pooky Posted November 21, 2013 #1 Posted November 21, 2013 Hello, I have strange problem with LAN speed, when I upload/download files from/to DSM LAN speed slow down from 50MB to 300kb ? Try to use E1000 driver, VMXNET3 but get some result Is someone have similar problem ? I use N54L with 10GB RAM, and 4 HDD x 1TB. p.s. Also, for test I try classic share on Windows VM and get about 110MB/s over some LAN adapter ? Thanks,
podge Posted January 1, 2014 #2 Posted January 1, 2014 Hi, I am getting the same problem with 4.3, my N54L vmware instance transfer is from 70mb/s down to 638kb/s. Has anybody got any idea why this is occurring? Regards Podge
Gotemcity Posted January 1, 2014 #3 Posted January 1, 2014 Yes. Confirm. The same problem. Esxi 5.5 N54L
mcdull Posted January 3, 2014 #4 Posted January 3, 2014 try test some jumbo frame setting may help to improve?
Gotemcity Posted January 4, 2014 #5 Posted January 4, 2014 Jumbo frames tested. Upload start from 80 but then down to 0. Tested on e1000 and vmxnet3. Winserver 2012 on the same esxi got stable 50
Gotemcity Posted January 9, 2014 #6 Posted January 9, 2014 Solved. Flashed new mod bios and is ok. This bios https://disk.yandex.ru/public/?hash=tcZ ... QiYYzRA%3D From this message. h http://forum.ixbt.com/topic.cgi?id=11:45645:113#113 And change cache on enabled in bios but even without it 50 Stable upload 50.
