Debug_Bug 0 Posted October 15, 2017 Share Posted October 15, 2017 On 12/10/2017 at 10:05 PM, Debug_Bug said: I have expierenced the following problems (so far) with Update 6: I'm unable to change the DSM interface ports away from 5000 / 5001 - the were different before the update but now I cant change them I can only access the DSM on port 5000 (without https) trying https:// on port 5001 does not work - nothing responds Photo station no longer works, even after uninstall/reinstall I'm unable to access it (it simply opens DSM when clicking the icon) The Synology search tool detects the server but clicking connect inside the tool opens the browser on the ports I used to use (8080) even though the web interface now only responds on port 5000 and I can not change the port. Anyone else seeing something like this? FYI, the above problem was solved when updating to update 7 through the control panel. Everything seems to be working now (juns loader 1.02b). Quote Link to post Share on other sites
haldi 7 Posted October 18, 2017 Share Posted October 18, 2017 I don't see any reason to do the update 7 as most is ds918 update stuff. So I'll just skip it. Quote Link to post Share on other sites
tabajdi 4 Posted October 22, 2017 Author Share Posted October 22, 2017 Uppdate to DSM 6.1.3-15152 Update 8 is OK Quote Link to post Share on other sites
tabajdi 4 Posted November 14, 2017 Author Share Posted November 14, 2017 Uppdate to 6.1.4-15217-1 is safe. Quote Link to post Share on other sites
Polanskiman 442 Posted November 23, 2017 Share Posted November 23, 2017 This is not really the place to report updates working or not. There is a specific forum just for that: https://xpenology.com/forum/forum/78-critical-updates/ Quote Link to post Share on other sites
Mad Max 0 Posted December 5, 2017 Share Posted December 5, 2017 Hi everyone, I've been following this forum for a few months now. I also tested xpenology project in vmware workstation for a long time and finaly decided to to take the ride on real baremetal box. I managed to get hp microserver gen8 1610T version few weeks ago (probably one of the last boxes out there :)) and now i would appreciate some advice from gen8 users regarding bios settings. As i understand from posts sata ports should be set as sata ahci mode. Done that. Also enabled wake on lan in bios. Is there anything else to consider? Specifically: -system options serial port options com2 -power management option hp power profile balanced power and performance hp power regulator hp dynamic power saving mode Any advice on these? or anything else maybe i should pay attention? Also would like to know how you power server on if there's power outage for example so server is shut off and your not home. You use WOL or iLo console or app for powering it on? Oh, and forgot to mention since this will be a fresh install i'll be using juns loader 1.02b and dsm 6.1.4 Thank you for help and for this great project. Quote Link to post Share on other sites
thibsie 0 Posted December 13, 2017 Share Posted December 13, 2017 Hi guys, just a quick question: Is there any way to force grub to boot on ODD sata port rather than SATA HDD 1 port ? Thanks Quote Link to post Share on other sites
grafiprints 0 Posted February 4, 2018 Share Posted February 4, 2018 (edited) Hi Guys, Did anyone had issues with gen8, jun 1.02b, dsm 6.1.5 on baremetal? Sometimes when i play with packages (install or uninstall some packages) i encounter a volume crash, my web interface is showing "Sorry, the page you are looking for is not found." The only way i can get it to work again is to put another drive, fresh reinstall the dsm and hotplug the old hdd in place, the volume is mounted and shows up as damaged, quick repair and it's working (i have to waste an hour to reinstall all my packages and put all the settings back). Does anyone knows why is this happening ? Forgot to mention that ssh and web interface doesn't work, i can work with my smb folders but only until i make the first restart of microserver, after that everything is down. Thanks Edited February 4, 2018 by grafiprints Quote Link to post Share on other sites
nokian80 1 Posted February 6, 2018 Share Posted February 6, 2018 Hello i have HP proliant microserver gen 8 and i make usb boot with loader v1.02a2 and i try to install DSM_DS3617xs_15047.pat but i see this message again and again failed to install the file probably corrupt 13 Any help? Quote Link to post Share on other sites
Dfds 87 Posted February 6, 2018 Share Posted February 6, 2018 59 minutes ago, nokian80 said: Hello i have HP proliant microserver gen 8 and i make usb boot with loader v1.02a2 and i try to install DSM_DS3617xs_15047.pat but i see this message again and again failed to install the file probably corrupt 13 Any help? You would be better off running DS3615xs & jun's 1.02b loader, also make sure you have set the vid & pid of the USB correctly. Quote Link to post Share on other sites
nokian80 1 Posted February 6, 2018 Share Posted February 6, 2018 You would be better off running DS3615xs & jun's 1.02b loader, also make sure you have set the vid & pid of the USB correctly.The latest update of 3615? Dsm 6.1.5??Sent from my iPhone using Tapatalk Pro Quote Link to post Share on other sites
nokian80 1 Posted February 6, 2018 Share Posted February 6, 2018 i ll try DSM_DS3615xs_15101.pat but i have still the same error Quote Link to post Share on other sites
Djulien 1 Posted February 6, 2018 Share Posted February 6, 2018 i ll try DSM_DS3615xs_15101.pat but i have still the same errorDid you set the correct vid and pid? Gesendet von meinem ONEPLUS A3003 mit Tapatalk Quote Link to post Share on other sites
nokian80 1 Posted February 6, 2018 Share Posted February 6, 2018 Just now, Djulien said: Did you set the correct vid and pid? Gesendet von meinem ONEPLUS A3003 mit Tapatalk no i did not set anything. Only i make the boot usb and i try to imstall the .pat file Quote Link to post Share on other sites
Djulien 1 Posted February 6, 2018 Share Posted February 6, 2018 no i did not set anything. Only i make the boot usb and i try to imstall the .pat fileYou need to mount the .img file from jun and edit the vid and pid values, you should also set the Serial Number and the MAC to your real nic mac. There is a pretty good tutorial here. https://xpenology.com/forum/index.php?/topic/7973-Tutorial:-Install/Migrate-DSM-5.2-to-6.1.x-(Jun's-loader) 1 Quote Link to post Share on other sites
nokian80 1 Posted February 6, 2018 Share Posted February 6, 2018 Thanks my friend i think its ready! 1 Quote Link to post Share on other sites
haldi 7 Posted November 1, 2018 Share Posted November 1, 2018 Question.... is it possible to update to launcher 1.04b and use DS918 software? According to it's the new 4.4 Kernel and needs Haswell or later CPU, which we don't have. Quote Link to post Share on other sites
bearcat 83 Posted November 2, 2018 Share Posted November 2, 2018 @haldi I think you answered yourself: Quote it's the new 4.4 Kernel and needs Haswell or later CPU, which we don't have. Quote Link to post Share on other sites
tabajdi 4 Posted December 10, 2018 Author Share Posted December 10, 2018 Is it possibile to install a later release than DSM 6.2-23739 on Gen8 on Baremetal? Quote Link to post Share on other sites
net 0 Posted June 3, 2019 Share Posted June 3, 2019 On 12/10/2018 at 2:05 AM, tabajdi said: Is it possibile to install a later release than DSM 6.2-23739 on Gen8 on Baremetal? nope, you have to install an Intel NIC so that you can enjoy DSM like 6.2.1 and 6.2.2. I just tried on my Microserver Gen8 Quote Link to post Share on other sites
Polanskiman 442 Posted June 4, 2019 Share Posted June 4, 2019 On 12/10/2018 at 3:05 PM, tabajdi said: Is it possibile to install a later release than DSM 6.2-23739 on Gen8 on Baremetal? We are going off tracks here. This thread is meant for Microserver Gen8 on DSM 6.1 as its title suggests. Any question related to DSM 6.2 please either refer to other available topics or create a new one. You can also check the DSM Updates Reporting sub-forum to check if your hardware is upgradable to DSM 6.2. Quote Link to post Share on other sites
