DVB Tuners for DSM 6.xx
lilmonkey
Can anyone confirm which (if any) drivers for DVB tuners are added for the new 6.x.x releases of DSM via Xpenolgy?
Looking at the Synology site, my pctv 292e is supported for some devices, but not he 3615xs that is generally used for Xpenology..
Does this mean that the drivers are not available? Can they be manually installed?
How do i do this?
ANy help with DVD please?
Any info about supported DVB-C tuners? I know that VideoStation do not support DVB-C at the moment, but I am going to use it with tvheadend.
As I have understood Sundtek products are well supported, but they are quite expensive too, so I am searching something cheaper, like Geniatech T230/T230C or DVB-C tuner from eBay on RTL2832P. But I can not find any info about driver support in Synology linux kernel or about possibility to compile/install drivers manually.
Please share your experience about using DVB-C on DSM 6.1 and supported/working tuner list.
Edited by Kostja_V
There are several dvb-c tuners that work very well, but you have to compile modules.
I was using TBS 6281 and 6205 in dvb-c/t mode and work exelent, using tvheadend and its exelent works 100% on a bare metal instalation of dsm.
Recently i changed to vmware esxi, and separeted dvb card and tvheadend to an ubuntu instalation, only because can use intel quicksync on ffmpeg, dsm doesent alow this kind of configuration.
Other than that dsm+tvh+dvb works 100%.
If you are buying an pciex dvb card, buy one from tbs and you have modules compiled by me to dsm 5.2 and 6.0, new versions if someone wants to help a can cross compile tbs again.
  • 3 weeks later...
  • 3 months later...
  • 3 weeks later...
I've put in a floppy-dtv dvb-s and dvb-t tuner in my system. They're quite old technology now, just had them left over from previous projects.
They work well with tvheadend, I did have to compile the firewire modules first, then the firedtv modules to make it work. Video station doesn't recognise them.
Sent from my D5803 using Tapatalk
  • 1 month later...
  • 2 months later...
On 9 de agosto de 2017 at 4:28 PM, JMRR said:
Cant test i cant compile modules for 6.1.3. And my configuration doesent alow me to test.
My dvb card is not in dsm anymore.
Hi JMRR,
I've bought a tbs6922 card and I've spent for a week trying to compile the drivers with no success :(. I've followed all the guides that I found but I only was able to create files with non *.ko extension, could you give me some advice to compile the drivers? Thank you so much :)
there are two howto/tutorials in the "Tutorials and Guides" section
i use the chmod environment of my tutorial on a regular base to create drivers for my extra.lzma so its capable of producing drivers
depending on drivers from external source it might be different how they detect the kernel source installed, so it can be necessary to look into compile scripts or makefiles to see why they cant find the kernel source or have problems detecting the kernel version
Hi master!
Yep, I tried both and also this one although is not the brand that I'm looking for:
Also I downloaded the open source and the official drivers with no luck. I'm not an expert in this field and I'm sure that I'm making a lot of mistakes. As it seems that @JMRR was able to compile them in the past, perhaps can help me with this roadblock :)
Anyway, thank you so much for taking your time answering my post, linking the tutorials and your hard work in the project ;)
hello newby here been following xpenology for a few years on an off and have built smaller builds previously
xpenology build 6.1 jun1.02b bootloader
hp proliant dl160g6 dual xeon e5506 cpu
8gb ram
as per above i am having issues with two compatable usb dvb t and usb dvb s devices
DVB-TKWorldDVB-T UB499-2T (single tuner)             found by xpenlonlogy as  registered new interface driver dvb_usb_af9015
DVB-STechniSatSkyStar USB HD - DVB-S HDTV-Empfänger (4109/3734   found by synology as b2c2-flexcop: B2C2 FlexcopII/II(b)/III digital TV receiver chip loaded successfully
dmesg for dvbs skystar 2 comes back as
[14170.950769] usbcore: registered new interface driver b2c2_flexcop_usb
[17172.178559] usbcore: deregistering interface driver b2c2_flexcop_usb
[17172.197380] b2c2-flexcop: B2C2 FlexcopII/II(b)/III digital TV receiver chip unloaded successfully
[17212.382094] perf interrupt took too long (5199 > 10000), lowering kernel.perf_event_max_sample_rate to 25000
[17378.230587] b2c2-flexcop: B2C2 FlexcopII/II(b)/III digital TV receiver chip loaded successfully
[17378.237032] flexcop_usb: running at FULL speed.
[17378.406943] DVB: registering new adapter (FlexCop Digital TV device)
[17378.407951] b2c2-flexcop: MAC address = 00:d0:d7:30:87:2e
[17378.412948] b2c2-flexcop: no frontend driver found for this B2C2/FlexCop adapter
[17378.421980] usbcore: registered new interface driver b2c2_flexcop_usb
and the same for the k world any ideas is this a driver issue? nothing shows up in videostation or in info centere attached devices
any help is appretiated.
regards lew
  • 9 months later...
Hi .
I can not successfully compile the drivers for DSM 6.1 at these tuners:
(I tested in other OS)
Microsoft Xbox One Digital TV Tuner
USB ID of the tuner is 045e:02d5.
[47902.461786] dvb-usb: found a 'Microsoft Xbox One Digital TV Tuner' in cold state, will try to load a firmware
[47902.462206] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[47902.526955] dib0700: firmware started successfully.
[47903.035227] dvb-usb: found a 'Microsoft Xbox One Digital TV Tuner' in warm state.
[47903.035776] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[47903.035875] dvbdev: DVB: registering new adapter (Microsoft Xbox One Digital TV Tuner)
[47903.035891] usb 1-2: media controller created
[47903.037156] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[47903.246406] mn88472 6-0018: Panasonic MN88472 successfully identified
[47903.248355] tda18250 6-0060: NXP TDA18250BHN/M successfully identified
[47903.250020] usb 1-2: DVB: registering adapter 1 frontend 0 (Panasonic MN88472)...
[47903.250025] dvbdev: dvb_create_media_entity: media entity 'Panasonic MN88472' registered.
[47903.250312] dvb-usb: Microsoft Xbox One Digital TV Tuner successfully initialized and connected.
and..
 # lsusb | grep HanfTek
Bus 001 Device 004: ID 15f4:0131 HanfTek
:~ # dmesg  | grep dvb
[    2.498777] usb 1-1.2: Product: dvbt2
[    2.498793] usb 1-1.2: Manufacturer: astrometadvbt2
[   10.377272] kernel-overlays-setup: processing conf /storage/.cache/kernel-overlays/50-driver.dvb.dvb-latest.conf
[   10.607002] kernel-overlays-setup: added modules from /usr/lib/kernel-overlays/driver.dvb.dvb-latest/lib/modules/4.19.8
[   38.190995] usb 1-1.2: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
[   38.446411] usb 1-1.2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[   38.446508] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
[   38.521186] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[   39.494498] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
[   39.495081] dvbdev: dvb_create_media_entity: media entity 'Panasonic MN88473' registered.
[   40.204306] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
[   40.217875] usb 1-1.2: dvb_usb_v2: schedule remote query interval to 200 msecs
[   40.231212] usb 1-1.2: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
I need for DVB-C TV in TVHeadend&Plex Server
Can you add these drivers to XPenology?
  • 4 weeks later...
  • 11 months later...
Hi @JMRR, would you mind helping in getting TBS cards work on DS3516xs DSM 6.2.2-24922 Update 4 - kernel 3.10.105 #24922 SMP? I'm trying cross compiling from WSL but without success. thanks!
On 2/5/2020 at 3:54 PM, Selfmade RuLeZ said:
I just wanna share my found on GitHub. Successfully compiled WinTV DualHD on official Synology DS918+
https://github.com/th0ma7/synology
Thank you very much!
I would like to do the same for an August DVB-T202 (ID 048d:9006 Integrated Technology Express, Inc. IT9135 BDA Afatech DVB-T HDTV Dongle) with a DS3615xs loader.
Do you think I can use the same walkthrough?
You have to look, if your card or usb device is marked as supported in the wiki:
https://linuxtv.org/wiki/index.php/Hardware_device_information
If you don‘t find your device, you have to figure out which demodulator and tuners your card has and find out if these will be supported in the linux kernel.
You have to tweak the kernel specific settings in the tutorial to compile it for the DS3615xs Loader. Good Luck! :)
My mistake, this is only available for the Apollolake and Avoton CPUs, so I think this is only valid for the DS918+ loader 😕
  • 2 years later...
