Capes Posted July 20, 2017 #1 Posted July 20, 2017 I had dowloaded the .ISO format from here (managed by Polanskiman) , but can't boot in new VM. Anyone know howto ,or where can i find the guide? Quote
agent47SG1 Posted July 20, 2017 #2 Posted July 20, 2017 (edited) Hello, It's strange, i have downloaded this iso file but i cant' open it. Try whis img file by creating a Loader 1.02b.vmdk file containing this lines if you use vmware Quote # Disk DescriptorFile version=1 CID=22733fd4 parentCID=ffffffff isNativeSnapshot="no" createType="vmfs" # Extent description RW 102400 VMFS "synoboot.img" 0 # The Disk Data Base #DDB ddb.adapterType = "lsilogic" ddb.deletable = "true" ddb.encoding = "UTF-8" ddb.longContentID = "6cbe0014ae8067fbd13c4b9522733fd4" ddb.thinProvisioned = "1" ddb.toolsInstallType = "4" ddb.toolsVersion = "10247" ddb.uuid = "60 00 C2 9a ee da ca 33-df 5e 04 3f 80 55 f9 62" ddb.virtualHWVersion = "10" Edited July 20, 2017 by agent47SG1 Quote
Terabyte Posted July 20, 2017 #3 Posted July 20, 2017 For ESXi I have used this converter to convert the ISO. https://www.starwindsoftware.com/converter Use starwind V2V Converter Select VMF Prealicated Image Select IDE I did change the boot order in the Juns loader so the Vm loader was first in the boot order. Here is an old video that may help. Quote
Capes Posted July 21, 2017 Author #4 Posted July 21, 2017 starwind V2V Converter just conver the vm disk file , not for ISO Quote
Capes Posted July 21, 2017 Author #5 Posted July 21, 2017 can boot from the vmdk that creating with "synoboot.img" , and i can find the device to setup , but it show " failed to format the disk. (35)" when installing the DSM. Quote
pigr8 Posted July 21, 2017 #6 Posted July 21, 2017 download this: https://www.dropbox.com/s/ytimsezu9cl61xx/synoboot_1.02b_ESXi_only.zip?dl=0 the only option available is ESXi, so you should not have problems regarding boot choice, it's for DS3615xs (i find has a better custom package support than DS3517xs). - extract and upload synoboot.vmdk and synoboot.img in your datastore - create a new VM (HW Version 11 or 13) dependent if you are on ESXi 6.0u2 or ESXi 6.5b - operating system should be Other -> FreeBSD 64bit - set bios to EFI - set nic to VMXNET3, set the mac manual to the same as the one in the grub.cfg - set scsi controller 0 to "LSI logic SAS" - add sata controller 0 if not there yet present - add existing hdd -> browse datastore -> add synoboot.vmdk - edit this hdd to "independent - persistent" and sata 0:0 on controller 0 - add how many new scsi disk you like, thin provisioning - dependent - save and poweron the VM - from your browser, go to find.synology.com, it should pop-up, connect and install it (manual or from internet is the same), reboot after finish the setup - create a new volume to your needs, if you want shr you have to modify synoinfo.conf - download this zip for open-vm-tools https://www.dropbox.com/s/k4hc343gwdepiuf/open-vm-tools_bromolow-6.0_10.0.7-1.spk.zip?dl=0 - extract the zip, install the spk in package manager - now ESXi should see that vm tools are installed and running Pretty much done. 8 3 Quote
truncj Posted August 25, 2017 #7 Posted August 25, 2017 On 7/21/2017 at 9:02 AM, pigr8 said: download this: https://www.dropbox.com/s/ytimsezu9cl61xx/synoboot_1.02b_ESXi_only.zip?dl=0 the only option available is ESXi, so you should not have problems regarding boot choice, it's for DS3615xs (i find has a better custom package support than DS3517xs). Thanks a ton for posting this.. it worked perfectly! This was literally the only ESXi image that I could find, now that they've decided to distribute ISOs that I can't mount. Did I miss something? Or are people really not using 1.02b with ESXi? Quote
bagheera Posted January 21, 2018 #8 Posted January 21, 2018 Just followed this guide and worked perfectly. Running on Dell R710 with ESXI 6.5 U1 Thank you! Quote
Alex_G Posted February 9, 2018 #9 Posted February 9, 2018 Just followed this guide and worked perfectly,... untill first restart. Can someone help me what i've done wrong. After restart Volume is gone. I did manualy instal DSM 6.1.4 Update 1 But othervise first manuals that startup at first shoot! Thank you so far pigr8!!! Quote
kazuni Posted July 27, 2018 #10 Posted July 27, 2018 Thank you so much Pigr, this is the only image that works on my ESXi 6.7, much appreciated! Quote
klutch14u Posted December 13, 2018 #11 Posted December 13, 2018 On 7/21/2017 at 8:02 AM, pigr8 said: download this: https://www.dropbox.com/s/ytimsezu9cl61xx/synoboot_1.02b_ESXi_only.zip?dl=0 the only option available is ESXi, so you should not have problems regarding boot choice, it's for DS3615xs (i find has a better custom package support than DS3517xs). - extract and upload synoboot.vmdk and synoboot.img in your datastore - create a new VM (HW Version 11 or 13) dependent if you are on ESXi 6.0u2 or ESXi 6.5b - operating system should be Other -> FreeBSD 64bit - set bios to EFI - set nic to VMXNET3, set the mac manual to the same as the one in the grub.cfg - set scsi controller 0 to "LSI logic SAS" - add sata controller 0 if not there yet present - add existing hdd -> browse datastore -> add synoboot.vmdk - edit this hdd to "independent - persistent" and sata 0:0 on controller 0 - add how many new scsi disk you like, thin provisioning - dependent - save and poweron the VM - from your browser, go to find.synology.com, it should pop-up, connect and install it (manual or from internet is the same), reboot after finish the setup - create a new volume to your needs, if you want shr you have to modify synoinfo.conf - download this zip for open-vm-tools https://www.dropbox.com/s/k4hc343gwdepiuf/open-vm-tools_bromolow-6.0_10.0.7-1.spk.zip?dl=0 - extract the zip, install the spk in package manager - now ESXi should see that vm tools are installed and running Pretty much done. Did I miss a step? Where is the grub file? Quote
bearcat Posted December 14, 2018 #12 Posted December 14, 2018 @klutch14u in partition 0 of the synoboot.img, see my other reply. Quote
