zozuka Posted October 7, 2017 Share #1 Posted October 7, 2017 I am setting up my NAS to access it from the net and I want to use secure https connection which needs certificate. Following this guide the operation fails. https://synoguide.com/2016/04/14/secure-your-synology-with-https-ssl-certificate-from-lets-encrypt/ I've tried to enter the following. Domain name: user.dyndns.org or dyndns.org (tried both) Email.... Subject alternative name: user.dyndns.org Do you have any idea how to do it? Link to comment Share on other sites More sharing options...
0 nevusZ Posted October 7, 2017 Share #2 Posted October 7, 2017 You have to forward port 80 http and port 443 https to your nas on your router Web station needs to be installed Then it should work Is remote connection from internet possible? Test it, for example with your smartphone You will get the certificate error but thats ok After that try to get lets encrypt certificate Link to comment Share on other sites More sharing options...
0 zozuka Posted October 7, 2017 Author Share #3 Posted October 7, 2017 Thanks. Forwarding the ports in the router solved it. Link to comment Share on other sites More sharing options...
zozuka
Email....
2 answers to this question
