Hrasbo Posted May 8, 2017 #1 Posted May 8, 2017 Hello It has the nForce 430 chipset, and GBit lan. But I can't get the Newest DSM to give the install the lan, it can't be found on the Intranet. I scroll Down to select the AMD on startup on usb, but no Got a Intel motherboard with a i3 530, with no problems. Has anyone any idea? Quote
Polanskiman Posted May 9, 2017 #2 Posted May 9, 2017 Hello and welcome to the forum, No information on the loader you are using; no information on what version of DSM you are intending to install. Difficult to help. Please provide details. Quote
Hrasbo Posted May 9, 2017 Author #3 Posted May 9, 2017 Hello I try to use DSM 6, and I select the DS3615xs 6.02 Baremetal AMD with Jun's mod v1.01 Found here: viewtopic.php?f=2&t=22100 Quote
Polanskiman Posted May 11, 2017 #4 Posted May 11, 2017 HelloI try to use DSM 6, and I select the DS3615xs 6.02 Baremetal AMD with Jun's mod v1.01 Found here: viewtopic.php?f=2&t=22100 Replace the extra.lzma ramdisk in the loader with the one provided below and try to install again please: https://mega.nz/#!HRJQGbhA!moPPC7fRCn-4 ... E8SaazHDg8 Please report. Quote
Hrasbo Posted May 19, 2017 Author #5 Posted May 19, 2017 Tried it, but it is the same. Can't find it on the network Quote
sbv3000 Posted May 22, 2017 #6 Posted May 22, 2017 This seems to be an older mobo so you could try XPE/DSM 5.2 for better compatibility or try a add on NIC that is known to work with DSM 6(eg intel) Quote
Polanskiman Posted May 23, 2017 #7 Posted May 23, 2017 Tried it, but it is the same.Can't find it on the network What do you see on screen after you have selected the AMD option line in grub? This seems to be an older mobo so you could try XPE/DSM 5.2 for better compatibility or try a add on NIC that is known to work with DSM 6(eg intel) Good advice. Also make sure that this motherboard has AHCI mode/capability otherwise it will not be possible to run DSM 6 with Jun's loader (even with an intel NIC) and you will have to use DSM 5.2 with Xpenoboot loader. So make sure of that before purchasing anything. Quote
Hrasbo Posted June 6, 2017 Author #8 Posted June 6, 2017 Hello It works perfect with DSM 5.2 So thanks for the help. Helge Quote
