jarugut 24 Posted July 2, 2019 Share Posted July 2, 2019 Try this file! POWERBUTTON_6.2-0002.SPK 2 Quote Link to post Share on other sites
MikeRoxx 1 Posted July 3, 2019 Share Posted July 3, 2019 @jarugut Thank you! Quote Link to post Share on other sites
Polanskiman 383 Posted July 31, 2019 Share Posted July 31, 2019 @lejurassien This is the English forum. Please post in English. Quote Link to post Share on other sites
n00b 0 Posted August 4, 2019 Share Posted August 4, 2019 (edited) Hello, I'm running a virtualized dx3615 from v1.03b/23739.pat. Installed powerbutton thru web gui, manual install (upload package), shutdown option under admin works! This is great work all, thank you! PS: if you can't download powerbutton file its because you need to register to forum; then the link works. Edited August 4, 2019 by n00b Quote Link to post Share on other sites
Osorkon 0 Posted August 8, 2019 Share Posted August 8, 2019 Thx Working DS3617xs 6.1 Jun's Mod V1.02b @ Proxmox 5.4.6 Quote Link to post Share on other sites
mojojojotroi 4 Posted August 13, 2019 Share Posted August 13, 2019 Thank you all ! Great job !! Working on Acer Aspire M5800 with DSM 6.2.2 update 2 for DS3615xs Quote Link to post Share on other sites
adicontakt 2 Posted August 25, 2019 Share Posted August 25, 2019 (edited) working perfect on Packard Bell Imedia S I3616 NL and DS3615xs 6.1 Jun's Mod V1.02b and DSM_DS3615xs_15284 10x Edited August 25, 2019 by adicontakt Quote Link to post Share on other sites
Jseinfeld 3 Posted September 14, 2019 Share Posted September 14, 2019 On 10/23/2018 at 11:19 AM, hoppler said: Updated powerbutton package to work with dsm 6.2 for ds3615, ds3617 and ds918+ POWERBUTTON_6.2-0002.SPK 106.5 kB · 297 downloads or https://www39.zippyshare.com/v/R3ftOA3X/file.html Thanks. Works great on my Asrock J4105 with the 918+ image. Quote Link to post Share on other sites
xuplus 0 Posted September 30, 2019 Share Posted September 30, 2019 insmod: ERROR: could not insert module /usr/lib/modules/evdev.ko: Invalid module format insmod: ERROR: could not insert module /usr/lib/modules/button.ko: Invalid module format with powerbutton 6.2-0002.spk 835d438200ac0538ccdd4568b2dd0ad9 POWERBUTTON_6.2-0002.SPK Quote Link to post Share on other sites
doveoscar 1 Posted October 12, 2019 Share Posted October 12, 2019 Thank you. 6.2-0002 works perfectly on my Odroid H2/Xpenology DS918+/DSM 6.2.1. Quote Link to post Share on other sites
G.Lee 0 Posted November 13, 2019 Share Posted November 13, 2019 Hi, Installed on baremetal gen8 with boot 1.03b on DS3615XS, on dsm 6.2.2-24922 Update 4 I'm not able to shutdown or reboot from dsm gui, or from real buttons of my gen8. That package was supposed to fix the problem ? Quote Link to post Share on other sites
IG-88 664 Posted November 13, 2019 Share Posted November 13, 2019 i can provide button.ko and evdev.ko for 6.2.2 and all 3 images , my oracle virtualbox vm does shutdown on acpi shutdown with it here are the ones for 3615 you install the POWERBUTTON_6.2-0002.SPK and then copy these 2 files to /usr/lib/modules/update button.ko evdev.ko Quote Link to post Share on other sites
aibos 0 Posted December 3, 2019 Share Posted December 3, 2019 (edited) IG-How can I make this work with DS918+ running as A virtualbox guest Edited December 3, 2019 by aibos Quote Link to post Share on other sites
IG-88 664 Posted December 3, 2019 Share Posted December 3, 2019 (edited) 6 hours ago, aibos said: How can I make this work with DS918+ running as A virtualbox guest i installed the last packed and after installing replaced the button.ko and evdev.ko with the files belonging to 6.2.2 the installer in the package replaces the files of a 6.2.2 system with the files in the package and they belong to 6.2.(0), everything else is fine, you just have to bring the kernel driver files back to the version they need to be (/usr/lib/modules/) as final solution the package needs to be modified to be aware of 6.2.2 and have extra *.ko files for this version postinst () { chown -R root:root ${SYNOPKG_PKGDEST} cp -R ${SYNOPKG_PKGDEST}/files/* / cp -R ${SYNOPKG_PKGDEST}/modules/$DSM_VERSION/$DSM_PACKAGE/* /usr/lib/modules/ exit 0 Edited December 3, 2019 by IG-88 Quote Link to post Share on other sites
aibos 0 Posted December 3, 2019 Share Posted December 3, 2019 Thanks it worked Quote Link to post Share on other sites
advin 3 Posted December 4, 2019 Share Posted December 4, 2019 Nice one thanks! bro Quote Link to post Share on other sites
Knallix 0 Posted December 30, 2019 Share Posted December 30, 2019 DSM 6.2.2-24922 update 4 // DS918+ ->>> PROXMOX VM I installed the file POWERBUTTON_6.2-0002.SPK. Does the file first have to be copied into the directory and then install the SPK or does it matter? Then copied the button.ko and evdv.ko file in /usr/lib/modules (folder I gave chmod 777 rights). Otherwise I couldn't copy the file. Is it correct that the evdev.ko file was not present? -> Or do I need another directory here? Unfortunately the server cannot be shutdown using the "Shutdown" button in the PROXMOX webui. The server only runs via the button on the Webui from the server itself. What else have I forgotten or done wrong? Quote Link to post Share on other sites
IG-88 664 Posted December 31, 2019 Share Posted December 31, 2019 just remove the button.ko and evdev.ko from /usr/lib/modules there are new one in /usr/lib/modules/update already the plugin is not aware of the changes of 6.2.2 and blindly overwrites with old 6.2.0 files the rest is fine, after removing the old/wrong files and rebooting your system should be able to use acpi power off i'm using this with my dsm test vm's in virtualbox the plugin needs to be extended for 6.2.2 and needs new button.ko/evdev.ko files (can be extraxted from my extra.lzma's) Quote Link to post Share on other sites
stasheck 1 Posted January 3, 2020 Share Posted January 3, 2020 Can confirm it's working for me (at least shutdown): Proxmox 6.1-5, image 3615 + 1.03 loader, DSM 6.2.2 Quote Link to post Share on other sites
mervincm 12 Posted February 15, 2020 Share Posted February 15, 2020 Is there an easy way to use winSCP or something like that to update these files? I cant get the winscp session to be elevated to SU to have enough permission to write to folders like this. Similarly, the File station app can't browse these folders either. Quote Link to post Share on other sites
mervincm 12 Posted February 15, 2020 Share Posted February 15, 2020 On 12/31/2019 at 6:46 AM, IG-88 said: just remove the button.ko and evdev.ko from /usr/lib/modules there are new one in /usr/lib/modules/update already .. and rebooting your system should be able to use acpi power off the plugin needs to be extended for 6.2.2 and needs new button.ko/evdev.ko files (can be extraxted from my extra.lzma's) I tried to pull those two files from your 918 extra.lzma and put them both in the /usr/lib/modules/update AND the /usr/lib/modules/ folder, rebooted, and my power button still does not shut down my physical suggestions to troubleshoot? Quote Link to post Share on other sites
IG-88 664 Posted February 16, 2020 Share Posted February 16, 2020 3 hours ago, mervincm said: suggestions to troubleshoot? did you install the "POWERBUTTON_6.2-0002.SPK" does shutdown from the web gui work properly? Quote Link to post Share on other sites
mervincm 12 Posted February 16, 2020 Share Posted February 16, 2020 absolutely, I have had that package installed for a while now, it used to work quite a while back. Yes it does restart and shutdown correctly from the GUI. I just would like to be able to shut it down using the physical power button. the power button will do an oldschool forced shutdown it I hold it four 4 seconds, so the button is OK. Quote Link to post Share on other sites
IG-88 664 Posted February 16, 2020 Share Posted February 16, 2020 1 hour ago, mervincm said: absolutely, I have had that package installed for a while now, it used to work quite a while back. reinstall the package, overwrite the files (old file date) with the new as you did before, reboot try the shutdown by button, check the log (dmesg) for errors during boot (drivers loading) and the (attempted) shutdown you can also look for whats in /dev/input/ and /sys/class/input/ there should be something if the drivers are loaded properly Quote Link to post Share on other sites
whatever000 1 Posted February 21, 2020 Share Posted February 21, 2020 I tried to install powerbutton_6.1-0005.spk on 6.2.2 24922 with driver extension 0.8 on 1.04b 918+ loader. But it said the DSM version is not supported. How do I install it? @IG-88would it be possible to include the power button stuff in the driver extension release? Thanks. Quote Link to post Share on other sites
