 / 0 VG UUID Ea0177-I7SU-60x3-GRvg-g3iN-Q2kQ-Hjtx4A Link to comment Share on other sites More sharing options...
chury721 Posted November 30, 2013 Author Share #2 Posted November 30, 2013 Problem solved fsck.ex4 ANSWER: $> syno_poweroff_task $> vgdisplay $> vgchange -ay vg1000 $> fsck.ext4 -v -f -y /dev/vg1000/lv Link to comment Share on other sites More sharing options...
