mmedeiro 0 Posted May 11, 2017 Share Posted May 11, 2017 Hi, I'm currently on a 5 bay Syno + NAS with 2 dual bay expansion units for a total of 9 drives in a single SHS raid. I'm looking to move this to a PC/XPEnology setup without transferring the data to new drive. I want to physically move the drives to the newly created NAS while keeping the RAID intact. Hardware 2011 Sabertooth X79 with a I7 4820k CPU LSI00244 16 port sata controller Is it possible to get 2 raid PCI controllers and run them in tandem, i.e. 2 8-port raid cards for a total of 16 ports while running 1 raid array across the 2 cards. At this point im not interested in splitting the raid arrays i would like to continue with the monster i created. I'm hoping this is possible, if not; thats cool, i guess i'll have to move the 32tb of data via transfer which should take roughly 12 centuries lol. [spoiler=More info]Hardware x79 Sabertooth motherboard with an Intel 4820k CPU Intel® X79 chipset : 2 x SATA 6Gb/s port(s), brown 4 x SATA 3Gb/s port(s), black Support Raid 0, 1, 5, 10 Marvell® PCIe 9128 controller : 2 x SATA 6Gb/s port(s), gray 32 GB of ram 2 8 port LSI PSI Sata cards SAS9211-8I Here is my dmesg exported https://mega.nz/#!q8p1XYgS!xjCMRdLxQL41 ... _zEcGIQch0 Currently only the Marvell PCIe ports are recognizing drives, the other on-board ports are not recognized in DSM I need to correctly map the sataports and transfer a 9 disk SHR-2 array from my old Syno Diskstation to this Xpenology station. Quote Link to post Share on other sites
LittleLama 2 Posted May 12, 2017 Share Posted May 12, 2017 If I have correctly understood, your 9 drives are currently running one DSM. If so, I'm pretty sure you can move your drives in one move because Synology RAIDS are Software based. DSM will be moved as well and you will be able to migrate it. Quote Link to post Share on other sites
mmedeiro 0 Posted May 12, 2017 Author Share Posted May 12, 2017 Correct. All 9 are currently on 1 SHR-2 raid. I'm looking to move the raid from a Syno box to a Xpenoplogy machine. If i can do this using 2 raid cards that are cheaper and easier to source rather than a single card with all 12 ports that would be the last piece to the puzzle. Thanks Quote Link to post Share on other sites
LittleLama 2 Posted May 12, 2017 Share Posted May 12, 2017 If you don't got them yet, you can find in my signature a model of SATA Extension Card that is working fine with XPenology. I don't see at this point why your migration may fail. Let's take the time to have one more advice to be sure. Of course you will take care of correctly config your Grub with the good combination of SataPortMap=422 The first 4 representing the number of your SATA drives wired on your motherboard, the nexts the number of you SATA drives wired on secondary cards. E.G. : 5 SATA on motherboard, 4 on secondary SATA Card => SataPortMap=52 Quote Link to post Share on other sites
mmedeiro 0 Posted May 12, 2017 Author Share Posted May 12, 2017 Great. Here is my Mobo Intel® X79 chipset : 2 x SATA 6Gb/s port(s), brown 4 x SATA 3Gb/s port(s), black Support Raid 0, 1, 5, 10 Marvell® PCIe 9128 controller : 2 x SATA 6Gb/s port(s), gray I also have 2 on the rear panel that i would not be using. I will be adding 3 of the cards you suggested for 6 additional ports soo.. SataPortMap=86 or SataPortMap=8222? Thanks, Quote Link to post Share on other sites
LittleLama 2 Posted May 12, 2017 Share Posted May 12, 2017 Assuming that 2+4+2 SATA ports are on your motherboard, the right string is well 8222 I'm curious to know what box you got that let you fill it with all theses drives. Quote Link to post Share on other sites
mmedeiro 0 Posted May 12, 2017 Author Share Posted May 12, 2017 Haha I just started looking at the boxes and now I'm at a bit of a road block. The mobo, ram and CPU are being sourced from my old rig so my only costs will be the box, PSU and PCI sata cards. I wanted to spend less than $500 on the box but it looks like a 16 drive box is going to run me much more than that. Quote Link to post Share on other sites
mmedeiro 0 Posted May 12, 2017 Author Share Posted May 12, 2017 Actually this is looking like the front runner... https://www.amazon.com/dp/B00XCA86OM/re ... UTF8&psc=1 Quote Link to post Share on other sites
IG-88 714 Posted May 15, 2017 Share Posted May 15, 2017 hi, there is no "tandem" its just software raid on sata ports, if there is more then one controller providing the ports the order of the controller/ports might be important (depending on how you specify it in the syno config file, the default is 12 ports in a row, behind that the sata ports and then the usb ports) you might take thist into consideration if you want to move your drives directly to a new hardware viewtopic.php?f=2&t=16933 afaik the SataPortMap is about how the ports are spread over the controllers and the order of the ports in the case of your board (you have not specifiyd the brand) it might be SataPortMap=242 or SataPortMap=62 the 88SE9128 chip has only 2 ports so the 2 external ports you mention might have a diffrent (additional) controller you did not specify or there are "switchable" from 2 internal to 2 extrenal (sometimes seen this with controller cards, not so often on boards - provide more/exaxt information and the predictions get better) for 9 disks/ports you still missing ports so you will need a additional controller with at least 2 ports if you have all ports in a row, fill the "slots" (ports) without a gap and specify the ports (internal sata, external sata, usb ports, -> ) in the config correctly, then to set SataPortMap might be of no importance you should realy be carefull if you do this without a backup and tranfering the drives directly, if you do you should map the order of the drives from the "old" system and should do a test installtion on the new system with one drive (test-installing the dsm 6.x) and map the ports with a additional drive so you know exactly the order of the ports in you new system, after you are shure about the port mapping you could put in your 9 drives and install the new dsm to it (keeping the data raid) imho you should be prepared that the synology dsm riad fails and you have to use an live linux trom usb to manualy reasemble/recover your data raid and backup/offload it (after your first attempt of directly migarting fails spectecular) beside putting in all 9 drives in install the new dsm (without the option to modify the configuration first, the first boot will be with the 12 drive default of the 3615/3617) there is also the option to install one addtional (10th) drive first, modify the config according to the new hadware, put the 9 old drives in and see if the system comes up booting from the one drive and "spreading" the working system to the 9 "additional" drives (expanding the system partition raid1 from 1 drive to 10 drives) if that works you will have the system on all 10 drives an can remove the 10th drive it might be possible to test all this in a vm (virtualbox) before doing it with the baremetal but it will take some time its much safer and easyer to have a backup of all date Quote Link to post Share on other sites
mmedeiro 0 Posted May 16, 2017 Author Share Posted May 16, 2017 Wow. Thanks for the reply. I would not be devastated if i lost the data to be honest. I'm worried the sata ports on the rear panel will some how effect my setup and break the 9 disk array. I have the 8 ports on the board and i'm looking to add 4 via 2 pci cards. I want to expand the disk array to 12 and I'm hoping the major improvement in hardware will drastically cut down the time it takes to add and replace disks in the raid array bc currently it takes like 2 weeks to add or replace a single disk which really sucks. Quote Link to post Share on other sites
IG-88 714 Posted May 16, 2017 Share Posted May 16, 2017 what board? i can check the specs and doku about the external sata ports btw, there are also 4 port cards, might be better to keep a slot free for later (10GBit nic) Quote Link to post Share on other sites
mmedeiro 0 Posted May 17, 2017 Author Share Posted May 17, 2017 Cool i appreciate that! Board is the x79 ASUS Sabertooth with 64gb RAM and a 4820k CPU. I bought the LSI SAS9211-8I 8PORT rather than the 2 cards and already built the system. Tomorrow I will attempt the installation of Xpenology before moving my array to the machine. Your advice would be appreciated! Quote Link to post Share on other sites
Eduardo 3 Posted May 17, 2017 Share Posted May 17, 2017 I'm almost in the same boat. That's a nightmare! Actually: HP N54L + LSI SAS9211-8I + 5.2 DSM N54L has 6 sata ports (4 sata, 1 eSata, 1 optical Sata) and 6 USB ports LSI SAS9211-8I has 8 sata ports. I changed ODD with a hot swap bay case. I want Back eSATA and ODD set as eSATA. That's my goal. As the 8 ports of the LSI SAS9211-8I appear as one on esataportcfg (7th) and can't separate 2 from the rest, my solution was: Four internal disks are controlled by the LSI SAS9211-8I Back eSATA and hot swap bay case (ODD) are set eSATA and controlled by N54L MOBO 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00(ODD)(back_eSATA) 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0(LSI 8 ports)00 (MOBO_sata)(MOBO_sata)(MOBO_sata)(MOBO_sata) = internalportcfg So, config that works flawlessly: esataportcfg="0x0030" usbportcfg="0x3f80" internalportcfg="0x004f" maxdisks="12" 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0100 1111 = internalportcfg I think is time to move to 6.1.1, but after reading and reading some times, I still can't understand and I'm not sure what to set on grub and synoinfo.conf. Quote Link to post Share on other sites
IG-88 714 Posted May 18, 2017 Share Posted May 18, 2017 I'm almost in the same boat. That's a nightmare! Actually: HP N54L + LSI SAS9211-8I + 5.2 DSM N54L has 6 sata ports (4 sata, 1 eSata, 1 optical Sata) and 6 USB ports LSI SAS9211-8I has 8 sata ports. I changed ODD with a hot swap bay case. I want Back eSATA and ODD set as eSATA. That's my goal. As the 8 ports of the LSI SAS9211-8I appear as one on esataportcfg (7th) and can't separate 2 from the rest, my solution was: Four internal disks are controlled by the LSI SAS9211-8I Back eSATA and hot swap bay case (ODD) are set eSATA and controlled by N54L MOBO 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00(ODD)(back_eSATA) 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0(LSI 8 ports)00 (MOBO_sata)(MOBO_sata)(MOBO_sata)(MOBO_sata) = internalportcfg So, config that works flawlessly: esataportcfg="0x0030" usbportcfg="0x3f80" internalportcfg="0x004f" maxdisks="12" 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0100 1111 = internalportcfg I think is time to move to 6.1.1, but after reading and reading some times, I still can't understand and I'm not sure what to set on grub and synoinfo.conf. imho (if i "gap" in the internal sata ports is allowed - never tried that) this would be the configuration to try: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 1111 1100 0000 0000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1100 1111 = internalportcfg esataportcfg="0x0030" usbportcfg="0xfc000" internalportcfg="0x3fcf" maxdisks="12" asumtion on that is the system (dsm) finds the 4+2 (or 4+1+1) onboard first and the lsi is last what you did (with the placeholders for a "1") would correctly "writen" look like this (lis = 8 Ports = 8 x 1, mobo 4 x 1) 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 011 1111 1100 1111 = internalportcfg or with additinal "0" from the right side, so its good to read 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1100 1111 = internalportcfg (red marks a error, 3 bit instead of 4, but in this case it does'nt matter it's only the "0" for filling) you see the problem (to "read" from left to right = lower bits first)? internal and usb overlaping - not good Quote Link to post Share on other sites
Eduardo 3 Posted May 18, 2017 Share Posted May 18, 2017 asumtion on that is the system (dsm) finds the 4+2 (or 4+1+1) onboard first and the lsi is last what you did (with the placeholders for a "1") would correctly "writen" look like this (lis = 8 Ports = 8 x 1, mobo 4 x 1) 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 011 1111 1100 1111 = internalportcfg or with additinal "0" from the right side, so its good to read 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 1111 1100 1111 = internalportcfg (red marks a error, 3 bit instead of 4, but in this case it does'nt matter it's only the "0" for filling) you see the problem (to "read" from left to right = lower bits first)? internal and usb overlaping - not good It makes sense. I'll try it. Not sure why I had seven "1" on usbportcfg. And what about Grub? SataPortMap=68 ? Quote Link to post Share on other sites
mmedeiro 0 Posted May 19, 2017 Author Share Posted May 19, 2017 So out of the box DSM recognized the 8 LSI ports and then 4 out of the 8 Mobo ports. I tried hotswapping between the MOBO ports but only 2 out of the 4 listed are working. So the two marvell ports are working but the 6 intel ports are now. Im fine with buying another LSI card and running 18 ports. I have no idea how to use GRUB to map the ports correctly. This is my mobos sata controllers. Intel® X79 chipset : 2 x SATA 6Gb/s port(s), brown 4 x SATA 3Gb/s port(s), black Support Raid 0, 1, 5, 10 These 2 are part of the 4 since Marvell® PCIe 9128 controller : 2 x SATA 6Gb/s port(s), gray Quote Link to post Share on other sites
mmedeiro 0 Posted May 19, 2017 Author Share Posted May 19, 2017 Going to start a new thread but is shr2 not available on Xpenology due to it emulating a system that does not support shr? Quote Link to post Share on other sites
Eduardo 3 Posted May 19, 2017 Share Posted May 19, 2017 So out of the box DSM recognized the 8 LSI ports and then 4 out of the 8 Mobo ports. I tried hotswapping between the MOBO ports but only 2 out of the 4 listed are working. So the two marvell ports are working but the 6 intel ports are now. Im fine with buying another LSI card and running 18 ports. I have no idea how to use GRUB to map the ports correctly. This is my mobos sata controllers. Intel® X79 chipset : 2 x SATA 6Gb/s port(s), brown 4 x SATA 3Gb/s port(s), black Support Raid 0, 1, 5, 10 These 2 are part of the 4 since Marvell® PCIe 9128 controller : 2 x SATA 6Gb/s port(s), gray Did you try SataPortMap=242 or SataPortMap=62? Quote Link to post Share on other sites
Eduardo 3 Posted May 19, 2017 Share Posted May 19, 2017 (if i "gap" in the internal sata ports is allowed - never tried that) Yes, gap has been working here from some years ago. I mapped to eSATA flawlessly. Quote Link to post Share on other sites
IG-88 714 Posted May 19, 2017 Share Posted May 19, 2017 So out of the box DSM recognized the 8 LSI ports and then 4 out of the 8 Mobo ports. I tried hotswapping between the MOBO ports but only 2 out of the 4 listed are working. So the two marvell ports are working but the 6 intel ports are now. Im fine with buying another LSI card and running 18 ports. I have no idea how to use GRUB to map the ports correctly. This is my mobos sata controllers. Intel® X79 chipset : 2 x SATA 6Gb/s port(s), brown 4 x SATA 3Gb/s port(s), black Support Raid 0, 1, 5, 10 These 2 are part of the 4 since Marvell® PCIe 9128 controller : 2 x SATA 6Gb/s port(s), gray well i took you word for granted that the mobo has 6 ports, if there are 8 (6+2) and they are found before the lsi it will look different in the mapping the bits/ports in the mapping have to tke all "visible" sata ports into account so if its 6+2+8 the correct mapping will look like this 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1100 0000 = esataportcfg 0000 0000 0000 0000 0000 0000 0011 1111 0000 0000 0000 0000 = usbportcfg 0000 0000 0000 0000 0000 0000 0000 0000 1111 1111 0011 1111 = internalportcfg esataportcfg="0xc0" usbportcfg="0x3f0000" internalportcfg="0xff3f" maxdisks="14" Quote Link to post Share on other sites
mmedeiro 0 Posted May 19, 2017 Author Share Posted May 19, 2017 I have to be honest would you, you're talking above my head at this point. DSM recognized 8 LSI then 4 MOBO ports. I just ordered another 8 ports LSI card and i think im just going to forgo using the onboard port bc I just don't have a good grasp of mapping. Im a total Iinux beginner and this might as well be Chinese to me at this point lol. If theres a good tut that will explain this all to me than im sure i can learn but right now i cannot interpret your instructions. Quote Link to post Share on other sites
antihrist2002 2 Posted May 19, 2017 Share Posted May 19, 2017 Hi, I think this will help https://hedichaibi.com/fix-xpenology-pr ... rd-drives/ but use WinSCP to edit files, not vi. Quote Link to post Share on other sites
mmedeiro 0 Posted May 20, 2017 Author Share Posted May 20, 2017 Ok so i was able to figure out how to edit these values. Now i have to figure out which controller is being seen first second and third. I now have 2 LSI controllers for 16 ports and then the above onboard sata ports. I have uploaded my dmesg below hopefully someone can decipher. https://mega.nz/#!q8p1XYgS!xjCMRdLxQL41 ... _zEcGIQch0 Quote Link to post Share on other sites
antihrist2002 2 Posted May 20, 2017 Share Posted May 20, 2017 (edited) Ok so i was able to figure out how to edit these values. Now i have to figure out which controller is being seen first second and third. I now have 2 LSI controllers for 16 ports and then the above onboard sata ports. I have uploaded my dmesg below hopefully someone can decipher. https://mega.nz/#!q8p1XYgS!xjCMRdLxQL41 ... _zEcGIQch0 WOW! A lot of stuff! This is what I see: First controller: 6 ports Second: 2 ports the third: 8 ports and I see only one drive connected to the motherboard directly: Seagate 5Tb (ST5000DM000-1FK178) then mpt2sas0 (LSI card): 8 ports (Sandisck SSD, 3x5Tb, 4Tb) and mpt2sas1 (LSI card): 8 ports (3x4Tb, 2x5Tb) also you have 8 USB buses. All correct at this point? Edited May 20, 2017 by Guest Quote Link to post Share on other sites
antihrist2002 2 Posted May 20, 2017 Share Posted May 20, 2017 I do not have DSM 6 running so I never played with SataPortMap I think it should be SataPortMap=62888 then you need Max disks= 32 esataportcfg="0x0" usbportcfg="0xFF00000000" internalportcfg="0xFFFFFFFF" in /etc.default/synoinfo.conf Quote Link to post Share on other sites
