standerby Posted September 16, 2017 #1 Posted September 16, 2017 I download vmware image DS3615xs 6.1 Jun’s Mod V1.02-alpha ISO (VM) from here https://xpenology.club/downloads/. When I try to open ds3615.ovf file I got failed to open disk synoboot.vmdk. I make sure the file physiccally exists. Somehow VMware work station 12 can not find it. Any help? Quote
standerby Posted September 17, 2017 Author #2 Posted September 17, 2017 It looks like the VM is created for SATA disks, while my computer has SCSI disks. I replaced stat with scsi in ds3615.ovf and it still doesn't work. Quote
IG-88 Posted September 17, 2017 #3 Posted September 17, 2017 did you read the tutorial about it on that site? https://xpenology.club/setup-xpenology-vmware-workstation-12/ i'd expect it to work as the author had testted it most people here use esxi or (under windows) virtual box as both are free to use Quote
standerby Posted September 17, 2017 Author #4 Posted September 17, 2017 I did. It looks like there was another person had the same issue and he posted a comment. Quote
IG-88 Posted September 17, 2017 #5 Posted September 17, 2017 (edited) you can try to make the vmdk file from the img youself be using "StarWind V2V Image Converter", also provided an this page edit: how about this: Edited September 17, 2017 by IG-88 Quote
standerby Posted September 19, 2017 Author #6 Posted September 19, 2017 On 9/17/2017 at 7:47 PM, IG-88 said: you can try to make the vmdk file from the img youself be using "StarWind V2V Image Converter", also provided an this page edit: how about this: Thanks! StarWind V2V Image Converter works for me. Quote
