UNSC-117 Posted May 12, 2017 Share #1 Posted May 12, 2017 Can anyone point to set up power button on 6.1.1 xxxx Quote Link to comment Share on other sites More sharing options...
filippo333 Posted May 12, 2017 Share #2 Posted May 12, 2017 Can anyone point to set up power button on 6.1.1 xxxx +1 Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
ouzycn Posted May 14, 2017 Share #3 Posted May 14, 2017 Don't understand what is "power bottom". in DSM UI, up right corner has a User symbol, it has restart, power off functions. Does it not fit your requirement? Quote Link to comment Share on other sites More sharing options...
abced Posted May 14, 2017 Share #4 Posted May 14, 2017 Don't understand what is "power bottom". in DSM UI, up right corner has a User symbol, it has restart, power off functions. Does it not fit your requirement? People want to shut down the box pressing physical button on their machine. It works like that on real boxes too. Quote Link to comment Share on other sites More sharing options...
Lordbl4 Posted May 15, 2017 Share #5 Posted May 15, 2017 try this - viewtopic.php?f=2&t=32773 or this - viewtopic.php?t=889#p7305 Quote Link to comment Share on other sites More sharing options...
IG-88 Posted May 15, 2017 Share #6 Posted May 15, 2017 instead of the second link (outdated) there is a description how to di it manualy for dsm 6 http://xpenology.com/forum/viewtopic.ph ... wer#p99213 but no need to do that, the first link with spk for 6.1 works also with 6.1.1 (tested with u1 and u2, jun 1.0.2a 3515xs) btw. also usefull for VM usage, you can select acpi power button shutdown in the vm options to shut down the xpenology vm 1 Quote Link to comment Share on other sites More sharing options...
