pigr8 Posted July 20, 2017 Share #1 Posted July 20, 2017 Hi, i'm testing the latest DSM version on ESXi 6.5 with the 1.02b loader, i got the VM up and running, first boot everything is ok and system does all the stuff to boot and install itself. This is the log for the first boot, before install https://pastebin.com/s7yuweeA This is the log after the first reboot, and everything looks normal to me https://pastebin.com/mH0gtxu8 This is the log after the second reboot, and all the reboots after this https://pastebin.com/EWsWQBk8 If i shut down the VM and restart it, this happens: https://pastebin.com/pjZH6z8W ------------upgrade Begin upgrade procedure No upgrade file exists End upgrade procedure ============upgrade Exit on error [7] Version number not match... and system goes in recovery, wants to fix via webui, than reboots fine everytime until i poweroff the VM.. after poweroff "Version number not match", fixes, reboots fine. Anyone knows why it does this? Thank You Link to comment Share on other sites More sharing options...
pigr8 Posted July 21, 2017 Author Share #2 Posted July 21, 2017 Figured out myself yesterday, i had to change the bootloadet img from "indipendent - non persistent" to "indipendent - persistent" 1 Link to comment Share on other sites More sharing options...
cruise Posted July 23, 2017 Share #3 Posted July 23, 2017 On 2017. 7. 21. at 8:45 PM, pigr8 said: Figured out myself yesterday, i had to change the bootloadet img from "indipendent - non persistent" to "indipendent - persistent" I have same issue. Pleas let me know how to change the bootloadet img . please Link to comment Share on other sites More sharing options...
