Hi. I am using an addon card for more sata ports. Its a syba 8port pci-e 2.0 x1 card. Model number is SD- PEX40104. it uses marvell chipset, 88SE9215 and 88SM9705. Xpenology 5.2 build 5967.1 managed to detect 4 ports that is at the top, but the other 4 ports at the sides are not detected.
Motherboard's 2x sata ports are also detected.
Does anyone know the problem? I went thru compatibility table and found marvell 9215 chipset is supported. Does port multiplier 9705 need to be supported as well? Thanks.
Sent from my SM-N910G using Tapatalk
I use a LSI SAS 9201-16i which works perfect. The only thing that doesn't work with the card is SNMP.
Yes. I saw LSI to be supported in the hardware list. Being a low cost built, i am gonna stuck with 6 ports sata, 4 from the card, 2 from motherboard.
Thanks.
