[SOLVED] How to create multiple Volume
After installation and when I tried to create Volumes, it under creating a RAID 5 Array, I found that it is not allowing me to create more than one Volume.
Is this a limitation or am doing something wrong.
In my Raid Array I've 4 HDDs of 3 Tb each.
Can anyone help...
Regards
Rakesh Gupta
During installation of DSM it will ask you if you wish to do an install for only one volume, or to select an option allowing multiple volumes to be used. It's during the early steps just after you have completed the basic install and gone back into DSM and selected you username if I recall.
