noVNC Virtual Machine Manager not working and SHR not an option DSM 6.1.2-15132
Running DSM 6.1.2-15132 baremetal. Everything working great except two issues:
1. Virtual Machine Manager doesn't allow me to noVNC connect to my instances. I can connect the first time during a VM installation, but once windows reboots the noVNC doesn't reconnect and will never connect to it again. I have been able to load the storage drivers during installation... noVNC is unable to reconnect or ever connect again after the first reboot. I tried loading a VMDK of another virtual machine created elsewhere and it won't connect either.
2. SHR is missing as an option during storage creation. I tried this a few times and same results each time. SHR is simply not available as an option.
Anyone else experience these issues?
Hi
For SHR, you need to do following steps
- connect with SSH
- get root acces
# sudo -i
- edit synoinfo.conf
# vi /etc.defaults/synoinfo.conf
- comment line support raid group = "yes"
- add line support_syno_hybrid_raid = "yes"
- reboot then SHR will be usable (be carefull : all data on disk will be lost)
For VNC i haven't use VMM in baremetal
The greater Business Devices ds3615xs and ds3617xs natively support all normal raid modes
On ds916+ image you can use shr natively
But you can change with obove config change
I am using Virtual Machine Manager on my system.
I installed Windows 7 SP1 X86.
Working fine so far, also noVNC is working, but i turned on RDP because it is more flexible in my opinion.
But i don't think i can help you with your issue.
Yeah, it was a long shot. By all accounts it should have been pretty easy and straightforward to have that VMM working but for some reason it just doesn't work for me. I have reinstalled DSM twice now.
I also have two ethernet ports. Both are on the same subnet. I dedicated one for cluster-to-cluster communication and tried assigning my VMs to the other one, but no luck.
Edited by bmacklin
My second adapter has no ip
They enforce you to have one but i dont have a cluster, so no need for a second nic
Maybe try to unplug the cable from second adapter and try again
  • 4 weeks later...
I'm having the same issue as you.  noVNC no longer works after the first reboot at the end of the Windows installation.  I started on DSM 6.1 -something, upgraded to 6.1.2-15132 then again to 6.1.3-1512, all on the same baremetal Dell.  Reinstalling the VM each time I upgraded DSM (VMM had an update at 6.1.2).  No luck.  I did notice that installing Ubuntu 16.04 Server works after all reboots.
I SSH to the xpenology box, ran top and noticed it is using qemu as the hypervisor.  I've tinkered with qemu/kvm with Openstack before, but can't remember much about it.  Though, I did notice that after about five seconds after powering on, the Windows VM goes into a "paused" State.  To watch this from the terminal, type "virsh list --all".   The number one cause of this error for qemu/virsh appears to be out of disk space on the storage (According to my Google searches :smile: ).  I verified that my 100GB virtual disk fits just fine on the 500GB volume, and then recreated it on the 4TB volume just to make sure.  No luck on either one.  I lowered the RAM and the CPUs from 4GB/2Cores to 1GB/1Core.  Still no good.  Note that the Ubuntu VM is 2 cores and 2GB RAM.  Sorry I don't have an answer yet, but I'll keep looking into it.  I wanted to post this in case it may spark some interest.
TLDR: The Ubuntu VMs stay in the "running" state, noVNC works fine.  The Windows VMs go to a "paused" state, noVNC don't work.
Edited by Nucklez
I've messed around a bit with this when I can.  Haven't gotten Windows to boot after being installed yet, but maybe some more details.  If you tail the log file in /var/log/libvirt/qemu that has the same ID as your VM when you run virsh list --all, you see this error a few seconds after the Windows VM boots.
KVM internal error. Suberror: 1
emulation failure
EAX=00000200 EBX=0000aa55 ECX=00000007 EDX=00000080
ESI=00007bd0 EDI=00000800 EBP=000007be ESP=00007be0
EIP=00000684 EFL=00003202 [-------] CPL=0 II=0 A20=1 SMM=0 HLT=0
ES =0000 00000000 ffffffff 00809300
CS =0000 00000000 ffffffff 00809b00
SS =0000 00000000 ffffffff 00809300
DS =0000 00000000 ffffffff 00809300
FS =0000 00000000 ffffffff 00809300
GS =0000 00000000 ffffffff 00809300
LDT=0000 00000000 0000ffff 00008200
TR =0000 00000000 0000ffff 00008b00
GDT=     00000000 00000000
IDT=     00000000 000003ff
CR0=00000010 CR2=00000000 CR3=00000000 CR4=00000000
DR0=0000000000000000 DR1=0000000000000000 DR2=0000000000000000 DR3=0000000000000000
DR6=00000000ffff0ff0 DR7=0000000000000400
EFER=0000000000000000
Code=7c 68 01 00 68 10 00 b4 42 8a 56 00 8b f4 cd 13 9f 83 c4 10 <9e> eb 14 b8 01 02 bb 00 7c 8a 56 00 8a 76 01 8a 4e 02 8a 6e 03 cd 13 66 61 73 1c fe 4e 11
I've searched this error, and the main areas of concern of this one is one guy trying to do a passthrough for a nvidia card in KVM/QEMU, not Synology, just a bare Linux install.  I've also seen many bug reports from an older Linux Kernel version from 2014ish.  I could get the exact number if anyone is interested, but google's first 10 results for a search on KVM internal error suberror 1, will provide all the information I've learned so far.
I found that mounting the Ubuntu install CD, and setting the VM to boot from the CD instead of a disk will in fact start the VM.  If I try to boot from the "Boot from first hard disk" from the live CD, I get an error on the noVNC console that states "Booting from local disk...   Boot failed: press a key to retry..."
I am running an older Core2 Quad Q9550, but verified that KVM is compatible with it.
# egrep -c '(vmx|svm)' /proc/cpuinfo
4
According to the KVM docs, as long as the results to that command isn't 0 I should be good.  We don't have other packages installed, such as kvm-ok, so I couldn't test everything.
It has something to do with the bootloader that Windows is installing.
* I booted the Windows VM off the Ubuntu 16.04 Desktop Live CD.
* I choose to install Ubuntu 16.04 Desktop on the same disk as Windows, shrinking the Windows partition to allow Ubuntu to fit.
* After Ubuntu installed, I shut down the VM, unmounted the Ubuntu Live CD and started the "Windows" VM.
* This time, it booted into GRUB ( I think this is what Ubuntu 16.04 is still using. :smile: )
* The default value is Ubuntu, but I choose "Windows Vista" even though it's currently Windows 2016 Server Datacenter edition.
* She booted up just fine into Windows.  So, we have to figure out what Windows is doing to the boot loader that KVM/QEMU (aka Synology Virtual Machine Manager) isn't liking on our system.
  • 3 months later...
Some news on this?
I got the same problem and test the grub workaround as i write.
(AND IT WORK!!!)
For me as linux noob, it is ~6GB lost linux space in every windows VM,
plus the linux install overhead. no exactly smooth.
Is it possible to only install GRUB from a live cd or somth like that,
and defining windows as first boot selection?
TIA and special thanks @Nucklez !
