Control Panel always opens
On one of my 6.02 builds, suddenly the Control Panel opens on every login. Tried to toggle disable Resume option on personal settings a few times, without any luck...
On another identical build all works well. Both updates from5.2 to DSM 6.0.2-8451 Update 1, using Jun's v1.01 loader.
It is just annoying, not serious :(
7 answers to this question
Hm..other build have the same update available, but do not open control panel. Will investigate further along suggested lines.
Edited by Gronaldo
have a look at your DSM update settings and disable auto updates and set to 'critical only', this wont necessarily stop the pop up until you update, but if you are on the 'latest critical update' then it wont show newer ones
Answer this question...
