I installed vmware 12 workstation how do I add my entire hard drive.
I currenlty have a 3 TB drive with data that I don't want to erase. How can I add this do my VM
Create a new virtual machine using the wizard. You will have to create it with a virtual disk at this point. Save your new VM then go back and edit the virtual machine.
Add a new HDD (choose a sensible type that matches your real disk) and then you will get the option to use a physical disk
I am lost on how to add an entire new hard drive. You metion to create a new virtual machine??
I try to add a new hard drive then Use a physical disk then select the physicaldirve# click on use entire disk file but when I boot it fails with this error message
Cannot open disk C:\Users\Server\Documents\Virtual Machines\XPEnology\DSM-2.vmdk
Ok. So what have you been able to do? Before attempting to add a physical disk, you should have imported the virtual machine files from June loader. Did you do that already?
EDIT:
Oh yes and my assumption is that your 3TB disk has come out of a DSM bare metal installation and is not a random disk with data on it.
EDIT AGAIN!
Ah and then I remembered. Check the VMWare documentation. I recall that Workstation only allows physical disks up to 2TB.
I am trying to add a 1.5 TB drive. I really just want to try this software out and if it does everything I want I think I am going to build a bare metal one with 500.00 budget.
So at that price I can buy and average synology or build a really good one
if its just about trying it out, why not format the disk under windows as usual and with vmware just plainly create a virtual drive as file on that new drive letter, if its not about performace or keeping the date it does'nt matter
if you crate thin disks you also might create a number of virtual disks in the vm and try out how to migrate from a basic disk to a raid1 or how to create a raid (1 or 5)
