Hi, I'm not sure if this is the correct part of the forum, but here we go:
I have set up an XPenology server. I used version 5.2 because it's simple to set up and as far as I'm aware I don't need any additional features.
My problem is that I have a large number of IDE/PATA hard drives that I want to use in the system. I've compiled and installed the correct modules and they seem to work fine in the system until I reboot. Every time I reboot, the IDE drives are dropped from the configuration. They still show up in the storage manager, but their status is changed to "not initialized" and they're dropped from the raid volume. It happens with all drives attached to both IDE controllers in the system.
How do I faut find this?
It looks likes your ide drives are somehow losing their DSM partition information
Can you give some more information about your mobo/ide controllers and number of drives
Did you try 5.2 loader 'as is' and your IDE controllers to see if the built in modules covered your hardware?
You could look at your dmesg raid/drive output for the various scenarios ('as is' 5.2, your modules added, after reboot with lost array) to compare and see if there are errors in the disks/drivers and raid build process and system partitions
The motherboard is an Asus P5Q SE, with a core2duo cpu and 4gb ram. I've recently used the computer for a different purpose, and it is perfectly stable on windows 7. I have however replaced the PSU with a more powerful unit due to the number of hard drives. I have checked memtest86+ since then and got no errors. Only a short run though, but on the motherboard I first used I got serveral within the first minute, even though DSM seemed stable.
The on board ATA controller is a Marvell 88SE6102
In addition I have a highpoint HPT370A controller
There is also a SIL3114 SATA controller in the computer, but no drives attached yet.
Neither of these were covered by the built in modules, so I built my own modules for them (by cross compiling from an ubuntu virtual machine on my windows 7 work station), and set them to load at boot by placing a file in /usr/syno/etc/rc.d
There may be a couple un-neccessary modules being loaded, due to migration from a different motherboard, and I may have forgotten to remove what is no longer needed.
Yesterday after posting I tried upgrading to 6.02, to see if it would solve the problem. The bootloader however does not support my network interface (Atheros L1E) it seems, so I'm back to 5.2 for now.
these ar my results from running dmesg(right now there are no drives attached to the Marvell on board ATA controller, and the HPT only has drives on one of its two ports). It seems that the connected ATA drives are ATA 13.0 and 13.1 this is after reboot with resulting ATA drives dropped from array:
dmesg
[   30.342695] md/raid:md5: device sde8 operational as raid disk 1
[   30.343066] md/raid:md5: allocated 5394kB
[   30.350026] md/raid:md5: raid level 6 active with 3 out of 5 devices, algorit
hm 2
[   30.350031] RAID conf printout:
[   30.350032]  --- level:6 rd:5 wd:3
[   30.350035]  disk 0, o:1, dev:sdd8
[   30.350037]  disk 1, o:1, dev:sde8
[   30.350039]  disk 2, o:1, dev:sdf8
[   30.350066] md5: detected capacity change from 0 to 204189204480
[   30.358758]  md5: unknown partition table
[   30.367844]  md3: unknown partition table
[   30.398368] md: md2 stopped.
[   30.434175] md: md4 stopped.
[   30.435256] md: bind<sdd7>
[   30.435350] md: bind<sde7>
[   30.435433] md: bind<sdf7>
[   30.435560] md: bind<sda7>
[   30.443699] md/raid:md4: device sda7 operational as raid disk 0
[   30.443703] md/raid:md4: device sdf7 operational as raid disk 3
[   30.443705] md/raid:md4: device sde7 operational as raid disk 2
[   30.443707] md/raid:md4: device sdd7 operational as raid disk 1
[   30.444134] md/raid:md4: allocated 6450kB
[   30.444407] md/raid:md4: raid level 6 active with 4 out of 6 devices, algorit
hm 2
[   30.444410] RAID conf printout:
[   30.444411]  --- level:6 rd:6 wd:4
[   30.444413]  disk 0, o:1, dev:sda7
[   30.444415]  disk 1, o:1, dev:sdd7
[   30.444417]  disk 2, o:1, dev:sde7
[   30.444419]  disk 3, o:1, dev:sdf7
[   30.444451] md4: detected capacity change from 0 to 87743004672
[   30.452494] md: bind<sdb5>
[   30.452592] md: bind<sdc5>
[   30.452685] md: bind<sdd5>
[   30.452773] md: bind<sde5>
[   30.452860] md: bind<sdf5>
[   30.452974] md: bind<sda5>
[   30.453622] md/raid:md2: device sda5 operational as raid disk 0
[   30.453625] md/raid:md2: device sdf5 operational as raid disk 5
[   30.453627] md/raid:md2: device sde5 operational as raid disk 4
[   30.453628] md/raid:md2: device sdd5 operational as raid disk 3
[   30.453630] md/raid:md2: device sdc5 operational as raid disk 2
[   30.453631] md/raid:md2: device sdb5 operational as raid disk 1
[   30.454160] md/raid:md2: allocated 8562kB
[   30.454178] md/raid:md2: raid level 6 active with 6 out of 8 devices, algorit
hm 2
[   30.454180] RAID conf printout:
[   30.454181]  --- level:6 rd:8 wd:6
[   30.454183]  disk 0, o:1, dev:sda5
[   30.454184]  disk 1, o:1, dev:sdb5
[   30.454186]  disk 2, o:1, dev:sdc5
[   30.454188]  disk 3, o:1, dev:sdd5
[   30.454189]  disk 4, o:1, dev:sde5
[   30.454191]  disk 5, o:1, dev:sdf5
[   30.454221] md2: detected capacity change from 0 to 210429149184
[   30.464825]  md4: unknown partition table
[   30.483060]  md2: unknown partition table
[   31.010977] bio: create slab <bio-2> at 2
[   34.840114] ip_tables: (C) 2000-2006 Netfilter Core Team
[   34.896094] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   35.194258] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   41.506004] EXT4-fs (dm-0): barriers disabled
[   41.564860] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts
: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,data=writebac
k,oldalloc
[   42.436057] usb-storage 8-2:1.0: USB Mass Storage device detected
[   42.436121] scsi10 : usb-storage 8-2:1.0
[   42.436193] usbcore: registered new interface driver usb-storage
[   42.447254] usbcore: registered new interface driver usblp
[   42.480437] usbcore: registered new interface driver usbhid
[   42.480440] usbhid: USB HID core driver
[   42.773526] ip_tables: (C) 2000-2006 Netfilter Core Team
[   42.868340] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   43.439880] scsi 10:0:0:0: Direct-Access     Generic  Flash Disk
  8.07 PQ: 0 ANSI: 2
[   43.440063] sd 10:0:0:0: Attached scsi generic sg6 type 0
[   43.441377] sd 10:0:0:0: [sdu] 7987200 512-byte logical blocks: (4.08 GB/3.80
 GiB)
[   43.441999] sd 10:0:0:0: [sdu] Write Protect is off
[   43.442010] sd 10:0:0:0: [sdu] Mode Sense: 03 00 00 00
[   43.442889] sd 10:0:0:0: [sdu] No Caching mode page found
[   43.442893] sd 10:0:0:0: [sdu] Assuming drive cache: write through
[   43.446499] sd 10:0:0:0: [sdu] No Caching mode page found
[   43.446504] sd 10:0:0:0: [sdu] Assuming drive cache: write through
[   43.466877]  sdu: sdu1
[   43.516340] sd 10:0:0:0: [sdu] No Caching mode page found
[   43.516344] sd 10:0:0:0: [sdu] Assuming drive cache: write through
[   43.516348] sd 10:0:0:0: [sdu] Attached SCSI removable disk
[   43.684801] ata1.00: configured for UDMA/133
[   43.684808] ata1: EH complete
[   43.689513] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doe
sn't support DPO or FUA
[   43.700430] ata2.00: configured for UDMA/100
[   43.700435] ata2: EH complete
[   43.707855] ata3.00: configured for UDMA/100
[   43.707859] ata3: EH complete
[   43.713948] ata4.00: LPM support broken, forcing max_power
[   43.718337] ata5.00: configured for UDMA/133
[   43.718343] ata5: EH complete
[   43.719306] ata4.00: LPM support broken, forcing max_power
[   43.719469] ata6.00: configured for UDMA/133
[   43.719473] ata6: EH complete
[   43.720571] ata4.00: configured for UDMA/133
[   43.720575] ata4: EH complete
[   43.722372] BUG: unable to handle kernel NULL pointer dereference at
  (null)
[   43.722376] IP: [<ffffffff813cd98c>] syno_mv_9235_disk_led_set+0x3c/0xd0
[   43.722383] PGD 1109ec067 PUD 1109ed067 PMD 0
[   43.722387] Oops: 0000 [#1] SMP
[   43.722390] Modules linked in: nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filt
er ip6_tables xt_geoip(O) xt_recent xt_iprange xt_limit xt_state xt_multiport xt
_LOG nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables hid_generic usbhi
d hid usblp usb_storage oxu210hp_hcd xt_length xt_tcpudp nf_conntrack x_tables b
romolow_synobios(PO) btrfs synoacl_vfs(PO) zlib_deflate hfsplus md4 hmac mlx_com
pat(O) tn40xx(O) fuse vfat fat glue_helper lrw gf128mul ablk_helper arc4 rng_cor
e cpufreq_conservative cpufreq_powersave cpufreq_performance cpufreq_ondemand mp
erf processor cpufreq_stats freq_table dm_snapshot crc_itu_t quota_v2 quota_tree
 psnap p8022 llc sit tunnel4 ip_tunnel zram(C) r8152 asix ax88179_178a usbnet et
xhci_hcd xhci_hcd ehci_pci ehci_hcd uhci_hcd ohci_hcd usbcore usb_common hptiop
3w_sas 3w_9xxx mvsas hpsa arcmsr pm80xx aic94xx megaraid_sas megaraid_mbox megar
aid_mm nvme mpt3sas mptsas mptspi mptscsih mptbase scsi_transport_spi sg ata_pii
x sata_uli sata_svw sata_qstor sata_sis pata_sis stex sata_sx4 sata_promise sata
_nv sata_via sata_sil pdc_adma pata_via iscsi_tcp libiscsi_tcp libiscsi enic qlg
e qlcnic qla3xxx netxen_nic mlx4_en mlx4_core cxgb4 cxgb3 cnic ipv6 bnx2x bna be
2net sis900 sis190 jme atl1e atl1c atl2 atl1 alx sky2 skge via_velocity crc_ccit
t via_rhine r8101 r8168 r8169 8139too 8139cp tg3 broadcom b44 bnx2 ssb uio force
deth i40e ixgbe ixgb igb ioatdma e1000e e1000 e100 dca pcnet32 amd8111e mdio mii
 evdev button thermal_sys compat(O) cryptd ecryptfs sha512_generic sha256_generi
c sha1_generic ecb aes_x86_64 authenc des_generic libcrc32c ansi_cprng cts md5 c
bc [last unloaded: ip_tables]
[   43.722494] CPU: 0 PID: 20784 Comm: scemd Tainted: P         C O 3.10.35 #1
[   43.722496] Hardware name: System manufacturer P5Q SE/P5Q SE, BIOS 1005    07
/10/2009
[   43.722498] task: ffff880126da6900 ti: ffff880110fc0000 task.ti: ffff880110fc
0000
[   43.722500] RIP: 0010:[<ffffffff813cd98c>]  [<ffffffff813cd98c>] syno_mv_9235
[   43.722504] RSP: 0018:ffff880110fc3d18  EFLAGS: 00010202
[   43.722505] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000000b
[   43.722507] RDX: ffff88012599c000 RSI: ffff88012599c000 RDI: ffff880125966800
[   43.722508] RBP: 0000000000000000 R08: ffff8801296510b8 R09: 0000000000000008
[   43.722510] R10: 00000000f77d8430 R11: 0000000000000000 R12: ffff880129651080
[   43.722512] R13: 000000000000000a R14: 0000000000000001 R15: 0000000000000000
[   43.722514] FS:  0000000000000000(0000) GS:ffff88012fc00000(0063) knlGS:00000
000f4a31b70
[   43.722516] CS:  0010 DS: 002b ES: 002b CR0: 0000000080050033
[   43.722517] CR2: 0000000000000000 CR3: 00000001109eb000 CR4: 00000000000007f0
[   43.722519] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[   43.722521] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[   43.722522] Stack:
[   43.722523]  0000000000000006 ffffffffa0c5bb98 ffffffffffffffff 00000000f4a31
048
[   43.722527]  ffff880129651080 ffffffffa0c58574 00000000f702f000 ffff880110fc3
de0
[   43.722529]  ffff880129ef4000 0000000000000007 00000000ffffff9c 00000000fffff
f9c
[   43.722532] Call Trace:
[   43.722539]  [<ffffffffa0c5bb98>] ? SetSCSIHostLedStatusBy9235GPIOandAHCISGPI
O+0x68/0x100 [bromolow_synobios]
[   43.722543]  [<ffffffffa0c58574>] ? synobios_ioctl+0xe24/0x1060 [bromolow_syn
obios]
[   43.722547]  [<ffffffff8110b6bc>] ? filename_lookup+0x2c/0xb0
[   43.722550]  [<ffffffff811098b4>] ? getname_flags.part.31+0x84/0x130
[   43.722553]  [<ffffffff81110610>] ? user_path_at_empty+0xa0/0x120
[   43.722557]  [<ffffffff8116a84b>] ? sysfs_getattr+0x4b/0x60
[   43.722560]  [<ffffffff81116f82>] ? dput+0x22/0x1b0
[   43.722564]  [<ffffffff8114bc57>] ? compat_sys_ioctl+0x1e7/0x1500
[   43.722568]  [<ffffffff810348e0>] ? sys32_stat64+0x10/0x30
[   43.722572]  [<ffffffff8152769c>] ? sysenter_dispatch+0x7/0x21
[   43.722573] Code: 0f 84 a0 00 00 00 48 8b 90 f8 04 00 00 48 85 d2 0f 84 97 00
 00 00 48 8b 82 80 2c 00 00 8b 4a 24 48 8b 70 78 48 8b 40 20 83 c1 04 <48> 8b 00
 2b 4e 24 48 85 c0 74 69 be 20 10 07 07 89 b0 a8 00 00
[   43.722599] RIP  [<ffffffff813cd98c>] syno_mv_9235_disk_led_set+0x3c/0xd0
[   43.722602]  RSP <ffff880110fc3d18>
[   43.722604] CR2: 0000000000000000
[   43.722607] ---[ end trace 9a0a4334804deded ]---
[   44.945994] Uniform Multi-Platform E-IDE driver
[   44.967363] scsi11 : pata_marvell
[   44.972038] scsi12 : pata_marvell
[   44.972118] ata11: PATA max UDMA/100 cmd 0xcc00 ctl 0xc880 bmdma 0xc400 irq 1
6
[   44.972120] ata12: DUMMY
[   45.185391] pata_hpt37x: bus clock 33MHz, using 66MHz DPLL
[   45.191032] scsi13 : pata_hpt37x
[   45.196029] scsi14 : pata_hpt37x
[   45.196115] ata13: PATA max UDMA/133 cmd 0xe080 ctl 0xe000 bmdma 0xd400 irq 1
8
[   45.196118] ata14: PATA max UDMA/133 cmd 0xdc00 ctl 0xd880 bmdma 0xd408 irq 1
8
[   45.358602] loop: module loaded
[   45.371846] ata13.00: ATA-6: WDC WD2000JB-00GVA0, 08.02D08, max UDMA/100
[   45.371851] ata13.00: 390721968 sectors, multi 16: LBA48
[   45.372960] ata13.01: ATA-6: WDC WD1600JB-00EVA0, 15.05R15, max UDMA/100
[   45.372964] ata13.01: 312581808 sectors, multi 16: LBA48
[   45.380661] ata13.00: configured for UDMA/100
[   45.387441] ata13.01: configured for UDMA/100
[   45.390765] scsi 13:0:0:0: Direct-Access     WDC      WD2000JB-00GVA0
  08.0 PQ: 0 ANSI: 5
[   45.391739] sd 13:0:0:0: [sdn] 390721968 512-byte logical blocks: (200 GB/186
 GiB)
[   45.391785] sd 13:0:0:0: [sdn] Write Protect is off
[   45.391788] sd 13:0:0:0: [sdn] Mode Sense: 00 3a 00 00
[   45.391808] sd 13:0:0:0: [sdn] Write cache: enabled, read cache: enabled, doe
[   45.391920] sd 13:0:0:0: Attached scsi generic sg7 type 0
[   45.416273] scsi 13:0:1:0: Direct-Access     WDC      WD1600JB-00EVA0
  15.0 PQ: 0 ANSI: 5
[   45.416357] want_idx 13 index 14. delay and reget
[   45.449284]  sdn: sdn1 sdn2 sdn3 < sdn5 sdn6 sdn7 sdn8 >
[   45.449892] sd 13:0:0:0: [sdn] Attached SCSI disk
[   46.416018] want_idx 13 index 14
[   46.416022] want_idx 13 index 14. delay and reget
[   46.795133] ata1.00: configured for UDMA/133
[   46.795139] ata1: EH complete
[   46.951059] ata2.00: configured for UDMA/100
[   46.951064] ata2: EH complete
[   47.096688] ata3.00: configured for UDMA/100
[   47.096695] ata3: EH complete
[   47.343045] ata4.00: LPM support broken, forcing max_power
[   47.348256] ata4.00: LPM support broken, forcing max_power
[   47.349523] ata4.00: configured for UDMA/133
[   47.349528] ata4: EH complete
[   47.393310] ata5.00: configured for UDMA/133
[   47.393316] ata5: EH complete
[   47.416035] want_idx 13 index 14
[   47.416039] want_idx 13 index 14. delay and reget
[   47.421569] ata6.00: configured for UDMA/133
[   47.421574] ata6: EH complete
[   47.797070] FAT-fs (sdu1): Volume was not properly unmounted. Some data may b
e corrupt. Please run fsck.
[   47.966570] ata13.00: configured for UDMA/100
[   47.973390] ata13.01: configured for UDMA/100
[   47.973395] ata13: EH complete
[   47.982526] sd 13:0:0:0: [sdn] Write cache: disabled, read cache: enabled, do
esn't support DPO or FUA
[   48.416014] want_idx 13 index 14
[   48.416018] want_idx 13 index 14. delay and reget
[   49.416008] want_idx 13 index 14
[   49.416013] want_idx 13 index 14. delay and reget
[   50.416014] want_idx 13 index 14
[   50.416018] want_idx 13 index 14. delay and reget
[   51.416007] want_idx 13 index 14
[   51.416011] want_idx 13 index 14. delay and reget
[   52.416008] want_idx 13 index 14
[   52.416012] want_idx 13 index 14. delay and reget
[   53.416009] want_idx 13 index 14
[   53.416013] want_idx 13 index 14. delay and reget
[   54.416007] want_idx 13 index 14
[   54.416011] want_idx 13 index 14. delay and reget
[   55.416007] want_idx 13 index 14
[   55.416011] want_idx 13 index 14. delay and reget
[   56.416007] want_idx 13 index 14
[   56.416010] want_idx 13 index 14. delay and reget
[   57.416007] want_idx 13 index 14
[   57.416011] want_idx 13 index 14. delay and reget
[   58.416007] want_idx 13 index 14
[   58.416011] want_idx 13 index 14. delay and reget
[   59.416007] want_idx 13 index 14
[   59.416010] want_idx 13 index 14. delay and reget
[   60.416007] want_idx 13 index 14
[   60.416127] sd 13:0:1:0: Attached scsi generic sg8 type 0
[   60.416221] sd 13:0:1:0: [sdo] 312581808 512-byte logical blocks: (160 GB/149
 GiB)
[   60.416267] sd 13:0:1:0: [sdo] Write Protect is off
[   60.416271] sd 13:0:1:0: [sdo] Mode Sense: 00 3a 00 00
[   60.416290] sd 13:0:1:0: [sdo] Write cache: enabled, read cache: enabled, doe
[  117.945227] type=1400 audit(1508077567.893:2): apparmor="DENIED" operation="m
kdir" parent=22335 profile="/usr/syno/synoman/webman/index.cgi" name="/usr/syno/
synoman/synohdpack/tmp/" pid=22370 comm="mkdir" requested_mask="c" denied_mask="
c" fsuid=0 ouid=0
[  120.800017] ata13: lost interrupt (Status 0x58)
[  120.801000] ata13: drained 65536 bytes to clear DRQ
[  120.886934] ata13.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  120.886938] ata13.01: failed command: READ DMA
[  120.886943] ata13.01: cmd c8/00:08:00:00:00/00:00:00:00:00/f0 tag 0 dma 4096
in
[  120.886943]          res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeo
ut)
[  120.886946] ata13.01: status: { DRDY }
[  120.887070] ata13: soft resetting link
[  121.069623] ata13.00: configured for UDMA/100
[  121.076420] ata13.01: configured for UDMA/100
[  121.076427] ata13.01: device reported invalid CHS sector 0
[  121.076434] ata13: EH complete
[  121.151786]  sdo: sdo1 sdo2 sdo3 < sdo5 sdo6 sdo7 sdo8 >
[  121.152239] sdo: detected capacity change from 0 to 160041885696
[  121.152322] sd 13:0:1:0: [sdo] Attached SCSI disk
[  122.626584] ata13.00: configured for UDMA/100
[  122.633354] ata13.01: configured for UDMA/100
[  122.633359] ata13: EH complete
[  122.754961] sd 13:0:1:0: [sdo] Write cache: disabled, read cache: enabled, do
[  123.750081] findhostd uses obsolete (PF_INET,SOCK_PACKET)
[  130.105352] touchVolumeRema[22933]: segfault at 5 ip 000000000804d7cf sp 0000
0000fffba350 error 6 in touchVolumeRemap.cgi[8048000+7000]
[  130.169988] touchVolumeRema[22934]: segfault at 5 ip 000000000804d7cf sp 0000
0000ffe49440 error 6 in touchVolumeRemap.cgi[8048000+7000]
AudunNAS>
Hide
The lost interrupts and chs errors might point to some hardware configuration settings needing changing.
For diagnostic purposes I'd suggest stripping back the system and do a set of tests for stability, then add on more components;
Disable onboard parallel, serial, sound
Disable onboard sata/pata
Remove the SIL card
Boot/test the HTP card with drives - I'm presuming you have setup the HPT as a jbod, IDE master/slave are all correct etc - and jumpers on the drives match etc
Check the dmesg and see if there is any change.
If stable then enable the onboard pata and retest etc and see if it 'breaks' at any point.
As an aside, your total potential drive capacity with all controllers seems to be 16 (6+2+4+4), presuming again that you have altered the drive configuration in synoinfo.conf to match.
I entered the BIOS and disabled everything I'm not using, and it did not help. I then tried googling the error message, and realized I was having an IRQ conflict. I then enabled PNP OS in the BIOS, and the error is now gone. Apparently Linux will try to allocate IRQs regardless of this setting, so you have to make the BIOS stop assigning IRQs, or you'll end up with IRQ conflicts.
I believe the problem is solved, but I have not yet had time to do any testing. On to that now :)
Thanks for your help, I was about to give up on  using the PATA drives.
EDIT: yes you're right about my setup, it is currently limited to 16 drives, and I've edited the config file to allow for up to 20 drives. I intend to start with 12 drives or so, and keep the SIL controller free so that I can migrate to SATA disks as the old PATA drives die. At the point when I have 2 PATA drives left, I'll replace the 4port PATA controller with another SATA controller.
Edited by AMelbye
It appears I was being too optimistic. To give it a proper test, let the system rebuild the degraded array using the two disks attached. I left it on all night, and the next morning it had crashed. web interface down, telnet down, and I could not even log on at the server itself.
here's the dmesg from just after the following boot:
dmesg
[   33.798727] md/raid:md5: raid level 6 active with 3 out of 5 devices, algorit
hm 2
[   33.798730] RAID conf printout:
[   33.798732]  --- level:6 rd:5 wd:3
[   33.798734]  disk 0, o:1, dev:sdd8
[   33.798736]  disk 1, o:1, dev:sde8
[   33.798738]  disk 2, o:1, dev:sdf8
[   33.798762] md5: detected capacity change from 0 to 204189204480
[   33.803819] md/raid:md3: device sda6 operational as raid disk 0
[   33.803824] md/raid:md3: device sdf6 operational as raid disk 4
[   33.803826] md/raid:md3: device sde6 operational as raid disk 3
[   33.803828] md/raid:md3: device sdd6 operational as raid disk 2
[   33.803829] md/raid:md3: device sdb6 operational as raid disk 1
[   33.804298] md/raid:md3: allocated 7506kB
[   33.806086]  md5: unknown partition table
[   33.807632] md: bind<sda7>
[   33.809856] md/raid:md2: device sda5 operational as raid disk 0
[   33.809861] md/raid:md2: device sdf5 operational as raid disk 5
[   33.809862] md/raid:md2: device sde5 operational as raid disk 4
[   33.809864] md/raid:md2: device sdd5 operational as raid disk 3
[   33.809866] md/raid:md2: device sdc5 operational as raid disk 2
[   33.809867] md/raid:md2: device sdb5 operational as raid disk 1
[   33.810454] md/raid:md2: allocated 8562kB
[   33.811161] md/raid:md3: raid level 6 active with 5 out of 7 devices, algorit
hm 2
[   33.811165] RAID conf printout:
[   33.811167]  --- level:6 rd:7 wd:5
[   33.811169]  disk 0, o:1, dev:sda6
[   33.811172]  disk 1, o:1, dev:sdb6
[   33.811174]  disk 2, o:1, dev:sdd6
[   33.811176]  disk 3, o:1, dev:sde6
[   33.811178]  disk 4, o:1, dev:sdf6
[   33.811210] md3: detected capacity change from 0 to 99890626560
[   33.814581] md/raid:md2: raid level 6 active with 6 out of 8 devices, algorit
hm 2
[   33.814585] RAID conf printout:
[   33.814587]  --- level:6 rd:8 wd:6
[   33.814590]  disk 0, o:1, dev:sda5
[   33.814592]  disk 1, o:1, dev:sdb5
[   33.814594]  disk 2, o:1, dev:sdc5
[   33.814596]  disk 3, o:1, dev:sdd5
[   33.814598]  disk 4, o:1, dev:sde5
[   33.814599]  disk 5, o:1, dev:sdf5
[   33.814630] md2: detected capacity change from 0 to 210429149184
[   33.815686] md/raid:md4: device sda7 operational as raid disk 0
[   33.815690] md/raid:md4: device sdf7 operational as raid disk 3
[   33.815692] md/raid:md4: device sde7 operational as raid disk 2
[   33.815693] md/raid:md4: device sdd7 operational as raid disk 1
[   33.816124] md/raid:md4: allocated 6450kB
[   33.816748] md/raid:md4: raid level 6 active with 4 out of 6 devices, algorit
hm 2
[   33.816751] RAID conf printout:
[   33.816752]  --- level:6 rd:6 wd:4
[   33.816755]  disk 0, o:1, dev:sda7
[   33.816757]  disk 1, o:1, dev:sdd7
[   33.816758]  disk 2, o:1, dev:sde7
[   33.816760]  disk 3, o:1, dev:sdf7
[   33.816789] md4: detected capacity change from 0 to 87743004672
[   33.833696]  md3: unknown partition table
[   33.836598]  md4: unknown partition table
[   33.860059]  md2: unknown partition table
[   34.589028] bio: create slab <bio-2> at 2
[   37.750140] ip_tables: (C) 2000-2006 Netfilter Core Team
[   37.784143] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   38.060150] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   45.600718] EXT4-fs (dm-0): barriers disabled
[   46.104921] EXT4-fs (dm-0): recovery complete
[   46.152862] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts
k,oldalloc
[   50.327300] ata1.00: configured for UDMA/133
[   50.327306] ata1: EH complete
[   50.327408] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doe
[   50.346376] ata2.00: configured for UDMA/100
[   50.346383] ata2: EH complete
[   50.348195] ata3.00: configured for UDMA/100
[   50.348202] ata3: EH complete
[   50.349950] ata4.00: LPM support broken, forcing max_power
[   50.354625] ata5.00: configured for UDMA/133
[   50.354633] ata5: EH complete
[   50.355268] ata4.00: LPM support broken, forcing max_power
[   50.356521] ata4.00: configured for UDMA/133
[   50.356527] ata4: EH complete
[   50.356977] ata6.00: configured for UDMA/133
[   50.356981] ata6: EH complete
[   50.357026] BUG: unable to handle kernel NULL pointer dereference at
  (null)
[   50.357030] IP: [<ffffffff813cd98c>] syno_mv_9235_disk_led_set+0x3c/0xd0
[   50.357038] PGD 110616067 PUD 110615067 PMD 0
[   50.357042] Oops: 0000 [#1] SMP
[   50.357045] Modules linked in: nf_conntrack_ipv6(-) nf_defrag_ipv6 ip6table_f
ilter ip6_tables xt_length xt_tcpudp xt_LOG nf_conntrack_ipv4 nf_defrag_ipv4 nf_
conntrack iptable_filter ip_tables x_tables bromolow_synobios(PO) btrfs synoacl_
vfs(PO) zlib_deflate hfsplus md4 hmac mlx_compat(O) tn40xx(O) fuse vfat fat glue
_helper lrw gf128mul ablk_helper arc4 rng_core cpufreq_conservative cpufreq_powe
rsave cpufreq_performance cpufreq_ondemand mperf processor cpufreq_stats freq_ta
ble dm_snapshot crc_itu_t quota_v2 quota_tree psnap p8022 llc sit tunnel4 ip_tun
nel zram(C) r8152 asix ax88179_178a usbnet etxhci_hcd xhci_hcd ehci_pci ehci_hcd
 uhci_hcd ohci_hcd usbcore usb_common hptiop 3w_sas 3w_9xxx mvsas hpsa arcmsr pm
80xx aic94xx megaraid_sas megaraid_mbox megaraid_mm nvme mpt3sas mptsas mptspi m
ptscsih mptbase scsi_transport_spi sg ata_piix sata_uli sata_svw sata_qstor sata
_sis pata_sis stex sata_sx4 sata_promise sata_nv sata_via sata_sil pdc_adma pata
_via iscsi_tcp libiscsi_tcp libiscsi enic qlge qlcnic qla3xxx netxen_nic mlx4_en
 mlx4_core cxgb4 cxgb3 cnic ipv6 bnx2x bna be2net sis900 sis190 jme atl1e atl1c
atl2 atl1 alx sky2 skge via_velocity crc_ccitt via_rhine r8101 r8168 r8169 8139t
oo 8139cp tg3 broadcom b44 bnx2 ssb uio forcedeth i40e ixgbe ixgb igb ioatdma e1
000e e1000 e100 dca pcnet32 amd8111e mdio mii evdev button thermal_sys compat(O)
 cryptd ecryptfs sha512_generic sha256_generic sha1_generic ecb aes_x86_64 authe
nc des_generic libcrc32c ansi_cprng cts md5 cbc [last unloaded: xt_multiport]
[   50.357146] CPU: 1 PID: 20368 Comm: scemd Tainted: P         C O 3.10.35 #1
[   50.357148] Hardware name: System manufacturer P5Q SE/P5Q SE, BIOS 1005    07
/10/2009
[   50.357150] task: ffff88012a206900 ti: ffff880110650000 task.ti: ffff88011065
0000
[   50.357151] RIP: 0010:[<ffffffff813cd98c>]  [<ffffffff813cd98c>] syno_mv_9235
[   50.357155] RSP: 0018:ffff880110653d18  EFLAGS: 00010202
[   50.357157] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000000b
[   50.357159] RDX: ffff880129c28000 RSI: ffff880129c28000 RDI: ffff8801258e6800
[   50.357160] RBP: 0000000000000000 R08: ffff880122fa8ef8 R09: 0000000000000008
[   50.357162] R10: 00000000f7755430 R11: 0000000000000000 R12: ffff880122fa8ec0
[   50.357163] R13: 0000000000000009 R14: 0000000000000001 R15: 0000000000000000
[   50.357166] FS:  0000000000000000(0000) GS:ffff88012fc80000(0063) knlGS:00000
000f49aeb70
[   50.357168] CS:  0010 DS: 002b ES: 002b CR0: 0000000080050033
[   50.357169] CR2: 0000000000000000 CR3: 0000000128be0000 CR4: 00000000000007e0
[   50.357171] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[   50.357173] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[   50.357174] Stack:
[   50.357175]  0000000000000006 ffffffffa0c5bb98 ffffffffffffffff 00000000f49ae
048
[   50.357178]  ffff880122fa8ec0 ffffffffa0c58574 00000000f6fac000 ffff880110653
de0
[   50.357181]  ffff880125e7a000 0000000000000007 00000000ffffff9c 00000000fffff
f9c
[   50.357184] Call Trace:
[   50.357191]  [<ffffffffa0c5bb98>] ? SetSCSIHostLedStatusBy9235GPIOandAHCISGPI
[   50.357195]  [<ffffffffa0c58574>] ? synobios_ioctl+0xe24/0x1060 [bromolow_syn
obios]
[   50.357199]  [<ffffffff8110b6bc>] ? filename_lookup+0x2c/0xb0
[   50.357202]  [<ffffffff811098b4>] ? getname_flags.part.31+0x84/0x130
[   50.357205]  [<ffffffff81110610>] ? user_path_at_empty+0xa0/0x120
[   50.357209]  [<ffffffff8116a84b>] ? sysfs_getattr+0x4b/0x60
[   50.357212]  [<ffffffff81116f82>] ? dput+0x22/0x1b0
[   50.357216]  [<ffffffff8114bc57>] ? compat_sys_ioctl+0x1e7/0x1500
[   50.357221]  [<ffffffff810348e0>] ? sys32_stat64+0x10/0x30
[   50.357225]  [<ffffffff8152769c>] ? sysenter_dispatch+0x7/0x21
[   50.357226] Code: 0f 84 a0 00 00 00 48 8b 90 f8 04 00 00 48 85 d2 0f 84 97 00
[   50.357252] RIP  [<ffffffff813cd98c>] syno_mv_9235_disk_led_set+0x3c/0xd0
[   50.357256]  RSP <ffff880110653d18>
[   50.357257] CR2: 0000000000000000
[   50.357261] ---[ end trace b048d24adac57f0f ]---
[   50.476258] usb-storage 8-2:1.0: USB Mass Storage device detected
[   50.476309] scsi10 : usb-storage 8-2:1.0
[   50.476380] usb-storage 8-3:1.0: USB Mass Storage device detected
[   50.476409] scsi11 : usb-storage 8-3:1.0
[   50.476455] usbcore: registered new interface driver usb-storage
[   50.548448] usbcore: registered new interface driver usblp
[   50.737329] usbcore: registered new interface driver usbhid
[   50.737334] usbhid: USB HID core driver
[   50.745873] ip_tables: (C) 2000-2006 Netfilter Core Team
[   50.831338] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   51.478624] scsi 11:0:0:0: Direct-Access     SanDisk  Ultra Fit
  1.00 PQ: 0 ANSI: 6
[   51.478815] sd 11:0:0:0: Attached scsi generic sg6 type 0
[   51.479493] sd 11:0:0:0: [sdu] 30031250 512-byte logical blocks: (15.3 GB/14.
3 GiB)
[   51.479995] scsi 10:0:0:0: Direct-Access     Generic  Flash Disk
  8.07 PQ: 0 ANSI: 2
[   51.480760] sd 10:0:0:0: Attached scsi generic sg7 type 0
[   51.481247] sd 11:0:0:0: [sdu] Write Protect is off
[   51.481251] sd 11:0:0:0: [sdu] Mode Sense: 43 00 00 00
[   51.481992] sd 10:0:0:0: [sdv] 7987200 512-byte logical blocks: (4.08 GB/3.80
 GiB)
[   51.482241] sd 11:0:0:0: [sdu] Write cache: disabled, read cache: enabled, do
[   51.482629] sd 10:0:0:0: [sdv] Write Protect is off
[   51.482633] sd 10:0:0:0: [sdv] Mode Sense: 03 00 00 00
[   51.483242] sd 10:0:0:0: [sdv] No Caching mode page found
[   51.483246] sd 10:0:0:0: [sdv] Assuming drive cache: write through
[   51.486740] sd 10:0:0:0: [sdv] No Caching mode page found
[   51.486744] sd 10:0:0:0: [sdv] Assuming drive cache: write through
[   51.489758]  sdu: sdu1
[   51.492745] sd 11:0:0:0: [sdu] Attached SCSI removable disk
[   51.816235]  sdv: sdv1
[   51.868341] sd 10:0:0:0: [sdv] No Caching mode page found
[   51.868346] sd 10:0:0:0: [sdv] Assuming drive cache: write through
[   51.868350] sd 10:0:0:0: [sdv] Attached SCSI removable disk
[   55.682204] loop: module loaded
[   55.802700] ata1.00: configured for UDMA/133
[   55.802707] ata1: EH complete
[   56.183909] ata2.00: configured for UDMA/100
[   56.183914] ata2: EH complete
[   56.216281] pata_hpt37x: bus clock 33MHz, using 66MHz DPLL
[   56.217271] scsi12 : pata_hpt37x
[   56.217607] scsi13 : pata_hpt37x
[   56.217652] ata11: PATA max UDMA/133 cmd 0xe080 ctl 0xe000 bmdma 0xd400 irq 1
8
[   56.217655] ata12: PATA max UDMA/133 cmd 0xdc00 ctl 0xd880 bmdma 0xd408 irq 1
8
[   56.298166] ata3.00: configured for UDMA/100
[   56.298172] ata3: EH complete
[   56.392796] ata11.00: ATA-6: WDC WD2000JB-00GVA0, 08.02D08, max UDMA/100
[   56.392801] ata11.00: 390721968 sectors, multi 16: LBA48
[   56.393918] ata11.01: ATA-6: WDC WD1600JB-00EVA0, 15.05R15, max UDMA/100
[   56.393922] ata11.01: 312581808 sectors, multi 16: LBA48
[   56.401677] ata11.00: configured for UDMA/100
[   56.408428] ata11.01: configured for UDMA/100
[   56.409970] ata4.00: LPM support broken, forcing max_power
[   56.411719] scsi 12:0:0:0: Direct-Access     WDC      WD2000JB-00GVA0
  08.0 PQ: 0 ANSI: 5
[   56.411889] sd 12:0:0:0: Attached scsi generic sg8 type 0
[   56.414871] scsi 12:0:1:0: Direct-Access     WDC      WD1600JB-00EVA0
  15.0 PQ: 0 ANSI: 5
[   56.414948] want_idx 12 index 13. delay and reget
[   56.414960] sd 12:0:0:0: [sdm] 390721968 512-byte logical blocks: (200 GB/186
 GiB)
[   56.415515] ata4.00: LPM support broken, forcing max_power
[   56.415567] sd 12:0:0:0: [sdm] Write Protect is off
[   56.415570] sd 12:0:0:0: [sdm] Mode Sense: 00 3a 00 00
[   56.415590] sd 12:0:0:0: [sdm] Write cache: enabled, read cache: enabled, doe
[   56.416789] ata4.00: configured for UDMA/133
[   56.416797] ata4: EH complete
[   56.447690] ata5.00: configured for UDMA/133
[   56.447696] ata5: EH complete
[   56.467281]  sdm: sdm1 sdm2 sdm3 < sdm5 sdm6 sdm7 sdm8 >
[   56.467676] sd 12:0:0:0: [sdm] Attached SCSI disk
[   56.470547] ata6.00: configured for UDMA/133
[   56.470553] ata6: EH complete
[   57.414853] want_idx 12 index 13
[   57.414858] want_idx 12 index 13. delay and reget
[   57.944082] FAT-fs (sdu1): Volume was not properly unmounted. Some data may b
[   58.414009] want_idx 12 index 13
[   58.414014] want_idx 12 index 13. delay and reget
[   59.414010] want_idx 12 index 13
[   59.414014] want_idx 12 index 13. delay and reget
[   60.121697] FAT-fs (sdv1): Volume was not properly unmounted. Some data may b
[   60.414021] want_idx 12 index 13
[   60.414026] want_idx 12 index 13. delay and reget
[   61.414009] want_idx 12 index 13
[   61.414014] want_idx 12 index 13. delay and reget
[   62.414011] want_idx 12 index 13
[   62.414016] want_idx 12 index 13. delay and reget
>[   63.035660] init: smbd main process (22213) killed by HUP signal
>[   63.035719] init: smbd main process ended, respawning
[   63.414017] want_idx 12 index 13
[   63.414021] want_idx 12 index 13. delay and reget
[   63.729569] ata11.00: configured for UDMA/100
[   63.736420] ata11.01: configured for UDMA/100
[   63.736425] ata11: EH complete
[   63.736525] sd 12:0:0:0: [sdm] Write cache: disabled, read cache: enabled, do
[   64.414009] want_idx 12 index 13
[   64.414013] want_idx 12 index 13. delay and reget
>[   64.927066] init: smbd main process (22767) killed by HUP signal
>[   64.927114] init: smbd main process ended, respawning
[   65.414009] want_idx 12 index 13
[   65.414013] want_idx 12 index 13. delay and reget
[   66.414011] want_idx 12 index 13
[   66.414015] want_idx 12 index 13. delay and reget
[   67.414016] want_idx 12 index 13
[   67.414020] want_idx 12 index 13. delay and reget
[   68.414008] want_idx 12 index 13
[   68.414012] want_idx 12 index 13. delay and reget
[   69.414010] want_idx 12 index 13
[   69.414014] want_idx 12 index 13. delay and reget
[   70.414009] want_idx 12 index 13
[   70.414012] want_idx 12 index 13. delay and reget
[   71.414010] want_idx 12 index 13
[   71.414146] sd 12:0:1:0: [sdn] 312581808 512-byte logical blocks: (160 GB/149
 GiB)
[   71.414193] sd 12:0:1:0: [sdn] Write Protect is off
[   71.414197] sd 12:0:1:0: [sdn] Mode Sense: 00 3a 00 00
[   71.414216] sd 12:0:1:0: [sdn] Write cache: enabled, read cache: enabled, doe
[   71.414292] sd 12:0:1:0: Attached scsi generic sg9 type 0
[   71.495074]  sdn: sdn1 sdn2 sdn3 < sdn5 sdn6 sdn7 sdn8 >
[   71.495468] sd 12:0:1:0: [sdn] Attached SCSI disk
[   72.856636] ata11.00: configured for UDMA/100
[   72.863365] ata11.01: configured for UDMA/100
[   72.863370] ata11: EH complete
[   72.982871] sd 12:0:1:0: [sdn] Write cache: disabled, read cache: enabled, do
[   75.126075] findhostd uses obsolete (PF_INET,SOCK_PACKET)
[  155.053300] type=1400 audit(1508164937.122:2): apparmor="DENIED" operation="m
kdir" parent=23488 profile="/usr/syno/synoman/webman/index.cgi" name="/usr/syno/
synoman/synohdpack/tmp/" pid=23522 comm="mkdir" requested_mask="c" denied_mask="
c" fsuid=0 ouid=0
[  167.749495] touchVolumeRema[23576]: segfault at 5 ip 000000000804d7cf sp 0000
0000ff91a050 error 6 in touchVolumeRemap.cgi[8048000+7000]
[  167.826560] touchVolumeRema[23577]: segfault at 5 ip 000000000804d7cf sp 0000
0000ffd6a360 error 6 in touchVolumeRemap.cgi[8048000+7000]
AudunNAS>
Hide
So I deleted the array, made a new one, then let the system reboot. My IDE drives are still being dropped from the array. Here's the DMESG:
dmesg
[   29.926055] md/raid:md5: device sdf8 operational as raid disk 2
[   29.926057] md/raid:md5: device sde8 operational as raid disk 1
[   29.926444] md/raid:md5: allocated 5394kB
[   29.929058] md/raid:md5: raid level 6 active with 3 out of 5 devices, algorit
hm 2
[   29.929061] RAID conf printout:
[   29.929063]  --- level:6 rd:5 wd:3
[   29.929065]  disk 0, o:1, dev:sdd8
[   29.929068]  disk 1, o:1, dev:sde8
[   29.929070]  disk 2, o:1, dev:sdf8
[   29.929121] md5: detected capacity change from 0 to 204189204480
[   29.930930] md: bind<sdd7>
[   29.931145] md: bind<sdb6>
[   29.931240] md: bind<sdd6>
[   29.935248]  md5: unknown partition table
[   29.939072] md/raid:md2: device sda5 operational as raid disk 0
[   29.939077] md/raid:md2: device sdf5 operational as raid disk 5
[   29.939079] md/raid:md2: device sde5 operational as raid disk 4
[   29.939081] md/raid:md2: device sdd5 operational as raid disk 3
[   29.939082] md/raid:md2: device sdc5 operational as raid disk 2
[   29.939084] md/raid:md2: device sdb5 operational as raid disk 1
[   29.939664] md/raid:md2: allocated 8562kB
[   29.941101] md/raid:md2: raid level 6 active with 6 out of 8 devices, algorit
hm 2
[   29.941105] RAID conf printout:
[   29.941106]  --- level:6 rd:8 wd:6
[   29.941109]  disk 0, o:1, dev:sda5
[   29.941111]  disk 1, o:1, dev:sdb5
[   29.941113]  disk 2, o:1, dev:sdc5
[   29.941115]  disk 3, o:1, dev:sdd5
[   29.941117]  disk 4, o:1, dev:sde5
[   29.941119]  disk 5, o:1, dev:sdf5
[   29.941148] md2: detected capacity change from 0 to 210429149184
[   29.950202]  md2: unknown partition table
[   29.979146] md: bind<sde7>
[   29.979205] md: bind<sde6>
[   29.983115] md: bind<sdf7>
[   29.983299] md: bind<sda7>
[   29.984022] md/raid:md4: device sda7 operational as raid disk 0
[   29.984025] md/raid:md4: device sdf7 operational as raid disk 3
[   29.984028] md/raid:md4: device sde7 operational as raid disk 2
[   29.984029] md/raid:md4: device sdd7 operational as raid disk 1
[   29.984440] md/raid:md4: allocated 6450kB
[   29.984715] md/raid:md4: raid level 6 active with 4 out of 6 devices, algorit
hm 2
[   29.984717] RAID conf printout:
[   29.984718]  --- level:6 rd:6 wd:4
[   29.984720]  disk 0, o:1, dev:sda7
[   29.984722]  disk 1, o:1, dev:sdd7
[   29.984724]  disk 2, o:1, dev:sde7
[   29.984726]  disk 3, o:1, dev:sdf7
[   29.984755] md4: detected capacity change from 0 to 87743004672
[   29.985035] md: bind<sdf6>
[   29.985307] md: bind<sda6>
[   29.986416] md/raid:md3: device sda6 operational as raid disk 0
[   29.986419] md/raid:md3: device sdf6 operational as raid disk 4
[   29.986421] md/raid:md3: device sde6 operational as raid disk 3
[   29.986423] md/raid:md3: device sdd6 operational as raid disk 2
[   29.986424] md/raid:md3: device sdb6 operational as raid disk 1
[   29.986834] md/raid:md3: allocated 7506kB
[   29.986854] md/raid:md3: raid level 6 active with 5 out of 7 devices, algorit
hm 2
[   29.986856] RAID conf printout:
[   29.986857]  --- level:6 rd:7 wd:5
[   29.986859]  disk 0, o:1, dev:sda6
[   29.986860]  disk 1, o:1, dev:sdb6
[   29.986862]  disk 2, o:1, dev:sdd6
[   29.986864]  disk 3, o:1, dev:sde6
[   29.986865]  disk 4, o:1, dev:sdf6
[   29.986892] md3: detected capacity change from 0 to 99890626560
[   29.999572]  md4: unknown partition table
[   30.023859]  md3: unknown partition table
[   30.601492] bio: create slab <bio-2> at 2
[   34.051430] ip_tables: (C) 2000-2006 Netfilter Core Team
[   34.085489] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   34.494699] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   40.917725] EXT4-fs (dm-0): barriers disabled
[   40.975143] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts
k,oldalloc
[   41.765052] usb-storage 8-2:1.0: USB Mass Storage device detected
[   41.765126] scsi10 : usb-storage 8-2:1.0
[   41.765202] usb-storage 8-3:1.0: USB Mass Storage device detected
[   41.765305] scsi11 : usb-storage 8-3:1.0
[   41.765358] usbcore: registered new interface driver usb-storage
[   41.801692] usbcore: registered new interface driver usblp
[   41.843244] usbcore: registered new interface driver usbhid
[   41.843248] usbhid: USB HID core driver
[   42.180276] ip_tables: (C) 2000-2006 Netfilter Core Team
[   42.273370] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   42.768559] scsi 11:0:0:0: Direct-Access     SanDisk  Ultra Fit
  1.00 PQ: 0 ANSI: 6
[   42.769136] sd 11:0:0:0: Attached scsi generic sg6 type 0
[   42.769433] sd 11:0:0:0: [sdu] 30031250 512-byte logical blocks: (15.3 GB/14.
3 GiB)
[   42.769930] scsi 10:0:0:0: Direct-Access     Generic  Flash Disk
  8.07 PQ: 0 ANSI: 2
[   42.770319] sd 10:0:0:0: Attached scsi generic sg7 type 0
[   42.771056] sd 11:0:0:0: [sdu] Write Protect is off
[   42.771061] sd 11:0:0:0: [sdu] Mode Sense: 43 00 00 00
[   42.771557] sd 10:0:0:0: [sdv] 7987200 512-byte logical blocks: (4.08 GB/3.80
 GiB)
[   42.772058] sd 11:0:0:0: [sdu] Write cache: disabled, read cache: enabled, do
[   42.772437] sd 10:0:0:0: [sdv] Write Protect is off
[   42.772442] sd 10:0:0:0: [sdv] Mode Sense: 03 00 00 00
[   42.773053] sd 10:0:0:0: [sdv] No Caching mode page found
[   42.773057] sd 10:0:0:0: [sdv] Assuming drive cache: write through
[   42.777275] sd 10:0:0:0: [sdv] No Caching mode page found
[   42.777280] sd 10:0:0:0: [sdv] Assuming drive cache: write through
[   42.780954]  sdu: sdu1
[   42.784144] sd 11:0:0:0: [sdu] Attached SCSI removable disk
[   42.791347]  sdv: sdv1
[   42.793809] sd 10:0:0:0: [sdv] No Caching mode page found
[   42.793814] sd 10:0:0:0: [sdv] Assuming drive cache: write through
[   42.793818] sd 10:0:0:0: [sdv] Attached SCSI removable disk
[   42.935753] ata1.00: configured for UDMA/133
[   42.935760] ata1: EH complete
[   42.945391] ata2.00: configured for UDMA/100
[   42.945400] ata2: EH complete
[   42.952614] ata3.00: configured for UDMA/100
[   42.952621] ata3: EH complete
[   42.955156] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doe
[   42.956492] ata4.00: LPM support broken, forcing max_power
[   42.961686] ata4.00: LPM support broken, forcing max_power
[   42.962903] ata4.00: configured for UDMA/133
[   42.962929] ata4: EH complete
[   42.966236] ata5.00: configured for UDMA/133
[   42.966245] ata5: EH complete
[   42.975012] BUG: unable to handle kernel NULL pointer dereference at
  (null)
[   42.975018] IP: [<ffffffff813cd98c>] syno_mv_9235_disk_led_set+0x3c/0xd0
[   42.975026] PGD 110936067 PUD 11090b067 PMD 0
[   42.975029] Oops: 0000 [#1] SMP
[   42.975032] Modules linked in: nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filt
[   42.975140] CPU: 0 PID: 21145 Comm: scemd Tainted: P         C O 3.10.35 #1
[   42.975142] Hardware name: System manufacturer P5Q SE/P5Q SE, BIOS 1005    07
/10/2009
[   42.975144] task: ffff880127786280 ti: ffff88010f690000 task.ti: ffff88010f69
0000
[   42.975145] RIP: 0010:[<ffffffff813cd98c>]  [<ffffffff813cd98c>] syno_mv_9235
[   42.975150] RSP: 0018:ffff88010f693d18  EFLAGS: 00010202
[   42.975151] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000000b
[   42.975153] RDX: ffff880125ec4000 RSI: ffff880125ec4000 RDI: ffff880125ce0800
[   42.975154] RBP: 0000000000000000 R08: ffff880129b571b8 R09: 0000000000000008
[   42.975156] R10: 00000000f77b7430 R11: 0000000000000000 R12: ffff880129b57180
[   42.975158] R13: 0000000000000007 R14: 0000000000000001 R15: 0000000000000000
[   42.975160] FS:  0000000000000000(0000) GS:ffff88012fc00000(0063) knlGS:00000
000f4a10b70
[   42.975162] CS:  0010 DS: 002b ES: 002b CR0: 0000000080050033
[   42.975163] CR2: 0000000000000000 CR3: 0000000110972000 CR4: 00000000000007f0
[   42.975165] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[   42.975167] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[   42.975168] Stack:
[   42.975169]  0000000000000006 ffffffffa0c5bb98 ffffffffffffffff 00000000f4a10
048
[   42.975173]  ffff880129b57180 ffffffffa0c58574 00000000f700e000 ffff88010f693
de0
[   42.975175]  ffff880110b99000 0000000000000007 00000000ffffff9c 00000000fffff
f9c
[   42.975178] Call Trace:
[   42.975185]  [<ffffffffa0c5bb98>] ? SetSCSIHostLedStatusBy9235GPIOandAHCISGPI
[   42.975190]  [<ffffffffa0c58574>] ? synobios_ioctl+0xe24/0x1060 [bromolow_syn
obios]
[   42.975194]  [<ffffffff8110b6bc>] ? filename_lookup+0x2c/0xb0
[   42.975197]  [<ffffffff811098b4>] ? getname_flags.part.31+0x84/0x130
[   42.975200]  [<ffffffff81110610>] ? user_path_at_empty+0xa0/0x120
[   42.975204]  [<ffffffff8116a84b>] ? sysfs_getattr+0x4b/0x60
[   42.975207]  [<ffffffff81116f82>] ? dput+0x22/0x1b0
[   42.975211]  [<ffffffff8114bc57>] ? compat_sys_ioctl+0x1e7/0x1500
[   42.975215]  [<ffffffff810348e0>] ? sys32_stat64+0x10/0x30
[   42.975219]  [<ffffffff8152769c>] ? sysenter_dispatch+0x7/0x21
[   42.975221] Code: 0f 84 a0 00 00 00 48 8b 90 f8 04 00 00 48 85 d2 0f 84 97 00
[   42.975247] RIP  [<ffffffff813cd98c>] syno_mv_9235_disk_led_set+0x3c/0xd0
[   42.975250]  RSP <ffff88010f693d18>
[   42.975252] CR2: 0000000000000000
[   42.975255] ---[ end trace 408ab3bc81433455 ]---
[   42.975472] ata6.00: configured for UDMA/133
[   42.975478] ata6: EH complete
[   44.384356] pata_hpt37x: bus clock 33MHz, using 66MHz DPLL
[   44.388395] scsi12 : pata_hpt37x
[   44.393024] scsi13 : pata_hpt37x
[   44.393102] ata11: PATA max UDMA/133 cmd 0xe080 ctl 0xe000 bmdma 0xd400 irq 1
8
[   44.393106] ata12: PATA max UDMA/133 cmd 0xdc00 ctl 0xd880 bmdma 0xd408 irq 1
8
[   44.569852] ata11.00: ATA-6: WDC WD2000JB-00GVA0, 08.02D08, max UDMA/100
[   44.569858] ata11.00: 390721968 sectors, multi 16: LBA48
[   44.570980] ata11.01: ATA-6: WDC WD1600JB-00EVA0, 15.05R15, max UDMA/100
[   44.570985] ata11.01: 312581808 sectors, multi 16: LBA48
[   44.578691] ata11.00: configured for UDMA/100
[   44.585503] ata11.01: configured for UDMA/100
[   44.588884] scsi 12:0:0:0: Direct-Access     WDC      WD2000JB-00GVA0
  08.0 PQ: 0 ANSI: 5
[   44.589069] sd 12:0:0:0: [sdm] 390721968 512-byte logical blocks: (200 GB/186
 GiB)
[   44.589116] sd 12:0:0:0: [sdm] Write Protect is off
[   44.589120] sd 12:0:0:0: [sdm] Mode Sense: 00 3a 00 00
[   44.589141] sd 12:0:0:0: [sdm] Write cache: enabled, read cache: enabled, doe
[   44.589281] sd 12:0:0:0: Attached scsi generic sg8 type 0
[   44.635243] scsi 12:0:1:0: Direct-Access     WDC      WD1600JB-00EVA0
  15.0 PQ: 0 ANSI: 5
[   44.635335] want_idx 12 index 13. delay and reget
[   44.652672]  sdm: sdm1 sdm2 sdm3 < sdm5 sdm6 sdm7 sdm8 >
[   44.653109] sd 12:0:0:0: [sdm] Attached SCSI disk
[   44.820549] loop: module loaded
[   45.112913] ata1.00: configured for UDMA/133
[   45.112922] ata1: EH complete
[   45.291018] ata2.00: configured for UDMA/100
[   45.291024] ata2: EH complete
[   45.458952] ata3.00: configured for UDMA/100
[   45.458960] ata3: EH complete
[   45.557824] ata4.00: LPM support broken, forcing max_power
[   45.563147] ata4.00: LPM support broken, forcing max_power
[   45.564410] ata4.00: configured for UDMA/133
[   45.564415] ata4: EH complete
[   45.593440] ata5.00: configured for UDMA/133
[   45.593447] ata5: EH complete
[   45.616235] ata6.00: configured for UDMA/133
[   45.616241] ata6: EH complete
[   45.635013] want_idx 12 index 13
[   45.635017] want_idx 12 index 13. delay and reget
[   45.932837] FAT-fs (sdu1): Volume was not properly unmounted. Some data may b
[   46.635015] want_idx 12 index 13
[   46.635020] want_idx 12 index 13. delay and reget
[   46.800267] FAT-fs (sdv1): Volume was not properly unmounted. Some data may b
[   47.635008] want_idx 12 index 13
[   47.635013] want_idx 12 index 13. delay and reget
[   48.635009] want_idx 12 index 13
[   48.635013] want_idx 12 index 13. delay and reget
[   48.912121] ata11.00: configured for UDMA/100
[   48.919427] ata11.01: configured for UDMA/100
[   48.919436] ata11: EH complete
[   48.933113] sd 12:0:0:0: [sdm] Write cache: disabled, read cache: enabled, do
[   49.635008] want_idx 12 index 13
[   49.635012] want_idx 12 index 13. delay and reget
[   50.635007] want_idx 12 index 13
[   50.635011] want_idx 12 index 13. delay and reget
[   51.635010] want_idx 12 index 13
[   51.635014] want_idx 12 index 13. delay and reget
[   52.635012] want_idx 12 index 13
[   52.635017] want_idx 12 index 13. delay and reget
[   53.635009] want_idx 12 index 13
[   53.635013] want_idx 12 index 13. delay and reget
[   54.635007] want_idx 12 index 13
[   54.635011] want_idx 12 index 13. delay and reget
[   55.635010] want_idx 12 index 13
[   55.635014] want_idx 12 index 13. delay and reget
[   56.635011] want_idx 12 index 13
[   56.635015] want_idx 12 index 13. delay and reget
[   57.635009] want_idx 12 index 13
[   57.635013] want_idx 12 index 13. delay and reget
[   58.635009] want_idx 12 index 13
[   58.635013] want_idx 12 index 13. delay and reget
[   59.635008] want_idx 12 index 13
[   59.635132] sd 12:0:1:0: Attached scsi generic sg9 type 0
[   59.635455] sd 12:0:1:0: [sdn] 312581808 512-byte logical blocks: (160 GB/149
 GiB)
[   59.635501] sd 12:0:1:0: [sdn] Write Protect is off
[   59.635504] sd 12:0:1:0: [sdn] Mode Sense: 00 3a 00 00
[   59.635524] sd 12:0:1:0: [sdn] Write cache: enabled, read cache: enabled, doe
[   59.715261]  sdn: sdn1 sdn2 sdn3 < sdn5 sdn6 sdn7 sdn8 >
[   59.715680] sd 12:0:1:0: [sdn] Attached SCSI disk
[   61.127619] ata11.00: configured for UDMA/100
[   61.134349] ata11.01: configured for UDMA/100
[   61.134355] ata11: EH complete
[   61.202547] sd 12:0:1:0: [sdn] Write cache: disabled, read cache: enabled, do
[   61.457079] findhostd uses obsolete (PF_INET,SOCK_PACKET)
AudunNAS>
Hide
As far as I can tell this doesn't show any errors regarding the PATA drives? Is there a log file that I can look into?
Did you strip back the number of drives for testing? ie only 2-4 connected to the HPT?
If you have a lot of drives connected, check the power supply can deliver whats needed on the 12v/5v rails continuously, (noting that the dmesg says some drives are needing full power mode)
Also, a possible dumb suggestion, but if the drives can be set to master/slave, with jumpers, do that rather than 'cable select' mode
well it's a 750W PSU, currently running 8 drives (6 SATA and 2 IDE as shr2), a low power consumption GPU and a mid range (in terms of power consumption) CPU. It should be enough. I guess I should get hold of an oscilloscope to check for ripple, but I find it strange that it only happens on IDE devices.
There's still a few things left to try, but it would be great if there was some way to make the system log what happens, since dmesg only shows the last 3 pages or so...
I guess I should try out the SIL sata controller, as it's also on the PCI bus. That would determine if this is a IDE issue or a PCI issue.
I was not aware of cable select being a liability, trying with Master&slave now :)
Edited by AMelbye
PSU should be ok then
I use winscp for running command windows and it allows better handling of the full dmesg output to copy etc.
Have you tried just creating an array with the 2 ide drives only maybe create two jbod single volumes on each drive and see if that survives the build/reboot, then delete and create a 2 drive volume etc.
If this works, but things go bad once the sata drives are mixed in, maybe this points to a conflict somewhere. Also I wonder if the different udma modes might somehow be involved with different drives types.
As an aside,  mask out the USB drives in your config, probably totally irrelevent, but another variable, seeing that the boot drive is being mounted I think.
winscp is much better than the telnet client, thanks for the advise!
I tried making single volumes on the IDE drives, and they're still dropped at boot. I tried pulling both PCI cards, re-enabling the onboard IDE, create two single volumes. Those are also lost if I reboot.
It seems the main problem may be that the PATA modules are not loaded yet at the point when it starts assembling the raid arrays. I've been loading the modules using a script called S05disks.sh in /usr/syno/etc/rc.d
I'll try renaming to S00disks.sh now assuming that the scripts are loaded alphabetically, and we'll see if that helps. There's also a feature in the bios to disable moving PCI adresses above the RAM. I'll try that as well.
How do I mask out the IDE drives? Is it in the same file that I enabled support for more than 12 drives?
If you a loading your pata modules with a script, you are probably correct that its not loading 'in time' before the array build starts. You could look at compiling your drivers directly into the 5.2 loader so they get installed/loaded 'at boot'.
Regarding drive numbers, as far as I know DSM orders drives based on bus numbering and resource allocation of controllers and an IDE drive is no different to a SATA when it comes to config so you edit synoinfo.conf as usual for your quantity (max = 24), 0x0ffffff etc
