Joelyuk Posted October 4, 2017 #1 Posted October 4, 2017 Hello all this is my first time on here but i have been mucking around with XPEonolgy for a while now but i cant figure this out right now. I had my system running well on a HP Microserver Gen8. Today i have replaced the CPU for Xeon version but now its coming up to install the PAT file again and wipe the hard drives. That is something that i can not do because i dont want to lose my data. Had anyone else had this. If so could you please help me. Thank you in advance. I am running HP Microserver Gen8 10gb Ram 3 X WD Red Old CPU Intel Celeron G1610T New CPU Intel Xeon E3-1220L Quote
The Mook Posted October 4, 2017 #2 Posted October 4, 2017 Did you try to make a new boot stick? So it ask to install/migrate again? Dont forget to backup youre current usb. Or use another. Quote
Joelyuk Posted October 4, 2017 Author #3 Posted October 4, 2017 No I haven't tried. Didn't know that would affect it but I will defo try that. Thank you for your advise I really appreciate it. Quote
haldi Posted October 5, 2017 #4 Posted October 5, 2017 Howdy. I'm planning an Up(down)grade from G1610T to E3-1265L so pretty soon i'm gonna be in the same position as Joelyuk. Why exactly does the CPU Change influence the System? When you boot the System and check via HP Remote Consoler or Monitor, do you see the option instead of normal boot Reinstall the image? Last time i had an issue with my RAID array and broken DSM Partition i've simply reinstalled and pressed "Migrate all data" and got back to normal usage after reinstalling the .pat file. Quote
sbv3000 Posted October 6, 2017 #5 Posted October 6, 2017 I suspect that when DSM is installed for the first time there is some sort of 'hardware configuration' written to a system file and a significant change of hardware like a CPU causes the system to think its moved and hence the migrate requirement to re-install DSM with the new 'configuration'. A migration keeps user data and if there is a message saying disks will be erased then something else has happened which may or may not be damaging to the data. I would reinstall the old CPU, to bring the system back and take a data backup, then swap CPU again and migrate. You could try disconnecting your raid drives, install DSM on a spare HDD connected to SATA channel 1 with same admin user details but don't create a volume, shutdown. Reconnect raid HDDS to SATA 2-n then boot. DSM will boot from the clean HDD and you will get warnings of failed system partitions on 2-n, after repair shutdown disconnect HDD1, move the raid to correct channels and reboot. Quote
Water Posted October 7, 2017 #6 Posted October 7, 2017 9 hours ago, sbv3000 said: I suspect that when DSM is installed for the first time there is some sort of 'hardware configuration' written to a system file and a significant change of hardware like a CPU causes the system to think its moved and hence the migrate requirement to re-install DSM with the new 'configuration'. A migration keeps user data and if there is a message saying disks will be erased then something else has happened which may or may not be damaging to the data. I would reinstall the old CPU, to bring the system back and take a data backup, then swap CPU again and migrate. You could try disconnecting your raid drives, install DSM on a spare HDD connected to SATA channel 1 with same admin user details but don't create a volume, shutdown. Reconnect raid HDDS to SATA 2-n then boot. DSM will boot from the clean HDD and you will get warnings of failed system partitions on 2-n, after repair shutdown disconnect HDD1, move the raid to correct channels and reboot. I switch the PC completely from Core 2 duo to Core i proccessor and the system and the data remain without change, I didn't reinstall the system, it just works in the second PC normally as the first PC Quote
sbv3000 Posted October 7, 2017 #7 Posted October 7, 2017 27 minutes ago, Water said: I switch the PC completely from Core 2 duo to Core i proccessor and the system and the data remain without change, I didn't reinstall the system, it just works in the second PC normally as the first PC Maybe the differences between Core2 and Core i are small enough that the configuration change is not detected, but celeron to zeon does? It would be an interesting 'exercise' to try various changes and see which ones trigger a 'migration' (eg AMD to Intel or the case of celeron to zeon). I have some hardware I could test but not high end processors. Quote
haldi Posted October 19, 2017 #8 Posted October 19, 2017 Update from Celeron G1610T to Xeon 1265L. No issues! Everything seems to work fine. Quote
